#85 | |
Drives: Brz
#86 | |
yes on key start lasy click before starter cranks sounds like you may have wiring issue does car actualky start on old ecu ? test you 4-13 loop on a friends car it wont harm to test it |
#87 |
Drives: Brz
No the car doesn’t start on old ecu because the ecu is fried. I was trying to fix this trash wiring job the last owner did for the gauges and accidentally blew the old ecu. I took it to a mechanic to confirm the ecu was fried and they said it was. That’s why I bought a new Ecu to get the car up and running again.
#88 |
Drives: 2016 scion frs
Okay so i'll be needing to replace my ECU due to P0018 code. Would this process still be the same for a push to start FRS/BRZ? also Im confused on what to replace to have the alarm system and start up working as intended. Would i need to also replace the alarm system like the immobilizer? or is the ECU/ECM the only thing needed?
#89 | |
Same process pish button start or key start, you only need to swap ecu nothing else |
| The Following User Says Thank You to steve99 For This Useful Post: | jrhudson (01-05-2022) |
#90 |
Okay so i swapped ecus and im trying to change the vin number via techstream but the alarmed is somehow armed and i cant disarm it. Everytime i put the car into ignition the alarm goes off. Im confused anyway so this doesnt happen?
I swapped back my original ecu and the alarm still goes off. Whenever i connect the battery even tho i havent set the car into on mode its already like this. Last edited by jrhudson; 01-27-2022 at 05:12 PM. Reason: extra info |
#91 | |
Assume its aftermarket alarm ? you will likely need documention on how to reset or reprogram it |
#92 | |
I connect the battery and some lights in the car turn on. |
#93 | |
https://www.gt86.org.uk/forums/forum...ctivate-alarm/ few post down is factpry alarm manual, we dont jave it in my country so i have zero knoledge on it |
| The Following User Says Thank You to steve99 For This Useful Post: | jrhudson (01-28-2022) |
#94 | |
Also i believe the ecu i got was for the MY15 manual just like mine but during the 30 min learning period the dash says A/T OIL TEMP. i've never seen that appear before, ever. Is that an indication replacement ecu i have might've been for an auto? |
#95 | |
ues if your getting that id say the new ecu is programmed with an auto calibration plug ecu in and read calid from ecu if its auto calibration and tour car manual it wont start either |
#96 | |
Calid for replacement ecu is d00d but my original ecu calid is D00C. When i tried to flash via ecutek with the correct calid rom (d00c) it said it wasnt compatible. Last edited by jrhudson; 01-28-2022 at 06:55 PM. |
#97 | |
ok thats easy fix message me ill telk you how to override ecutek rom id check |
#98 |
Couldn't get my key fob to disable the alarm even after the 30 min relearn period. I have a manual frs and accidentally got an auto ECU as the replacement but thanks to @steve99 assisting me in turning my auto ECU to a manual ECU.
Getting the ecutek tune in for my setup was the solution. key fob/security system was working as intended. thanks again @steve99 Last edited by jrhudson; 01-30-2022 at 04:10 AM. |
| The Following User Says Thank You to jrhudson For This Useful Post: | steve99 (01-30-2022) |
| Bricked ECU? | FirestormFlex | Software Tuning | 8 | 03-14-2016 10:20 AM |
| My OFT is basically bricked | austin_ellas | Software Tuning | 19 | 03-08-2016 07:59 PM |
| Who has Bricked an ECU | Toyota John | Software Tuning | 5 | 03-02-2015 11:10 PM |
| Need Bricked BRZ 86 ECU | steve99 | Software Tuning | 0 | 10-25-2014 07:09 PM |
| I think I bricked my ECU with EcuTek help | iketiak | Engine, Exhaust, Transmission | 4 | 07-04-2013 12:19 AM |
