#855 | |
Drives:
__________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram @zeal.eightsix |
#856 | |
Drives:
@ka-titties What is your opinion on Devcon aluminum putty in general? Do you think it would hold up in this particular application? __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram @zeal.eightsix Last edited by zeal86; 07-25-2017 at 02:13 PM. |
#857 |
Drives:
Pics of Devcon Aluminum Putty applied on the inside and outside seams...
[Edit] Btw, the pictured aluminum is not the weldable type, it is 2024... Luckily I have access to some 6061 T6. 040" as well. ![]() ![]() ![]() ![]() ![]() Once dry I'll sand the Devcon to the proper contours __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram @zeal.eightsix Last edited by zeal86; 07-25-2017 at 03:52 PM. |
#858 | |
Drives: 2013 BRZ Limited 6MT
| The Following User Says Thank You to ka-titties For This Useful Post: | zeal86 (07-26-2017) |
#859 |
Drives:
Devcon sanded down...
![]() ![]() ![]() ![]() __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram @zeal.eightsix |
#860 |
Drives:
Ok... so while filing a small revision to my design the Devcon cracked and one corner opened up. Since this is only a prototype, I reinforced the corners with some angled brackets.
#861 |
Drives:
Started a third prototype... I corrected some things I figured out through trial and error and added a cut out of the throttle body shape.
#862 |
Drives:
I completed and test fit my third prototype. I just need to fill in the seams with Devcon aluminum putty then sand smooth. I will have this version painted either Beatrush gold or chrome (which will probably look more like polished aluminum) ... I will probably use this version until my final is complete then I will sell it.
Btw, 2024 aluminum is considered unweldable and the Devcon withstands heat up to around 250°F so polishing and powder coating aren't options.... that's why I'll paint these versions. My final version will be made out of 6061 T6 aluminum which is weldable.... I plan on polishing the final version. ![]() ![]() ![]() ![]() ![]() **Top hardware is temporary. Final hardware will most likely be a counter sunk hex head.** ![]() ![]() ![]() __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram @zeal.eightsix Last edited by zeal86; 07-29-2017 at 02:20 AM. |
#863 |
Drives:
Found some left over hardware from my ZSpec kit... and installed them on the ECU and back of my prototype manifold cover.
#864 |
Drives:
Picture overload....
Saturday Hangar Shoot... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram @zeal.eightsix Last edited by zeal86; 07-30-2017 at 04:06 AM. |
#865 |
Drives:
I really like these gritty pics...
__________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram @zeal.eightsix Last edited by zeal86; 07-31-2017 at 11:11 AM. |
#866 |
Drives:
Grainy as f#@% but it has substance...
#867 |
Drives:
Here is a shot of my Uras driver side sideskirt. Look closely and you'll see the Uras logo and a plane.
#868 |
Drives:
Here is a video of my third Red Intake Manifold Cover Prototype . I've decided to polish it first...if the Devcon I used to fill the gaps doesn't look good after I polish it, I'll have it painted. It will serve as my temp until I complete my final version. Afterwards I plan on selling it if anyone is interested.
The following pics in the link above are pre Devcon but illustrate the fitment of this third prototype. The temporary top hardware will change to a countersunk hex head bolt. __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram @zeal.eightsix |
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 08:52 PM |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 10:59 PM |
| Kylefrs Build Thread | kylefrs | Member's Car Journals | 14 | 01-28-2015 09:27 PM |
| Jac's BRZ build thread | Jac | Member's Car Journals | 0 | 04-30-2014 08:09 PM |
| EOJ (Not much of a Build) Thread | jonbatz01 | Member's Car Journals | 41 | 07-31-2013 08:34 PM |
