Old 08-26-2013, 01:36 AM   #883
suaveflooder
Originally Posted by forwallblakmail View Post
Don't have an OBD2 scanner. The DTC's should be stored. I'll check later.
Car runs fine. I want to point out that I ran this same track just as hard and just as many sessions this past April. It was freezing outside (upper 30's, low 40's) I had no issues during that event. Nor the event at another local track about a month later.
The only time I've experienced this CEL is during 85+ degree days.
I know its the misfire CEL I've scanned before, its happening the same way every time.
I will verify the code early this week.
I'm gonna be positive and vote you just heated up the coil packs! Glad she runs well. Do you have an oil cooler by chance?
suaveflooder is offline   Reply With Quote
The Following User Says Thank You to suaveflooder For This Useful Post:
forwallblakmail (08-26-2013)
Old 08-26-2013, 08:49 AM   #884
forwallblakmail
Troll Level: Expert
forwallblakmail's Avatar
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
I do not have an oil cooler. Im going to get one and a Koyo radiator before the next track day. (Sept 30th)
I've read about the coil packs heating too. Hopefully that's it.
Nick K.
NASA ST5/TT5 #130
Southeast Region
forwallblakmail is offline   Reply With Quote
The Following User Says Thank You to forwallblakmail For This Useful Post:
suaveflooder (08-26-2013)
Old 08-26-2013, 09:14 AM   #885
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
seems weird, I have had my oil to over 270F way more than once and no coil overheat issues, why some cars and not others?
448hpsti is offline   Reply With Quote
Old 08-26-2013, 12:25 PM   #886
forwallblakmail
Troll Level: Expert
So I'm gathering that a tune (like EcuTek) rids detonation. This is a double edged sword however because if it does not fix the issue and you lose a motor over it, the dealer can see that you had a reflash.
The battle raging in my head is epic, to say the least.
Nick K.
NASA ST5/TT5 #130
Southeast Region
CSG Mike (08-26-2013)
Old 08-26-2013, 01:05 PM   #887
thill
You can also get a tune that has the latest Toyotabru calibration that has the supposed DI seal fix. This would at least keep you with a stock tune but it would seem ridiculous to have to pay for it from a vendor...
Old 08-26-2013, 01:09 PM   #888
forwallblakmail
Troll Level: Expert
From my understanding and from what the tech at the dealer told me, thats impossible to do. I would need a new ECU. They are VIN specific. I have a May 2012 build date car. I would rather explore that option. Other than suspension my car is stock. I would like to keep it that way (tune and all)
I don't even want the oil cooler and rad, but they will happen.
*something I don't feel I made clear in my last post about my CEL on track yesturday:
All the CELs occured 4-5 laps into the session.
Nick K.
NASA ST5/TT5 #130
Southeast Region
Old 08-26-2013, 01:49 PM   #889
thill
No, you don't need a new ECU. You would just need something like this and have the tuner re-flash your ECU to the newest Subaru/Toyota calinration file that fixes the DI issue:
http://www.ecutek.com/Products/ProEC...cion_FR-S.aspx
I know of at least one tuner who has access to the stock calibration file and has sent it to customers.
The Following User Says Thank You to thill For This Useful Post:
Old 08-26-2013, 02:02 PM   #890
forwallblakmail
Troll Level: Expert
So essentially, buy Ecutek in order to get the newer calibration from Subaru? (basically breaking into Subaru's comfy suburban house when they aren't home and taking it since they wont give it up...I don't hate the idea)
I was told that the calibration is not something that can even be flashed. (or at least thats how I understood it)
So unless Subaru aknowledges this as a real problem (which they won't, ask any GR Sti owner) this is the option for 2012 build date cars?
It's going to be an expensive winter.
Nick K.
NASA ST5/TT5 #130
Southeast Region
Old 08-26-2013, 02:28 PM   #891
xjohnx
Grip>Slip
xjohnx's Avatar
It is possible. Every tuner I've dealt with (4 different ones now) have all had access to the new rom with the fix applied.
Old 08-26-2013, 02:31 PM   #892
thill
Yes. There is at least one person here that worked with fa20club to get the new est stock (01C) calibration. This is what makes it ironic. The tuner market has access to something most dealers don't and it is clearly installed on newer builds from at least February, so the whole thing is rather ridiculous..
Old 08-26-2013, 02:33 PM   #893
xjohnx
Grip>Slip
xjohnx's Avatar
Indeed. Although I don't think you'll ever get Subaru to own up to it, short of a class action suit.
Old 08-26-2013, 02:37 PM   #894
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
When it's hot I get a CEL.. But only after the session, usually pulling into my spot in the pits.. Almost always while backing into my spot.. I don't recall the CEL, but it's something about the cam timing I believe. Only other light I've had pop up is the Transmission light for over heating (auto) i do have the new ECU that was replaced back in April I think.. Otherwise no issues with the car.. When I do get the CEL it starts to idle like it would have a cam in a push rod type engine, like that lope lope type idle... Once cleared it goes back to normal
Gixxersixxerman is offline   Reply With Quote
Old 08-26-2013, 02:40 PM   #895
forwallblakmail
Troll Level: Expert
IIRC on iwsti.com there was talks of a class action suit due to the GR STi's magical ringland melting abilities. Don't think anything ever happened though.
With our cars, this problem seems to be affecting only the early build cars. The problem usually only occurs when the car is tracked, so the number of people affected is even smaller.
Subaru wont be hard pressed to do anything about it because despite the marketing of the car, they dont support competetition driving.
Basically, we're f*cked.
Nick K.
NASA ST5/TT5 #130
Southeast Region
Old 08-26-2013, 02:42 PM   #896
forwallblakmail
Troll Level: Expert
They gave you a new ECU? I'm assuming with the updated calibration, or was it for something else?
Nick K.
NASA ST5/TT5 #130
Southeast Region
We Ask Toyota & Subaru about James May's Claim that Toyota Gets 90% of GT 86/FR-S/BRZ vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 94 09-15-2013 08:55 PM
Denied service... Chen Northwest 37 09-13-2013 08:37 PM
HELP with diminished value claim! zohare Scion FR-S / Toyota 86 GT86 General Forum 41 04-03-2013 11:17 AM
Hit and Run Insurance Claim CharlieChaos Off-Topic Lounge [WARNING: NO POLITICS] 9 12-26-2012 08:54 PM
Japan loses its claim to "Creepiest Asian Country" reni Off-Topic Lounge [WARNING: NO POLITICS] 3 05-07-2012 11:57 PM
