Old 01-02-2020, 01:57 AM   #8849
LOJOKO
LOJOKO's Avatar
Drives: Subaru BRZ 2013 6AT& Honda Odyssey
Originally Posted by 86TOYO2k17 View Post
I have full headerback with no cats and its not that loud even cold starts. Not much different then stock. Can tune out the loud cold starts. Just depends on what components you choose and the tune.
I am auto trans btw.
Stock MT is 1second faster 0-60 vs auto, 90% because MT can launch at much higher RPM. But both taking off from idle at same rpm MT is only .1sec faster.
But once you are FI and become traction limited that launching benefit becomes less and less beneficial unless your on slicks on a prept track. Otherwise you just sit in place spinning.
I do plan on building my trans, valve body, clutch packs, and torque converter, i could then launch at 3k rpm but again traction is already a problem.
I do think about replacing the header this year. It's closer to Japan, Maybe TOMEI 4-2-1. I believe it will make a difference. So good with no cats.
Rear wheel drive.. Traction is inevitable. I heard people say 350P Is the max power that the auto trans can withstand. The stock manual trans is lower then AT. So the gearbox upgrade is a certainty. My AT gearbox smells like BBQ when it's speeding up at high RPM. Trans really need to upgrade.
Vehicle weight 1.2 tons. Over 270HP(I guess). Only wider tires to enhancing grip and control. CUP2 or RE11 tires. I will change MichelinPS4 in winter. But I feel it doesn't grip as much as the TOYO I used before.
May I ask if you are teaching ECU by yourself? I need to go to a professional store for this. It costs about $1,000 per visit...
2013 Subaru BRZ 6AT; Rays 57XTREME STD SPEC 18' 9.5J Wheels; TEIN FLEX Z Coilovers; Brembo OE Gold Front Brake Kit(STI); Sprintex 210 SC;GReddy GT ver.2 Exhaust; CUSCO strut bar F/R...
LOJOKO is offline   Reply With Quote
Old 01-02-2020, 02:34 AM   #8850
86TOYO2k17
Drives: 2017 toyota 86
Manual is rated at 180ft lbs torque before you need a clutch. Then 240ft lbs before gears shear. Auto is rated at 220ft lbs. ssp valve body and ssp clutch pack brings it up to 400ft lbs. Plus the valve body helps with quicker firmer shifts. Stock stall converter has a brake stall of about 2400rpm, ssp stall converter has brake stall of about 3100rpm. Transmission cooler also helps trans longevity especially with lots of extra power.
Yes traction is an issue once boosted. Point was because of that one of the main benefit of manual transmission is negated.
I am E-tuned by xero-limit. Im pretty sure you can get an E-tune from many different tuners.
Old 01-02-2020, 01:23 PM   #8851
brybot
Drives: 13 DGM BRZ 6MT
IC kit still for sale. Would love to get rid of this thing. If you're chewing on it, make me an offer.
http://www.ft86club.com/forums/showthread.php?t=137834
brybot is offline   Reply With Quote
Old 01-03-2020, 03:53 AM   #8852
LOJOKO
LOJOKO's Avatar
Yes still needs to be cooled. Breaking a limit will soon meet a new limit.
Old 01-05-2020, 09:28 AM   #8853
Kodename47
Kodename47's Avatar
Drives: UK GT86
Thats somewhat difficult to say just because we don’t have an accurate way of knowing for sure what IAT truly are post IC unless you tap a sensor into the manifold, which idk anyone that has.
It was something we developed here in the UK, sold by Abbey Motorsport so common on UK cars:
Replacement MAP sensor plate for MAP and IAT sensors.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
LOJOKO (01-06-2020)
Old 01-05-2020, 10:57 AM   #8854
86TOYO2k17
Are you Intercooled and/or E85?
What MAP sensor is that?
Did you find a maf harness that splits to IAT connector so ecu IAT reading is from that instead of maf sensor?
EDIT: Never mind thats probably the IAT sensor... But i was reading that it either A. picks up the temp of the plate and not so much the airflow so reads a false high or B. if its far enough into the air stream it will read accurate but blocks and interrupts airflow
Old 01-05-2020, 11:36 AM   #8855
tomm.brz
Drives: brz 2017 hksv2
IAT relocation is just as easy as cutting the first 2 cables of the maf and solder them to a new iat sensor, I did the same on my hks v2 sc
of course then you should use a new scale that suits better the new sensor
Old 01-05-2020, 07:36 PM   #8856
kev0
Drives: '14
So I discovered soot on the underside of my car hood. This is most likely from the leak that I cannot find. Anyone know where I should start looking? I heard something about a leaking PCV, but I have no clue where/how I should check that..
kev0 is offline   Reply With Quote
Old 01-05-2020, 07:47 PM   #8857
jflogerzi
jflogerzi's Avatar
What kind of SC oil are you using?
2013 Series 10 FRS #553
Old 01-05-2020, 08:26 PM   #8858
kev0
Drives: '14
Redline 75W90 I believe. It's Redline 75W?? for sure.
Not sure if the SC oil is making it black... it might be something with my PCV hose or exhaust leak.. either way this is frustrating.
Old 01-05-2020, 08:33 PM   #8859
jflogerzi
jflogerzi's Avatar
I am with you. Fighting this lean condistion plus the inconsistent performance is frustrating. Keep trying. I am looking at borrowing another stock MAF, also looking at DI seals for the p0171 code along with any leaks post MAF. Also going to order a new SC gasket. If not I will probably remove the kit, sell it and stick to NA for a while with e85 and ecutek
Old 01-07-2020, 08:51 PM   #8860
kev0
Drives: '14
Originally Posted by sroby View Post
Good deal. He will fix it like it should have come from sprintex. I went back N/A and sold my unit. The gentleman I sold mine to shouldn’t have any issues what’s so ever with my unit.
The frustrating part is these mods are still not in play on any of the current sprintex platforms. Including the Jeep units. Jon tried working with Sprintex and it fell on deaf ears. He has bought out all remaining parts that were out in the field. My suspicion is he will probably start making these replacement parts as needed. I believe he is the only person in the world that has actually seems to care about Sprintex customer base even over the own damn corporation. They had a lot of good people leave. There customer service here in the states is about as good as HKS US customer service which blows. Thank goodness for Jon Bond. He will keep these units alive for a good while.
Do you remember if your unit threw any lean codes with the leak? I have the same leaks as you did but they sure as hell do not look big enough to throw my fuel trims off by 40%.
Old 01-08-2020, 11:41 AM   #8861
brybot
Update because Ichi got me before I could add a picture with my username on it. Someone buy my intercooler kit please.
https://www.ft86club.com/forums/show...49#post3288849
Old 01-10-2020, 08:54 PM   #8862
Kodename47
Kodename47's Avatar
Drives: UK GT86
IC'd, no E85 here in the UK. IAT disconnected at MAF and extended to the sensor on the plate, as you stated. Not sure if I have a picture but my tuner is experienced enough to ensure that neither A or B is an issue. It's a wire type sensor which does stick into the manifold a little but not much deeper than the recess for the plate on the runners. Reacts fast enough to be air temp, both as temps increase and decrease.
.: Stealth 86 :.
Kodename 47 DJ:
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
