Old 10-23-2014, 10:40 AM   #883
arvidj
Drives: '93 MR2 Turbo
Well the call to Scion Customer Service suggests they are impotent.
They "do not have the authority to override the dealerships determination that the condition is 'normal'".
This is an interesting 'catch-22'.
After speaking with the dealership about service work, Toyota only gives them two options ... They must either resolve the issue or determine that the issue is normal. Those are the only two 'service work results' available to the dealer from Toyota.
The dealers ability to resolve the issue is limited to checking the ECU to ensure it has the most recent software and then escalating to the next level technical support line to see if any other remedies are available. It appears as though the next level technical support does not have a resolution to the problem, therefore the dealer can not resolve the issue.
Given that it is impossible for the dealer to resolve the issue the only other option they have for the 'service work result' is to call it 'normal'.
And we are then back to "Scion Customer Service" can not override the dealers determination.
In short, if the dealer says that "an documented idle that varies between 530 and 1000 RPM continuously over a 15 second interval" is normal because Toyota does not offer any remedy ... i.e. "2 + 2 = 5" ... and they have multiple instances of vehicles that exhibit this behavior ... i.e. writing "2 + 2 = 5" on the black board 1000 times ... then indeed, it is "normal" and 2 + 2 really does equal 5.
The options offered by Scion Customer Service were "take it to another dealer" ... which smacks of the 'stupidity by doing the same thing over and over and expecting a different result' paradigm ... or to look in the back of the owners manual under the "Warranty Arbitration" section.
I'm off to read that section of the manual.
Arvid
Red '93 MR2 Turbo, daily driver, 129,000 miles
Red '93 MR2 Turbo, garage queen, 24,683 miles
Red '15 FRS Automatic, TRD Springs, Swaybars, Brake Pads
arvidj is offline   Reply With Quote
Old 10-23-2014, 10:45 AM   #884
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
This may not be the best place to ask but can OFT users chime in if they still have this issue. @Shiv@Openflash
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 10-23-2014, 03:20 PM   #885
nunonuna
nunonuna's Avatar
Still does that with mine with AC on, but not as many times as before the tune. Also it seems happening more often with high ambient temperature.
nunonuna is offline   Reply With Quote
Old 12-28-2014, 01:07 PM   #886
VeezyF
Drives: Scion FR-S
funny i just got a brand new FRS a/t 2015 -- my second day i went over 100 miles. when i got back home from driving .. in park the idle rpm kept reving and dipping to where it almost stalled (with or without a/c on)
i hope they didnt put cheap gas in my new car. It had 20 miles when i picked it up. =(
VeezyF is offline   Reply With Quote
Old 01-23-2015, 04:09 AM   #887
MrPantyDroppa
MrPantyDroppa's Avatar
Drives: Crystal Silica Black
Anyone got any more info on this? My BRZ has been doing this for well over 10k miles. I'm sitting at 26k and it still happens regularly.
As someone said in a few posts up, it seems to happen more in warmer air. My car would actually die on deceleration during the summer months. I can't go to the dealer cus of the turbo :/ Increased idle speed from the tune seemed to help a bit but the problem still persists.
MrPantyDroppa is offline   Reply With Quote
Old 01-23-2015, 04:14 AM   #888
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
My engine is still stock but it went away for me after I put a drop in filter in it 3000mile down the road. The Funny thing is that it actually started doing it again when I has to reset the battery. Its like the ecu learned to drop idle again......
Old 08-12-2015, 05:45 PM   #889
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
From reading parts of this thread it sounds like something my Yaris and some other new Toyotas do supposedly for emissions purposes, ie it goes as low as it can then jumps to 1000 rpms and hunts back down.
I am surprised you couldn't use a tune and raise the idle a bit, for me in my Yaris an intake and pulleys changed things enough so that it doesn't rpm hunt any more. Maybe the other thing to try is these throttle bodies have tiny screws set into them, usually totally covered with paint if they haven't been touched, and they can vary the idle by tiny amounts so you could raise it just high enough to stop it from rpm hunting.
Old 08-13-2015, 05:41 PM   #890
P5yk0t1c
Drives: 2014 FR-S
My car used to do this all the time as well. With my OFT tune I do not have those rev dips any longer. With or without A/C on.
I used to have a 2013 had idle dip after about 100miles, took into the dealership to have it looked at, they said everything was fine....they needed to see a CEL before they would do anything. About 500 miles later, I got the CEL took it in and they cleared the code...did this about 5 times in the next month. After the last time I took her out for a rip and toasted the motor. Fought with Scion and they gave me a new 2014. Drove it for 100miles same idle dip....got an OFT, never looked back. Car runs 10x better than before.
P5yk0t1c is offline   Reply With Quote
Old 07-11-2016, 12:45 PM   #891
D5teph
Automotive Enthusiast
D5teph's Avatar
Drives: Zenki 86
Is your motor still doing that low drop idle from time to time?
D5teph is offline   Reply With Quote
Old 07-14-2016, 10:42 AM   #892
avp1
Drives: Traded BRZ for Supra
Mine was doing it for 25000 miles (and almost 3 years). Now it finally decided to raise P0017 error. Car is in dealer's shop now. They said that camshaft sprocket has to be replaced. Part is out of stock in local distribution center (NJ) and has to be ordered. It will take few days. Good thing is that dealer offer free of charge rental.
avp1 is offline   Reply With Quote
A Small Easter Egg avusblue Scion FR-S / Toyota 86 GT86 General Forum 28 06-28-2012 11:38 PM
Subaru BRZ - The biggest small car ever Laika BRZ Photos, Videos, Wallpapers, Gallery Forum 7 06-09-2012 01:21 AM
Received my FR-S with a small ding Neurytic Scion FR-S / Toyota 86 GT86 General Forum 10 06-03-2012 12:53 PM
Isn't 6-10 miles on a new car kinda high? houseofsuffering BRZ First-Gen (2012+) — General Topics 45 05-15-2012 12:32 PM
Kinda make me worry! (Radiation related thing) EJ20 Off-Topic Lounge [WARNING: NO POLITICS] 32 05-09-2011 12:58 AM
