Old 01-16-2014, 06:46 PM   #897
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Terrapin77 View Post
On the newest firmware, I can't perform a backup. I get a popup screen that says "Backup Error".
Sent from my XT912 using Tapatalk
Thanks for the heads up. I'll confirm the problem and email the programmers for a resolution. To be honest, I don't use the back up feature on this platform since the ROM files aren't unique to each car as they are in other platforms.
Old 01-16-2014, 07:15 PM   #898
utekineir
blowhard
Drives: frs, project forester
Shiv,
What are your thoughts on the pump gas s2 oft map with a gutted/cat delete on the stock header?
Advisable/not advisable?
Thanks.
utekineir is offline   Reply With Quote
Old 01-16-2014, 07:31 PM   #899
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by utekineir View Post
Shiv,
Thanks.
I'm sure it will be ok. I haven't tested it myself but give it a go.
Old 01-16-2014, 08:51 PM   #900
Vlady
Vlady's Avatar
Drives: Argento Scion FRS
Its like Christmas everytime revisions are put up! Each revision feels more and more refined. Thanks alot Shiv!!
Vlady is offline   Reply With Quote
Old 01-16-2014, 10:24 PM   #901
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
Originally Posted by FrsDuke View Post
Any plans on doing 93 octane specific releases? Maybe once you've completely finalized the 91 octane ones? Can you expand on what learning occurs?
You are the man!
I would also would like to know this.
cjsporl1996 is offline   Reply With Quote
Old 01-16-2014, 11:33 PM   #902
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Would fitting an aftermarket catted front pipe with high flow panel filter (to an otherwise stock car with stock tune) make it run richer or leaner?
Hence, would a 93 specific OTS tune extract more power/tq from the engine given the above mentioned (mild) mods?
Fizz is offline   Reply With Quote
Old 01-17-2014, 02:40 AM   #903
steve99
Trying to edit/view Flat foot shifting and launch control parameters in Tunepro for 1.34 or 1.42B tunes for G series ROM (BRZ Australia/European 6 MT). XDF appears to have parameters defined (can view definition) but if you select the tables Tunpro locks up (have latest version). appears no data a ROM location
I can view and edit Flat foot shifting and launch control parameters on C series 6 MT ROM's no problems.
How do I get it going on G series ROM's ????
Tried ROM Raider but appears FFS and Launch tables not defined
Thanks
Old 01-17-2014, 02:47 AM   #904
Shiv@Openflash
Drives: 2013 FRS
Thanks
If you can hang tight for the release of the new v1.50 maps, G series ROMs will have FFS and LC enabled. And they will be defined in Tuner Pro. I will also modify the XML files for Rom Raider to show them as well.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
steve99 (01-17-2014)
Old 01-17-2014, 02:49 AM   #905
steve99
I believe with these small mods the "stock " tune would be fine their would be enough "learning" capacity in the stock ECU tune to cater for these mods.
If your running OFT you would run Stage 1 tune untill you change headers.
I believe OFT Tune are done on USA 91 octane so running 93 give a bit more safety margin for knock but probably no more power unless you changed the tune to take advantage of the higher octane fuel.
The hi flowcat and filter may make a small difference in hp over a stock car guessing 5 hp
Fizz (01-17-2014)
Old 01-17-2014, 02:56 AM   #906
steve99
Magic, thanks for quick response
no problem hanging out for 1.5 tunes, my oft is still in transit
Old 01-17-2014, 03:00 AM   #907
Shiv@Openflash
Drives: 2013 FRS
Excellent Quite busy on this side of the computer with all the various updates we are doing. Seems like we spend 10x as much testing new updates before release as we do developing the update itself.
Kakawate (01-17-2014)
Old 01-17-2014, 03:10 AM   #908
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Just a quicky. I'm getting the oft soon and won't be getting my headers and front/over pipe until late February. Should I start messing around with the oft or should I just wait until I install my parts?
Thanks
Carlitoz3 is offline   Reply With Quote
The Following User Says Thank You to Carlitoz3 For This Useful Post:
Old 01-17-2014, 03:35 AM   #909
DEK186
DEK186's Avatar
Drives: 86 GT MT Velocity Orange
Hey Shiv, will you be releasing G series E85 roms with the new 1.5 revisions?
DEK186 is offline   Reply With Quote
Old 01-17-2014, 04:09 AM   #910
s2d4
s2d4's Avatar
Hope the I series get some love too.
Would really love to see iam, fbkc and flkc all working before I start loading stuff that I have played around with.
The Following User Says Thank You to s2d4 For This Useful Post:
akyp (01-18-2014)
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
