Old 02-21-2014, 07:28 PM   #883
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by mike the snake View Post
No CELs, it's running the Hydra standalone, which apparently doesn't trigger any codes (as I've been told, not 1000% sure about that).
Well that sucks. Hopefully, your tuner can figure it out.
Old 02-21-2014, 07:29 PM   #884
joergasm
joergasm's Avatar
Drives: Subaru BRZ 2013 - SWP 6MT
I want to join this list of owners but I am completely noob and don't know jack about turbo's & it's parts. Tried to read the past few posts but seemed so lost. Also are there any fullblown approved installers located close to Toronto, Canada LOL
joergasm is offline   Reply With Quote
Old 02-21-2014, 07:29 PM   #885
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
i made it on Super Street Magazine lol
The Following User Says Thank You to whitefrs For This Useful Post:
mack4477 (02-23-2014)
Old 02-21-2014, 07:32 PM   #886
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Most Canadians make the drive to Minneapolis/St. Paul to see LJ @FullBlown.
The Following User Says Thank You to King Tut For This Useful Post:
Dipstik-sportech (02-21-2014)
Old 02-21-2014, 07:33 PM   #887
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Nice to see that mag is still out there. I should scan in a picture of when my 1998 Chevy Cavalier Z24 made it in reader's rides in like 2000, haha.
Old 02-21-2014, 07:34 PM   #888
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Hahahaha
I love boost!!!!!!
Old 02-22-2014, 01:01 AM   #889
Dipstik-sportech
Dipstik-sportech's Avatar
Any chance to leave my iceberg of a country lol. The guys are a lot of fun and the shop is amazing.
The Frozen North
Old 02-22-2014, 01:26 AM   #890
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Any of you guys are always welcome to come
FullBlown is offline   Reply With Quote
The Following User Says Thank You to FullBlown For This Useful Post:
Dipstik-sportech (02-23-2014)
Old 02-22-2014, 01:57 PM   #891
RickyB
Drives: Mazdaspeed 3
The Hydra will set the CEL for some things but not for an ignition miss since there are lots of effects (anti-lag, etc) that cause ignition misses on purpose.
You should have your tuner check that they are using the right dwell maps for a turbocharged application and that your AFRs are staying in the appropriate ranges. It sounds like you may be far too rich after cold start and maybe too rich when the meth kicks in which is going to also cause misses and stumbles. You may also not be getting perfect meth distribution causing some cylinder to be too rich or too lean which can also cause problems.
When going after AFR problems, datalogs are your friend.
RickyB is offline   Reply With Quote
Old 02-22-2014, 04:56 PM   #892
mike the snake
I'm going to have to learn how to take and record data logs.
The tuning part I had planned on just leaving to the tuner. This is my first "tuner" car. My last car was a BMW 135i, which I bought the Vishnu Procede tune for, and it ran perfectly for 20,000-plus miles without any probs until i sold it.
I really hope I can get my BRZ tuned to where I can just get in and drive, and not worry whether it's going to run right.
Old 02-22-2014, 05:11 PM   #893
joergasm
joergasm's Avatar
Was thinking of that, heard if I did get it that a few MN members wouldn't mind meeting up. How long of a drive is that?
Was curious as to how long it would take to install, also I am assuming when going back, mums the word to the suits.
The Following User Says Thank You to joergasm For This Useful Post:
Old 02-22-2014, 06:08 PM   #894
FullBlown
FullBlown's Avatar
Drives: Scion FRS
I can check to see how far that is. The install is about 1 to 1.5 days.
Old 02-23-2014, 11:48 PM   #895
pmccut
Drives: Blue Subarus
I just installed the SPAL fans and shrouding. How much room do you guys have between the fans and the downpipe? I can almost fit a finger. I'm about to try and wrap the downpipe which means it'll be pretty damn close. Is this too close?
Should I get the brackets for more clearance? [not my car]
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 02-24-2014, 12:48 AM   #896
mike the snake
You can gain the most clearance by relocating the lower mounting points forward up to 1.5". Relatively easy, basically just drill holes forward of the originals, and a little grinding needed to allow the radiator to move forward.
The lower radiator posts rest in/on a rubber grommet. When you move the radiator forward, you can either drill small holes for just the posts and use a rubber washer as a pad, or you can drill a larger hole and refit the whole grommet.
The lower radiator hose easily stretches to do this.
The upper mounts will give a little extra clearance, but you'll probably have to install a longer radiator hose.
The Following User Says Thank You to mike the snake For This Useful Post:
Dipstik-sportech (03-01-2014)
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 11:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 10:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 10:15 PM
