Old 03-13-2020, 01:14 PM   #855
StraightOuttaCanadaEh
Wes
Ah man that is painful to see. Glad you're okay
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
stevo_12v (03-16-2020)
Old 05-06-2020, 10:43 AM   #856
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
I think it's time to install the carbon doors and some lexan windows
stevo_12v is offline   Reply With Quote
The Following 3 Users Say Thank You to stevo_12v For This Useful Post:
Code Monkey (05-06-2020), PulsarBeeerz (05-09-2020), Thefalls (05-09-2020)
Old 06-13-2020, 12:14 AM   #857
stevo_12v
Update pics
The Following 5 Users Say Thank You to stevo_12v For This Useful Post:
alphasaur (06-13-2020), Code Monkey (12-15-2020), Irace86.2.0 (10-31-2020), Silviacrazed (06-13-2020), Thefalls (06-18-2020)
Old 06-19-2020, 05:20 AM   #858
stevo_12v
So I got some custom badges to match the plates..
The Following User Says Thank You to stevo_12v For This Useful Post:
Clipdat (10-31-2020)
Old 07-20-2020, 01:34 AM   #859
stevo_12v
While car was in the repairers with the bumper off. Decided to figure a way out to stop rocks damaging the front mount intercooler, and oil cooler situated under the wheel well.
This saves me having to cut up the factory grille, make new mounting points for the mesh, and slightly better airflow with the mesh hard up against the intercooler.
Mesh is stainless steel.
Oil cooler mesh will be flipped back facing(it's mounted front facing in the photos)
Also received my Block8Head 60mm dual guage holders
Old 10-22-2020, 07:53 AM   #860
stevo_12v
Minor update
The Following 2 Users Say Thank You to stevo_12v For This Useful Post:
HaXx (10-22-2020), Lonewolf (12-26-2020)
Old 10-27-2020, 01:44 PM   #861
stevo_12v
Block8head dual 60mm vent pod and OG 20yo + Boost Guage
Pics of the dual 60mm vent/guage pod and a super OG Apexi "EL Light" boost guage. Bought this way back in 1997.
Guage looks a little too thick though.
Old 10-30-2020, 01:34 PM   #862
stevo_12v
Mechanical Check
Had the car dropped off at the workshop where my engine build and tune were done. Told the insurance company I wanted a full mechanical and safety check of the car to be sure the exhaust system, drive shaft and maybe some other parts weren't damaged during the impact.
Exhaust had a minor leak, and also requires new hangars.
Got the workshop to put the car on the dyno, which was a very good idea since the impact had caused a fuel leak from the injectors(2 pictures below)
Some facebook updates. Was running on _old_ BP98... which was in the car since March(not over one year as stated). Ran it on the dyno @ 16 PSI, managed 405hp and 439Nm at the hubs(stock 86 runs 130hp on this dyno for reference).
As you can see the engine bay is filthy and has quite a bit of overspray.
Irace86.2.0 (10-31-2020), weederr33 (11-03-2020)
Old 10-31-2020, 04:11 AM   #863
sam69
Drives: GT 86
Very nice numbers stevo, a guy I know has recently had his built turbo dynode in Perth at 375 kw at the wheels which is around the 500 I think and could go more but as he said it's not needed
sam69 is offline   Reply With Quote
Old 11-07-2020, 03:43 PM   #864
stevo_12v
Found some pics off the workshop's social media
Old 11-14-2020, 05:58 AM   #865
stevo_12v
Old pic, lost when tinypic went down
JUN IM before and after
Lantanafrs2 (11-14-2020), RayRay88 (12-17-2020)
Old 12-15-2020, 08:18 AM   #866
stevo_12v
Got my car back at last
No engine bay pics, as it's filthy AF. It will be professionally detailed in January, along with a full ceramic coat. Was good to drive the car again.
Abflug Spiral 86 bootlid not installed due to ceramic coat. Contemplating not running it.
The Following 4 Users Say Thank You to stevo_12v For This Useful Post:
beltax90 (12-24-2020), Code Monkey (12-15-2020), Lonewolf (12-15-2020), weederr33 (12-19-2020)
Old 12-15-2020, 11:21 AM   #867
Copy
Copy's Avatar
Drives: GR Corolla CE
I think it looks so much cleaner without the spoiler. Looks good man!
IG: grcwicks
Copy is offline   Reply With Quote
The Following User Says Thank You to Copy For This Useful Post:
stevo_12v (12-15-2020)
Old 12-23-2020, 08:21 PM   #868
stevo_12v
Gave the car a quick clean
36yroldvirginscar, keyboardwarrior, trd
Dumb idea to get auto tranny? tinnyms3 BRZ First-Gen (2012+) — General Topics 85 06-22-2012 06:22 PM
After this last winter is RWD such a bad idea Nate219BRZ Great Lakes 3 03-14-2012 06:03 PM
Any Idea of U.S. Pre-Order Numbers? markemark24 Scion FR-S / Toyota 86 GT86 General Forum 1 02-21-2012 01:29 PM
I have a great idea! ftw-86 Scion FR-S / Toyota 86 GT86 General Forum 56 07-24-2011 12:14 PM
Marketing Idea for the FT-86 JDMluv Scion FR-S / Toyota 86 GT86 General Forum 21 05-02-2011 06:29 AM
