Old 12-21-2021, 04:37 PM   #9115
Hurricane Nate
Drives: 2020 BRZ (Black)
Originally Posted by kev0 View Post
Belt #3 snapped today. Think i'm going to replace idler pulley too this time. It did look worn out and the edge of it appeared to be melting a bit.
I had some issues with belts awhile back, namely they would wear funny and then one of the bands (closest to the block) would separate from the rest of the belt. I checked all my pulleys carefully and found an idler pulley had a burst seal, and that caused it be out of alignment with the other pulleys. Replaced the pulley and I’ve been going strong for six months of daily driving (about 6k miles). The belts had previously only lasted to 1 month (1k miles) before breaking.
I do have the Edelbrock kit, so ymmv, but I found my belt breaking issue to be bad idler pulleys.
Hurricane Nate is offline   Reply With Quote
The Following User Says Thank You to Hurricane Nate For This Useful Post:
kev0 (12-24-2021)
Old 12-24-2021, 02:03 AM   #9116
kev0
Drives: '14
Thanks! Mine has been fixed by replacing one of the idler pulleys as well! 4k miles strong so far!
kev0 is offline   Reply With Quote
Old 12-24-2021, 02:55 AM   #9117
Ads
Drives: 86
Originally Posted by subsonicflo View Post
Has anyone ever inspected seals or changed the bearing on Sprintex S5-210's?
Sprintex nor Jon Bond are replaying to my inquires. I am looking for torque specifications.
My unit was previously owned. The oil leaks onto my rotors and is the reason why the intake manifold and intercooler were full of gunk.
https://imgur.com/a/BM3Otwh
According to the manual (https://www.innovatemotorsports.com/...tercooled_.pdf):
Pulley to nose/pulley hub = 12Nm
Throttle body to Manifold = 12Nm
Manifold to Engine = 25Nm
According to Sprintex (from past emails):
Drive extension/nose and oil sump to Supercharger face = 23Nm
Unfortunately, I can't find specs for the Supercharger to the intercooler/manifold or any of the internals.
Is this related to this issue?
https://static1.squarespace.com/stat...letin+0004.pdf
Ads is offline   Reply With Quote
Old 12-28-2021, 11:20 AM   #9118
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
When doing autox my belt on my crank pulley slipped off one notch towards the engine and was making a horrible noise. Fortunately I made it home and figured out the issue. Shortly after that I replaced all the pulleys with the RaceSeng Revo 7 package and haven't had an issue since. Got the green K061015HD Gates belt that is heavier duty which will hopefully last longer as the prior one that was a few years old wasn't looking very good.
stockysnail is offline   Reply With Quote
Old 12-30-2021, 11:01 PM   #9119
Laybaaan
Laybaaan's Avatar
Drives: 2019 Subaru BRZ Series. Gray
Anyone here have a 70mm Rasceng pulley they're willing to part?
Sent from my SM-G991U using Tapatalk
Laybaaan is offline   Reply With Quote
Old 02-10-2022, 02:49 AM   #9120
Jeff_Sin
Drives: A FI Toyota 86
Hi Guys, may i know when checking the supercharge oil level , it is good to check while the engine is hot or cold ?
Jeff_Sin is offline   Reply With Quote
Old 02-11-2022, 10:51 AM   #9121
stockysnail
Just the tip
I typically check when cold. It's such a tiny area that I don't think there would be much difference when hot (oil over the parts more) vs cold (all oil on the bottom).
I usually have to put in a tiny amount every month so I'd recommend checking it once a month or maybe 3 at the most. I see a little oil around the top where the stick goes occasionally as the pressure pushes some out. I've also tried a vented bolt instead of the stick but it was actually worse and pushed oil out the vent.
Old 02-11-2022, 10:53 AM   #9122
stockysnail
Just the tip
Anyone know if the Sprintex will fit on the new gen2 BRZ/GR86? Only the bore is different but if the manifold is the same as gen1 then it should work. Most everything else uses the same parts it seems from the look at it in the videos from Savagegeese.
Old 04-27-2022, 02:31 PM   #9123
EvilPenguin04
Drives: 2015 BRZ 2004 SVT Cobra
Newish person here I've been reading through this thread for a few months making notes of stuff. We installed a 210 intercooled kit on my wife's BRZ a couple of months ago with the stock pulley and just a Borla catback on the car and Ecuteck tuned by Delicious Tuning. Now we are starting to gather parts to support the 69mm pulley we have for it, so any recommendations are welcome. Not really going for specific dyno numbers since the car is an Auto and all dyno's are different just want a fun car to play with. I have my turbo Cobra to chase numbers with.
EvilPenguin04 is offline   Reply With Quote
Old 05-20-2022, 02:24 PM   #9124
EvilPenguin04
Decided to take the BRZ to a 1/8th mile about 25 minutes from our house. Being an auto with just the kit 75mm pulley and a borla catback as the only power I was going to be happy with a 9.5 or less. I know this isn't what these cars are made for but it's all in the fun of getting out and having fun with the car.
First run heat the car was heat soaked from the 85 degree temp and drive there. second run was the best after I let it cool down for about an hour and a half.
The Following User Says Thank You to EvilPenguin04 For This Useful Post:
frostyfrs (01-05-2023)
Old 09-29-2022, 09:45 AM   #9125
Superseriesgrey
Drives: Series grey brz
BPV
Has anyone tried to run an aftermarket BPV on this supercharger? Or tried to switch to a BOV? If so what worked for you and was there any performance increases after tuning?
Superseriesgrey is offline   Reply With Quote
Old 09-30-2022, 01:26 PM   #9126
jflogerzi
jflogerzi's Avatar
I miss my old SC setup. Looking at this thread was fun
2013 Series 10 FRS #553
Old 01-05-2023, 12:28 AM   #9127
frostyfrs
Drives: Supercharged 2013 Scion FR-S
frostyfrs is offline   Reply With Quote
The Following User Says Thank You to frostyfrs For This Useful Post:
tomm.brz (01-05-2023)
Old 01-25-2023, 12:32 AM   #9128
amirnew
Drives: 2013 BRZ sprintex SC
Originally Posted by frostyfrs View Post
On wich dyno is that
amirnew is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
