, dpfarr
Old 03-03-2016, 03:26 PM   #911
86fun
Drives: 2013 FRS
Originally Posted by NotSoJDM View Post
There's certainly a lot of tire spin happening....even on 265 street tires...
I can attest to this. In my first 13k miles, being 100% stock, the tires (originals from purchase) hardly wore down at all. In the past few hundred miles of testing various tunes with Edelbrock I've nearly depleted the rear tread! When the car is running at full power (mine isn't consistent at this point unfortunately) it will spin 1st very easily and 2nd too if you drop the clutch a bit shifting from 1st. I even got 3rd to step the rear out on a hard shift once. I'm only on the CARB tune! This is with stock tires of course. I think a wheel/tire upgrade should go with this kit!
86fun is offline   Reply With Quote
The Following User Says Thank You to 86fun For This Useful Post:
paiceyfan (03-03-2016)
Old 03-03-2016, 03:27 PM   #912
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Right foot discipline...MOAR GAS!
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
NotSoJDM (03-03-2016)
Old 03-03-2016, 03:30 PM   #913
I might be able to do a couple of flyby's but I'm afraid you might be disappointed if you're looking for that SC whine. These TVS units are super quiet, combined with my exhaust, you might as well just watch stock flybys
You can hear it faintly with a stock exhaust and header...
less noise = more efficiency!
Yoda (03-03-2016)
Old 03-03-2016, 04:09 PM   #914
Yoda
Drives: Crystal Black BRZ(Sophia)
This will be really great for a sleeper...
Yoda is offline   Reply With Quote
Old 03-03-2016, 04:27 PM   #915
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
For street driving? No, you don't need a cooler.
If you're going for spirited drives that have sustained high RPM, or are tracking the vehicles, you should have an oil cooler.
Edelbrock probably has something in the works, but there are several options that fit, if you decide you need an oil cooler.
The OEM FA20DIT cooler is a perfect match for street driving, and casual spirited drives; it is not suited for track driving.
Just read this...now I am worried. I am getting the kit installed, but with no oil cooler and I expect to hit a couple of track days this year...
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 03-03-2016, 04:41 PM   #916
It's no different from tracking a NA car. You'll be okay for a few track days, but if you do more than that, you really should be getting an oil cooler.
If you absolutely MUST have one asap, we've verified the Perrin cooler fits with a slightly modified mounting location (easy to DIY if you're installing yourself).
They're in stock and ready to ship.
Old 03-03-2016, 04:45 PM   #917
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Originally Posted by j123ic View Post
Just to be clear. Do you perhaps mean the "EVAP" solenoid? It is located located underneath the supercharger and has two ports that require hose clamps. Additionally clamps are required on each hose end going to the EVAP hardline and the the supercharger nosedrive.
Yes, step # 83 in Edelbrock's instruction book.
Lunatic is offline   Reply With Quote
Old 03-03-2016, 04:56 PM   #918
paiceyfan
paiceyfan's Avatar
No money for it right now, but thanks for the reassurance. I will ensure that when funds become available down the road it's top of my list.
Cheers!
The Following User Says Thank You to paiceyfan For This Useful Post:
CSG Mike (03-04-2016)
Old 03-03-2016, 05:21 PM   #919
Uplink
Uplink's Avatar
Drives: anything you let me
I thought Perrin fits with no modification?
Any idea how much the Perrin setup weighs? It's listed as 20lbs but I'm guessing that's boxed shipping weight. Just wondering what else has to be removed from the car to compensate.
Uplink is offline   Reply With Quote
Old 03-03-2016, 06:26 PM   #920
CounterSpace Garage
You will not notice the weight difference for these reasons:
1. Your ECU pulls timing when your oil temperature increases and you effectively lose power.
2. The engine power output will be more consistent with an oil cooler.
3. You will be happier knowing that you won't kaboom your engine due to negligence.
Side note, your wallet will feel marginally lighter rather than exceptionally lighter (oil cooler vs. fresh motor).
The Following 2 Users Say Thank You to CounterSpace Garage For This Useful Post:
clayrush (03-03-2016), Uplink (03-03-2016)
Old 03-03-2016, 08:48 PM   #921
Uplink
Uplink's Avatar
Hehe, all very important points. Seriously though, I'm only curious because I have a static power/weight ratio goal.
Old 03-03-2016, 09:23 PM   #922
CounterSpace Garage
You can cut weight elsewhere such as dry carbon panels, full strip of the interior and rollcage it with dry carbon seats.
Old 03-03-2016, 10:08 PM   #923
Uplink
Uplink's Avatar
If you only saw my search history... I'd be proud if it were actually porn.
Nah, keeping this one with full amenities. Maybe a Beatrush bumper replacement or TIG up my own aluminum version to offset the weight.
Back to our regularly scheduled Edelbrock goodness...
The Following User Says Thank You to Uplink For This Useful Post:
sato (03-04-2016)
Old 03-04-2016, 03:26 AM   #924
Pushing it a little more forward is recommended, to give a buffer between the cooler core and the LTR.
paiceyfan (03-04-2016), Uplink (03-04-2016)
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
