Old 07-26-2013, 08:15 PM   #897
Unichip Jack
Unichip Jack's Avatar
Drives: E36 M3, Whiteout FR-S
IceFyre13th… My apologies if I miss questions…I try to hit everything every day, but sometimes I get pulled in too many directions. If I miss something that you really want an answer to, shoot me a PM since they go to my inbox as well.
We’re scheduled to put the FA20 Club intake back on the car next week and complete the maps. As soon as they’re done, we’ll get them posted.
The Flux2 “accept” graphics are a liability thing… sorry, they’re built into the firmware and they won’t go away.
The metal pin is a taper fitting, if you support one side you can use a small punch and a hammer to very lightly tap the pin to one side which will move the taper and increase the friction… if you want a more specific description than that, shoot me a PM and I’ll tell you what I mean.
Yes, we can certainly work something out for the connectors…
Mttimney… tuners really come and go, unfortunately. Nobody comes to mind as particularly current in New England but if you have a favorite shop, I’d be happy to talk with them… it’s not difficult for them to get started with Unichip tuning.
Cheers
Unichip Jack is offline   Reply With Quote
Old 07-29-2013, 04:24 PM   #898
mtimney
mtimney's Avatar
Drives: 2013 BRZ Limited
@Unichip Jack...
I was putting in a performance header and the factory had stripped the threads on the downstream O2 sensor. So, I'm without a car as they have to get the part from overseas.
Would my unichip be bothered by not having the 2nd sensor, or would it fool the ecu into thinking things were fine? It would be nice to have a car for the next four days.
mtimney is offline   Reply With Quote
Old 07-29-2013, 06:16 PM   #899
Unichip Jack
2nd O2 sensor
mtimney... thanks for the post.
The Unichip won't care, but the factory ECU will.
Cheers
Old 07-30-2013, 01:10 PM   #900
DAEMANO
Time Traveller
Unichip and the Phantom eCharger
So the Phantom eCharger is real, and it really works. Some of it's primary advantage is that it installs in < 2 hours, bolts off in < 30 minutes gives +80wtq in the dip and +30whp max. Prob is, it needs a tune to not throw a CEL in certain conditions. So far I believe the ECU has been altered with BRZedit. My question to anyone in this thread who knows Unichip (especially UnichipJack) is if Unichip is capable of resolving the issue below. If so the combination of Unichip + eCharger would make a killer combo for those looking for a DD bolt on kit that could be removed in short order and be warranty invisible. Jack, am I smoking crack here?
Originally Posted by fenton View Post
1. 80 percent throttle is 80 percent to the floor.... which is = to 100% throttle body open. So you can basically drive the car Full throttle NA and then push the throttle 10% more(past the switch) and get the supercharged power. It has never kicked in when i didnt want to it. When i want to pass someone i go WOT and it engages instantly.
2. It isnt just going wot under 3000 rpm. If you go wot in 4th to 6th gear between 3000 and 4000 the CEL will come on indicating MAP out of range or something like that. If you gun it at 1000 rpm(dont know why you would do this) it will go very rich and probably bog. In first gear you are out of that range within seconds..... even after you feather the clutch to get going you usually are at 2000 and it works just fine.
The one thing that i found was i had a crap start once and bogged it(almost stalled) and then went full thorttle to try and get up to speed and it just kind of bucked and bogged. You have to think of it this way, almost no other form of Forced induction can give 4 to 5 psi of boost(sans PD) at 1000 rpm..... there is so much load on the engine at that RPM that it pushes the ECU outside of its known fuel and load tables resulting in rich AFR.
It really isnt a problem at all, only ran into it once as i mentioned.
3. For the dyno on the stock tune we just started at 3200 rpm and it recorded the run fine. It still gets a CEL but the run produced safe AFR's and good power.
Once we tuned we were starting at about 2300 RPM and it has happy to do that all day long without throwing a code. I really recommend a tune for this product.
Hope that helps, keep the questions coming, im the Guinea pig and have had the system for over 5000km now!
Old 07-30-2013, 01:39 PM   #901
ML
ML's Avatar
Drives: 13 White MT FR-S
probably just take the unichip to a local tuner, or buy the tuning kit and tune away.
Old 07-30-2013, 03:34 PM   #902
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I'm currently running unichip and hopefully will be using it for my open source e-charger. The biggest problem is there really aren't many unichip tuners out there (None in my area I think). I'm willing to buy the tuning kit because I think in addition to tuning for the e-charger it may be able to control it's activation as well.
I'm currently educating myself on tuning basics but I'm guessing I'll need the help of an expert to really get it right.
Maybe Phantom could be convinced to send one of his e-chargers to unichip to create map for it. I know once I get my prototype built I'd be willing to lend it to a unichip tuner if it meant getting a good map.
Old 07-31-2013, 04:13 PM   #903
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
WOOHOO Sounds like we're finally getting a FA20 club tune! Hopefully the wait pays off. ^_^
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 07-31-2013, 04:23 PM   #904
Dustin2JZ
StatusLow
Dustin2JZ's Avatar
Drives: 2013 10 Series FRS
I am wandering the same thing. As I don't have tuners in my area "closest dyno is over 2 hours away.
Follow my instagram page @86_Nation
Dustin2JZ is offline   Reply With Quote
Old 07-31-2013, 06:39 PM   #905
Unichip Jack
eCharger
I sent a message to the eCharger website and we'll see what theycome back with. There's nothing extraordinary about any of the issues being discussed in terms of Unichip tuning, but there are obviously a number of things we have to understand and the best way to do that is looking at a kit.
Cheers
Old 07-31-2013, 07:05 PM   #906
husker741
Anyone install and not feel much of a difference? I'm not sure if the butt dyno isn't on point today or what, but it's not very noticeable. I'm using 92 fuel out timing in, all drop ins, all catbacks. I also have the 89 fuel in timing out for the same drop in and catbacks.
I'm using 91 octane.
husker741 is offline   Reply With Quote
Old 07-31-2013, 07:24 PM   #907
Hawk77FT
Drives: GTS 86
I was wondering which map do we need to run if I have the following:
1. Drop in Air filter with Zeta intake tube
2. Over pipe and front pipe (2.75") no cat.
Hawk77FT is offline   Reply With Quote
Old 08-01-2013, 11:00 AM   #908
Unichip Jack
Hawk77FT... PM sent.
Cheers
Old 08-02-2013, 02:15 AM   #909
ReThink
ReThink's Avatar
Drives: Sc10n FRS "DCLXIV"
Originally Posted by Unichip Jack View Post
[I]...you can use “tuning pots;” with the tuning pots “enabled” in the software, you can literally turn a knob and change the AFR as you're driving without doing a download. Once the AFR is what you want, you hit an enter button and that value is stored in the Unichip. I think that’s about as “on the fly” it gets.
Hey Jack, what are these tuning pots you speak of?
Sc10n FRS #0664
ReThink is offline   Reply With Quote
Old 08-02-2013, 03:15 AM   #910
FRSGeek
Drives: UltraMarine 6 Spd MT
@Unichip Jack
The upload/flash software is piss poor. Wouldn't take much to fix. Here is what I recall from last week using it.
It hangs and you have to kill it.
You do the settings and it does write out the file, but if you immediately go back to the settings it uses its defaults, not what was last used and last saved.
When you load it again, it doesn't use the settings in the file to populate the UI in settings.
The file dialog box drive and path letters are not localized fully. I get a "C:[]" instead of a "C:\" The box is shown here as two letters, but I am talking about one.
There is no history of files flashed, nor does the F/W store the file name if you later then download it. You shouldn't rename it by default, but point to a folder and get the name from the Unichip ROM. The file name could be compressed and would not take that much space in the F/W. It doesn't need code and can be ignore. Let the PC compress/uncompress the text.
I think there is one or two more things, but can't recall now. I'll update this when I think of them.
Regards,
Ron
'13 Ultra Marine 6MT:AVO Stg 1.5 T, Berk Tech Cat'd FP, Perrin OP & 2.5" cat back, WinMax W3F/W2R, 18x8.5et44 Rota, 245/35R18's, Drift-Office EcuTek Tune, Cusco Strt Twr & Rear brace and Grimspeed hood struts.
FRSGeek is offline   Reply With Quote
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 02:37 PM
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 03:13 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-03-2013 11:05 PM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 05:31 PM
