Old 05-15-2014, 10:40 PM   #911
cycleboy
Drives: 2013 Scion FR-S - Argento
Originally Posted by Foobar View Post
Only on the passenger side and it didn't happen last year so some water must have frozen in the gap somewhere over the winter and broke a seal to allow water in.
My guess is it isn't that complex. The seals are thin, not well adhered, and only across the top of the housing. Probably just a matter of time before we all get enough crap and water going that way to make them leak.
cycleboy is offline   Reply With Quote
Old 06-03-2014, 12:06 AM   #912
treystarks
treystarks's Avatar
Drives: 2013 Firestorm FR-S
Took the dealer two hours to replace my light. Gave me a fucking corolla and broke ny laptop in the trunk. Fml
Sent from my SAMSUNG-SM-N900A using Tapatalk
treystarks is offline   Reply With Quote
Old 06-10-2014, 08:11 PM   #913
69Marshall69
69Marshall69's Avatar
Drives: 2013 Subaru BRZ-S
Subaru dealer being a bunch of ****s, wont replace my tail light because I have painted it(even though it was painted my a custom shop who never removed the light) looks like im doing it myself. The MOD Life
69Marshall69 is offline   Reply With Quote
Old 07-16-2014, 12:45 AM   #914
choi0706
Drives: t
where does one find METHYL HYDRATE down south? with no real winter
choi0706 is offline   Reply With Quote
Old 07-16-2014, 12:56 AM   #915
choi0706
Drives: t
anyone try windex?
Old 07-17-2014, 12:29 AM   #916
RFB
RFB's Avatar
Drives: FRS
Originally Posted by choi0706 View Post
anyone try windex?
Windex is soap water and ammonia D. The ammonia D is different than regular ammonia. Ammonia D is a dessicant, but it is insufficient to remove the soap residue.
The interior of the tail housing will be a mess, as you will be adding a stain to the plastic, soap and water will remain, as well as the condensation.
CERBERUS
RFB is offline   Reply With Quote
Old 08-06-2014, 09:37 PM   #917
cycleboy
I finally got the chance to put on my gasket ninjas today and they are great. These are a very high quality item, much nicer than factory. I also appreciated the fast service and communication from @wdninja.
I didn't have enough of the sticky stuff to make the full dam around both sides, so I glued on the gaskets and did as much damming as possible and will add more tomorrow.
The top of the lights w/ the factory gaskets was just a total mess of dried mud, leaves, and other junk. It's no wonder eventually those thin tape strips leak.
Old 08-07-2014, 07:18 PM   #918
wdninja
wdninja's Avatar
Drives: 2023 Toyota GR86 Premium
Similar to what RFB has done, I also cover the gap between the tail light housing and the trunk channel, to prevent the water from hitting the gasket in the first place.
I use waterproof black tape instead of the "snowman snot", but it's the same idea.
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
wdninja is offline   Reply With Quote
Old 08-17-2014, 03:45 PM   #919
Foobar
SLO NO MO
Foobar's Avatar
I ended up using some removable caulk, in the same location as wdninja's waterproof tape above.
Old 08-19-2014, 10:03 PM   #920
cycleboy
removable caulk
Funny when said out loud!
Kind of like a. . .
[ame="https://www.youtube.com/watch?v=byDiILrNbM4"]King Missile - Detachable Penis - YouTube[/ame]
Old 09-03-2014, 02:15 PM   #921
Parappa
Parappa's Avatar
Drives: Scion FR-S White Out
Did this method work?
Parappa is offline   Reply With Quote
Old 10-27-2014, 12:31 PM   #922
redfred
Drives: Red BRZ
Just had both of mine replaced at the dealer under warranty. A month ago they tried the "kit", but that actually made the problem worse. Apparently, the early versions crack where they are bolted to the car.
Will wash car later today to verify...
redfred is offline   Reply With Quote
Old 10-28-2014, 10:55 AM   #923
Canadian Greg
Drives: Black 2013 fr-s
Tail light condensation
I'm afraid it won't go away... I had the same issue and it is quite common.
Dealer replaced mine under warranty. Toyota knows there's an issue, but not enough to recall it.
Canadian Greg is offline   Reply With Quote
Old 10-28-2014, 11:46 AM   #924
WtFxMintBerry
Drives: 2013 Asphalt fr-s
I had toyota/Scion dealer (Scott Clark South Blvd.) here in Charlotte, NC replace both taillights and gaskets even though only the passenger side was building condensation, they did it in about 2 hours last weekend.
I bought my 2013 FRS used with 23k, and 75k additional warranty. It was still covered it under warranty and did not cost me anything.
WtFxMintBerry is offline   Reply With Quote
Red tail light photoshops OwenK FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 68 02-06-2013 03:48 PM
HKS head and tail lamps DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 5 05-19-2012 01:04 PM
Tail of the Dragon Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 32 02-10-2012 02:30 PM
headlight condensation MRZ415 Off-Topic Lounge [WARNING: NO POLITICS] 1 01-23-2012 02:24 AM
Optional coloured tail lights? m_life Scion FR-S / Toyota 86 GT86 General Forum 9 11-30-2011 06:20 PM
