#939 |
Quote from OptimumG:
"On a car where rules allow, and you choose to do so, a suspension system can be designed where damping adjustments can be made that isolate ride, roll, and pitch. Finding an ideal baseline for roll and pitch damping are discussed below, however, most cars due to their suspension design are forced to make a compromise between the three (this explains the point mentioned above with successful cars using non-ideal damping ratios in ride)." A lot of people overlook this fact and wonder why people aren't going for the 2.2 Hz number and leaving it at that. It's also one reason why there is some wiggle room in the damping ratios. - Andy |
#940 | |
Junior
Drives: a car
lol jkI've dealt with frequency before, only in audio though. I know nothing about impulse response, dampers and settling time.
#941 | |
1. Remember that total weight transfer is not affected by spring rate in a given corner. You can alter the proportion of weight transfer front and rear, but not the total. 2. Firmer suspension means quicker reactions and quicker weight transfer. The car changes direction quicker and feels nice. Very quick weight transfer can overload a tire rather than loading it up nice and progressively, so there's a balance. 3. Firmer suspension (and less roll) is a good way to minimize camber loss and suspension geometry changes. - Andy |
#942 | |
How To Make Your Car Handle by Fred Puhn is a good book. Old, but good. - Andy |
#943 |
Junior
Drives: a car
I'll look into it! I hope there are some good puhns...
#944 |
#945 |
Junior
Drives: a car
So after a little reading, who is going to under take the hidiously enormous task of converting a 86 into a double wishbone suspension
#946 | |
i'm sorry, what?
Drives: Canada
but really, given the application requirements, the only problem we have from being on struts is limited adjustability in stock form
#947 | |
#948 |
Quick question, I have the ST Coilovers, do i need to get camber bolts to adjust front camber or is it okay w/o it since ST's are slotted
Thanks |
#949 |
Junior
Drives: a car
Rather than going for the cheaper option, miata or the like, I would attempt this only due the fact of how different the car would sit and feel on the road and track, the unique appeal also has some allure to it as well
#950 |
Junior
Drives: a car
From the difference in design is there any way in which the double wishbone is better?
#951 | |
That Guy
Drives: 2013 asphalt FRS MT
#952 |
i'm sorry, what?
Drives: Canada
it's generally easier to make the wheel maintain a desired angle to the road during suspension movement... even a lot of movement
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
