Old 09-24-2012, 09:05 AM   #85
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
Mobil 1 is to Motor Oil as Jose Cuervo is to tequila. It is not that good. However, I'm not sure why it would be consumed/lost so much by Subaru engines specifically. I don't use it or plan to ever use it, so I won't be able to speak directly to that specific issue.
I just did my first oil change at just over 2K miles with Motul 300V and Power Enterprise MAG II Filter; installed a QwikValve; and sent the FF oil off to Blackstone labs for a baseline analysis.
Here's some pics and links to the products I used:
First Oil Change
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 10-07-2012, 09:13 AM   #86
Captain Insano
I have some mobil1 full synthetic 0w-20 I'm about to use. Will post if the engine starts to eat it once I have it in the car.
The Following User Says Thank You to Captain Insano For This Useful Post:
zoomzoomers (10-07-2012)
Old 10-07-2012, 10:58 AM   #87
n2oinferno
Praise Helix!
n2oinferno's Avatar
I skimmed through this, but I saw something that the OP missed.
Oil.
You definitely must have oil when doing oil changes.
Also cat litter can help to clean up spills that might happen.
Old 10-07-2012, 08:37 PM   #88
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
I know I might get flamed for saying this, but I wonder if these oil manufacturers have successfully Jedi mind tricked a huge portion of our population. I have an uncle who is a retired mechanic and had his own shop for decades. He once told me that buying expensive oil is pretty much a waste. If you maintain your car well and change your oil & filter at the recommended intervals.
Now I know there's a ton of research and yada yada, but how many of us push the limits of the oils used in our cars to a point where they break down. If anything I'd gather that most enthusiasts change their oil faster than what's recommended so wouldn't logic dictate we use the value brand, that meets the standards set by the factory, and save money? I mean wven for those who track their cars, etc. Do they merit using expensive oils that will be changed out way early??? I just can't stop thinking that we've been bamboozled. LOL
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 10-07-2012, 09:10 PM   #89
Captain Insano
Well, I think it's a sorta a weird bizarro world thing with oil and maintenance for car fanatics. Let's face it, if you come on this forum as much as most people that are reading this, you are probably a little bit fanatical about your car(s).
So, I do agree with alot of what you are saying. I knew a pretty great engine builder and he once told me he puts the cheapest oil he can find in his cars. He changes the oil when it needs to be changed. And he doesn't sweat it, because as long as the car has oil and you are changing it when you are supposed to, things will be fine.
I tend to agree with that, but at the same time, I know that I'm a little bit paranoid about my car too. And, I have been there in the past with some of the cars I love, spending way too much on oils and other maintenance stuff, because I'm paranoid. The only time I've ever had a problem with an engine was due to a bad aftermarket tune. Nothing to do with oil - and I've never had any other problems with an engine.
So what I'm saying... I agree with you. But I think most people that like their cars as much as we do. That will spend oodles of money on even minor performance gains or appearance modifications... They tend to not care much about overspending on oil. Know what I mean?
I think some oils definitely are better than other oils. But I also think, if you are changing your oil every 3000-4000 miles or after track sessions like most of us here, you should be just fine even if you are using an average oil instead of the very best oil money can buy.
Old 10-07-2012, 09:54 PM   #90
zoomzoomers
Jedi mind trick = paranoia
Old 10-11-2012, 09:33 AM   #91
Jayde
Jayde's Avatar
So is there ramps out there that will clear our cars and provide ample amount of space to drain the oil, but not cost an arm and a leg?
Jayde is offline   Reply With Quote
Old 10-11-2012, 12:22 PM   #92
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Don't really think so. You can use wood planks in addition to rhino ramps, like on this DIY: http://www.ft86club.com/forums/showthread.php?t=11730
Or you can do what I do and just jack up the car onto the rhino ramps.
Phaedrus29 is offline   Reply With Quote
The Following User Says Thank You to Phaedrus29 For This Useful Post:
Jayde (10-11-2012)
Old 10-13-2012, 12:58 PM   #93
xwd
I have these, they work well.
http://www.griotsgarage.com/product/...tension+kit.do
Old 10-13-2012, 09:13 PM   #94
Phaedrus29
Phaedrus29's Avatar
Originally Posted by dwx View Post
Nice! So you can just drive up on those no problem? They don't look very high...how's the space underneath?
Old 10-18-2012, 09:48 AM   #95
Vukodlac
Vukodlac's Avatar
Drives: Asphalt FR-S
I'm loving that Fumoto oil valve. What a great idea, thanks for the suggestion!
-2013 Scion FR-S-
K&N drop in.
Motiv overpipe, hfc. Perrin unresonated. Stage 1 NA Tune ( Thanks Drift Office )
Vukodlac is offline   Reply With Quote
Old 10-24-2012, 09:49 PM   #96
RedRocket
RedRocket's Avatar
Drives: Firestorm Red FR-S
I know.. I'm at 1200miles on my FR-S.. Might have to do my install of the Fumoto now.
RedRocket is offline   Reply With Quote
Old 12-30-2012, 10:39 PM   #97
oaroyale
Drives: Black BRZ
Quick question, when installing the fumoto valve, do I have to use a crush washer?
oaroyale is offline   Reply With Quote
The Following User Says Thank You to oaroyale For This Useful Post:
86WRX (02-01-2013)
Old 12-30-2012, 11:34 PM   #98
zoomzoomers
No. The valve itself has one on it.
[=oaroyale;635667]Quick question, when installing the fumoto valve, do I have to use a crush washer?[/QUOTE]
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 02:27 PM
Toyota Holds "FT-86 Fastest Painted Website" Event to Help Launch FR-S / FT-86 Snoopyalien24 Scion FR-S / Toyota 86 GT86 General Forum 35 11-26-2011 07:56 AM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
