12-29-2019, 08:08 PM | #8835 | |
Drives: 2015 Firestorm 08/05/15
The frustrating part is these mods are still not in play on any of the current sprintex platforms. Including the Jeep units. Jon tried working with Sprintex and it fell on deaf ears. He has bought out all remaining parts that were out in the field. My suspicion is he will probably start making these replacement parts as needed. I believe he is the only person in the world that has actually seems to care about Sprintex customer base even over the own damn corporation. They had a lot of good people leave. There customer service here in the states is about as good as HKS US customer service which blows. Thank goodness for Jon Bond. He will keep these units alive for a good while. |
12-29-2019, 10:54 PM | #8836 |
Drives: Subaru BRZ 2013 6AT& Honda Odyssey
SC pulley Ø75mm in my SC 210 kit. gas i run the 98#. I'm not sure the difference between 98# and E85. But it is the highest calss in Beijing.
2013 Subaru BRZ 6AT; Rays 57XTREME STD SPEC 18' 9.5J Wheels; TEIN FLEX Z Coilovers; Brembo OE Gold Front Brake Kit(STI); Sprintex 210 SC;GReddy GT ver.2 Exhaust; CUSCO strut bar F/R...
12-30-2019, 12:08 AM | #8837 | |
12-30-2019, 12:18 AM | #8838 | |
12-30-2019, 12:56 AM | #8839 | |
Drives: 2017 toyota 86
E85 is equivalent to 108octane usa or roughly 113ron. It allows for a lot more timing and thus more power. 75mm pulley makes about 9psi if i recall correctly. Im making about 12.5-13psi with 69mm pulley. And with wmi my octane is equivalent to roughly 98octane usa or about 103ron. Do you have header and no cats? You should still be-able to get 0-60 down to 5.6-5.9 range on 75mm+94octane. |
12-30-2019, 07:15 AM | #8840 | |
My ECU was turned by an "engineer". on the basis of the stock ECU. I'm not sure what you mean by "header and CAT". I guess it's about the ECU turning? Because there is no SC dealer here and my car is 6 years old I told the "engineer" to be conservative. I just wanted to give the stock engine(FA20 NA) a few lift originally. By the way, This SC kits in Japan, Is called CUSCO SC. They probably got the agency and put up a logo to sell it. Finally I found this forum so that I could learn more.
12-30-2019, 08:40 AM | #8841 | |
Have you changed any of the exhaust components? A good header and/or removing the cats really helps a lot with this kit (or any kit) |
01-01-2020, 02:42 AM | #8842 | |
2013 Series 10 FRS #553
01-01-2020, 02:54 AM | #8843 | |
Best wishes for the New Year.
01-01-2020, 03:04 AM | #8844 |
Which is better between EL and UEL. I sold my EL ASPEC last year.
01-01-2020, 03:11 AM | #8845 |
Typically UEL gives you the subie rumble and removes the TQ dip on NA cars. These are typically louder than EL. EL headers are normally better at the top end for track use. But 4-2-1 desgins by both JDL and ACE give you the best of both worlds. More top in power and more power under the curve compared to UELs. But EL's can really sound like shit with the wrong exhaust combinations.
RCE T2's, SPC LCAs -4/2.6 camber JDL 4-2-1 EL, FP and OP, Tuned by Zach@CSG on e85 RR Wilwood Front/Rear Sport BBK, Motul 600 Fluid ARC-8 17x9 SX2 GTs 245s/Koing 17x8 v730's 225's Last edited by jflogerzi; 01-01-2020 at 03:29 AM. |
01-01-2020, 03:21 AM | #8846 | |
01-01-2020, 11:58 AM | #8847 | |
I am auto trans btw. Stock MT is 1second faster 0-60 vs auto, 90% because MT can launch at much higher RPM. But both taking off from idle at same rpm MT is only .1sec faster. But once you are FI and become traction limited that launching benefit becomes less and less beneficial unless your on slicks on a prept track. Otherwise you just sit in place spinning. I do plan on building my trans, valve body, clutch packs, and torque converter, i could then launch at 3k rpm but again traction is already a problem. |
01-01-2020, 06:10 PM | #8848 |
Drives: '14
So the measurement of our IAT’s aren’t accurate because of the design of our kit, right? Just wondering because my readings are sometimes 40° f higher than the ambient temperature and sometimes 10° f higher, both from light driving.
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
