03-10-2016, 10:36 PM | #953 |
Drives: 2015 Raven FRS
03-10-2016, 11:23 PM | #954 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
I've had the tires break loose when i'm starting out in 1st gear and floored it. I was surprised as this was in a straight line. Taking a turn really doesn't count, as you can break loose in a turn with pretty much any tire if you get on the gas mid turn too much and you're going fast enough. However, taking the same turns I do every day, it takes much less gas pedal input (at the same entry speed) to break the tires loose mid turn now, and at lower revs. Have you found it to be the same, driving your car?
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
The Following User Says Thank You to shiumai For This Useful Post: | CSG Mike (03-12-2016) |
03-11-2016, 09:58 AM | #955 | |
03-11-2016, 12:23 PM | #956 | |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
Anybody on drive shaft shop axles here? Might be worth the upgrade now. |
03-11-2016, 12:25 PM | #957 | |
Drives: '13 BRZ | '04 E55
Much better now lol. My stock ones lasted me about 76k miles. I installed this one last week. Took it to the autocross this past weekend and it's doing ok so far. My plan is to go upgraded as funds allow. Sent from my iPhone using Tapatalk
03-11-2016, 01:15 PM | #958 |
03-11-2016, 01:24 PM | #959 |
Correct, I only replaced my driverside axle with an OEM.
I would like to upgrade to DSS 600hp axles, but I can't afford to do them right now. Edit: FWIW, I'm on 265 PSSs, and switching to 255 RS-3s.
The Following User Says Thank You to NotSoJDM For This Useful Post: | CSG Mike (03-12-2016) |
03-11-2016, 05:16 PM | #960 |
I wonder if they're stickier than the toyo proxes sport T1s i have. i've also had these same tires for 3 years now and they may not be as soft as they were when new.
my plan was to switch to the RS-3s when these wear out, and also go down from 265 to 255 in the rear as i believe the RS-3 has a more squarish sidewall profile and would rub if i stayed with 265. i haven't noticed any axle clicking - i've only done a couple of launches; but i typically try to roll onto the throttle vs. mash it suddenly (i drive my car like i used to ride my motorcycle). i also only have 7900 total miles on the vehicle.
03-11-2016, 07:52 PM | #961 | |
03-11-2016, 08:14 PM | #962 | |
03-11-2016, 09:42 PM | #963 |
It's been 6 weeks now. I'm out in the middle of no where at least as far as good tech's are concerned. Delicious Tuning keeps saying I have a vacuum leak. We smoked the car again today for 4 hours. 2nd time we've done this, but can't fine a single leak anywhere. We've changed every vacuum hose and added new clamps. but still runs like crap below 1500 rpm.
03-11-2016, 10:24 PM | #964 | |
Drives: Scion FR-S (Hot Lava)
Sent from my SM-T320 using Tapatalk |
03-12-2016, 01:47 AM | #965 | |
Upgrade, and never have to worry again. Unless you decide you want 800hp. |
03-12-2016, 01:47 AM | #966 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | shiumai (03-12-2016) |
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
