#897 | |
Drives: 2015 WRX
Just be aware that if you lower the ride height you absolutely will need some way to adjust the camber in the rear. After three alignments trying to use something other than lower control arms I wish I had just gotten them. The cost starts adding up quickly so just be sure you know what you are getting into before you make any purchases as the last thing you'll want is to have to go back and spend even more money fixing stuff that you should have done from the start. |
#898 | |
Basically 4 adjustments would be high and low piston speeds for both compression and rebound. 3 way is usually high and low for compression with 1 for rebound. This is a fun little read too: http://www.penskeshocks.com/assets/A...e%20Manual.pdf - Andy |
| The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
#899 | |
Junior
Drives: a car
I've read yes, that any substantial change in ride height (I believe it's more than 1/2-3/4 inch? Idk) requires LCAs to properly adjust camber. Another variable to add to the equasion.
#900 |
Junior
Drives: a car
I clicked on the link. My head hurts lol
#901 |
#902 | |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Lots of great information, and very good explanations (easy to read and understand), of what all the parts inside the shock are and how they work (pistons, shims, speeds, linear vs prog vs digressive, etc., etc), as well as in-depth dyno explanations. Everyone should read it, or at least skim through the tasty bits. Thanks for sharing. |
| The Following User Says Thank You to fooddude For This Useful Post: | Racecomp Engineering (03-12-2014) |
#903 |
Junior
Drives: a car
Although for a suspension noobie for me it might have been a tad heavy I was still able to decipher it's contents...I think lol I had no idea there were THAT many parts inside of a (good) coilover. No wonder some of them are so damn expensive, it takes a genius just to come up with the design :O
#904 | |
Junior
Drives: a car
If the car is front biased in terms of weight, wouldn't you want a higher spring rate in the front to omit the extra weight of the engine? And likewise in the rear wouldn't you want a softer rate than the front to help with acceleration g forces? Along those lines of logic I don't understand why so many companies offer like 4.5k up front and 5-6k in the rear..
#905 | |
i'm sorry, what?
Drives: Canada
that is not how it works... you're thinking about at a very basic level of mass being supported in space weight distribution is by and large static, you can tip the car forward/backward/side/skew using adjustable springs but there is a practical limit to this. a spring's function is multi-dimensional... i'll try to fish out a detailed explanation (since keener minds have already done this),
#906 | |
That Guy
Drives: 2013 asphalt FRS MT
Anyway, I'll just add that motion ratios play a pretty big roll in this. The front of our cars, for all intents and purposes, uses a 1:1 ratio. (Yes, ZDan, I know it's not quite 1:1 but it's close enough for this discussion. Put the dogs back in their cage, please. ) But the back of this car is much less than that so a stiffer spring is required to accomplish the same roll resistance.
#907 | |
Junior
Drives: a car
#908 | |
i'm sorry, what?
Drives: Canada
![]() what I tried to say is that lets say you have a 1000lb car with 500lb on the front wheels and 500lb on the rear wheels and 250lb/in springs on each corner if you could move the springs (ie, adjustable perches), you maintain your spring ratio but shift the weight balance around... ie... corner balancing! But there is a practical limit to this, you're not gonna be raising the front 2" while dumping the rear 2" just to get the weight to the back in a nose heavy car because that would cause way more problems than solutions. which is why you generally accept the F/R distribution for what it is and try to dial in the crossweight to be as equal as possible without upsetting the whole setup too much if weight distribution is a problem, it is generally solved by removing crap, relocating crap, or adding ballast. and more to your point, yes, the spring rates are there to achieve a desired wheel frequency for the intended application, which are impeded by suspension design and with tradeoffs being having to go stiffer to fight roll to achieve a better contact patch (not to be confused with reduction of roll!!).
#909 |
That Guy
#910 | |
That Guy
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
