Old 03-05-2015, 12:51 PM   #883
Diode Dynamics
Diode Dynamics's Avatar
Originally Posted by yohan04 View Post
I'm also having this exact same issue. I ordered the module pretty early (2/17), so it might be one of the few defective batches. Of course, the engine was running, parking brake disengaged and installed correctly.
I sent out an email so we can discuss what we can go from here.
Pretty bummed out since I just received it yesterday after waiting half a month.
Please reinstall the factory relay, and try turning on your DRLs.
Just as we've mentioned to the others above, this module does not affect the stock DRL function in any way, it just also sends the power to boomerangs.
If your DRLs are not coming on at all during the day as DRLs, you do not have them switched on. Thanks!
John C.
Diode Dynamics
Old 03-05-2015, 01:00 PM   #884
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
Your Order #11220484*(placed on*February 17, 2015 8:40:28 PM
When will mine be shipped out ? Thanks
ucsmfu is offline   Reply With Quote
Old 03-05-2015, 02:09 PM   #885
yohan04
yohan04's Avatar
Drives: Your sister
PM'd
yohan04 is offline   Reply With Quote
Old 03-05-2015, 03:56 PM   #886
Porcupint
Drives: 13 GBS BRZ
@Diode Dynamics
Parking brake is down assuming manual car? Or in Neutral/Drive with parking brake down in automatic.
Porcupint is offline   Reply With Quote
Old 03-05-2015, 10:37 PM   #887
00NissanNinja
The Thread Lurker
00NissanNinja's Avatar
Drives: '14 BRZ, '17 GTI, MT09
Originally Posted by tracerit View Post
The one thing that held me up was plugging the module's plug into the back of the headlight, you have to kind of angle down, then push in as if you want to plug the top side first. Think of a digging motion.
Haha glad I wasn't the only one. They seem to have used slightly different connectors than the stock connector (Or maybe subaru/toyota slightly changed it at some point?). They are the same but the little white plastic alignment piece inside the connector (or whatever you want to call it) is slightly different design. Same function just a bit different. Wonder if anyone else noticed...
00NissanNinja is offline   Reply With Quote
Old 03-06-2015, 12:59 AM   #888
livert
livert's Avatar
Just reporting that the wire swapping mod works for AU cars. Thanks for the support DD.
livert is offline   Reply With Quote
Old 03-06-2015, 10:19 AM   #889
qoncept
qoncept's Avatar
I've always wondered why anyone would ever buy galaxy blue when you can get WRB. I don't know what it is about your car but now I get it.
qoncept is offline   Reply With Quote
Old 03-06-2015, 11:34 AM   #890
Porcupint
Drives: 13 GBS BRZ
Something about GBS in certain lights that make it looks awesome. That's the reason I bought it instead of WRB.
Old 03-06-2015, 02:27 PM   #891
Abyssul
Drives: None
Currently in the talks with a representative at Diode Dynamics about my module. I installed it and watched the video multiple times. Both harnesses are installed to the headlight plugs and the relay was installed. All of my lights act as if the module wasn't installed. The jumpers are in the right spot.
Current behavior is the stock behavior. DRLs come on during the day, but not the boomerang.
Ill reply when we figure out a solution. I did notice that I couldn't change the position of the jumper to the down position because the black housing was not cut to allow enough room to push the jumper down.
Abyssul is offline   Reply With Quote
Old 03-06-2015, 03:48 PM   #892
SCHN3LL
Drives: '13 GBS BRZ
This. Plus it's the rarest color...
OFT + e85, Borla catback, header soon...
SCHN3LL is offline   Reply With Quote
Old 03-06-2015, 04:07 PM   #893
rlpaul
Drives: point A to point C. Screw point B!
I'm having the same issue. The jumper to control the DRLs is working, but not the boomerangs. So I can get the DRLs to turn on or off while headlights are on. I've moved the jumper to the off position to see if the Boomerangs come on in case its reversed on mine, but haven't had time to actually have somebody sit in the car so I can test (parked on an incline). If that doesn't work, then I'll send Diode Dynamics an email, see if they have any ideas.
rlpaul is offline   Reply With Quote
Old 03-06-2015, 05:28 PM   #894
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Yea thats your issue then. DRLs dont come on at all unless your parking break is off, which is why your boomerangs haven't come on without headlights.
EDIT: Unless you mean your boomerangs dont come on even with headlights.. then I'm wrong and nvm.
PandaSPUR is offline   Reply With Quote
Old 03-06-2015, 05:36 PM   #895
rlpaul
No, I mean boomerangs only come on with the headlights. I know the DRLs are off with the parking break on
I haven't had a chance to test it after switching the jumpers. And since I'm parked on an incline, that's why I need a second person to test. So the parking brake can be turned off.
Old 03-06-2015, 06:42 PM   #896
amaciose
amaciose's Avatar
Drives: 2013 BRZ Limited
For those that can't view the functionality due to the parking brake, here's what I ended up doing: Set up your GoPro in front facing the car and view the camera remotely through your phone. If you don't have a GoPro, you can find a way to prop up your camera facing the car and record a video.
Thankfully, mine worked perfectly out of the box!
amaciose is offline   Reply With Quote
[Closed] Gauging Interest thread pansontw Cosmetic Modification (Interior/Exterior/Lighting) 49 08-27-2014 03:14 PM
So has anyone managed to get the BRZ Boomerang/parking lights to operate as DRLs? gt8613 BRZ First-Gen (2012+) — General Topics 18 04-27-2014 02:09 AM
Gauging Interest ISC Suspension Announcements, Contests, Giveaways 17 04-03-2014 09:44 AM
Jdm headlights - gauging interest Hawk77FT Exterior Parts (Aero, Lighting, Etc.) 7 03-31-2014 09:38 AM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 10:53 AM
