#855 |
Drives: Scion FR-S
bolts
where would I get some camber bolts, and what is a good price for them? I just dont want any rubbing if I decide to go with the +20 in the rear. Or should i just go with +30 all around? I just dont want to start developing any problems.
#856 |
Drives: STi
A lot of great looking rides in this thread.
here's a few of mine lowered on Swift Sport Springs. ![]() ![]()
#857 |
Glorious BRZ Master Race
Drives: Subaru Libird
Rolling into our local Fast Fridays:
[ame="http://www.youtube.com/watch?v=Osi-gog7ZtQ"]Fast Fridays 6/28/2013 Roll-in - YouTube[/ame]
#858 | |
Lowered Lifestyle
Drives: Scion Fr-S
Sent from my HTC One |
#859 |
Drives: Scion FR-S
Tires
Are there any specific tires that would work good with this combo? I really don't know too much about wheels so any guidance or advice you have would be great and much appreciated. I was told to watch what tires you get because of sounding too loud also.
#860 | |
What width: 8.75 or 9.75? For 18x8.75, I used this table to compare and decide (first column is stock for reference).
#861 | |
Lowered Lifestyle
Drives: Scion Fr-S
#862 |
Drives: Scion FR-S
wheel questions
I will be going with the 18 x 8.75. I'm debating on just going +20 (rear) and +35 (front). But if I am going to have rubbing issues without rolling my wells I may just go with a square setup of +35's all around. What do you think?
#863 | |
Code:
WHEEL |-- STOCK HEIGHT --| |-- LOWERED 1" --| WIDTH FRONT REAR FRONT REAR 7.0 +25 +18 +23 +13 7.5 +31 +24 +29 +19 8.0 +38 +31 +36 +26 8.5 +44 +37 +42 +32 9.0 +50 +43 +48 +38 9.5 +57 +50 +55 +45 10.0 +56 +51 WHEN LOWERED 1" YOU WILL NEED TO REDUCE THE FRONT OFFSET BY 2MM AND THE REAR OFFSET BY 5MM FOR PERFECT FLUSHNESS DECREASING THE OFFSET NUMBER PUSHES THE WHEELS OUT AND INCREASING THE OFFSET SUCKS THE WHEELS IN. Flush 8.75" wide wheel offset with 1" drop F: +45 R: +35 Flush 8.75" wide wheel offset with 1.4" drop F: +44.2 R: +33 We can use the above to calculate flushness when 8.75 wide wheels have offsets locked to either +35 or +20: 8.75" wide +35 wheel flushness with 1" drop F: +10mm (poke) R: 0mm (flush) 8.75" wide +20 wheel flushness with 1" drop F: +25mm (poke) R: +15mm (poke) 8.75" wide +35 wheel flushness with 1.4" drop F: +9.2mm (poke) R: -2mm (tuck) 8.75" wide +20 wheel flushness with 1.4" drop F: +24.2mm (poke) R: +13mm (poke) When we say "flush," I believe it is how far the rim face is relative to the outer surface of the fender. If you're concerned about rubbing, you might also want to consider the rear fender has a small lip, whereas, the front fender is rolled. So you'd want your rear wheels a little more tucked to prevent rubbing (assuming you don't roll the rear fenders) compared to the front wheels. Someone please correct me if I'm wrong.
#864 |
Drives: 13 White MT FR-S
Should be the same regardless of rim diameter?
#865 |
Drives: pinto power
rear poke on a 1" drop with 18x8.75 +20 and a federal ss595 225/40/18
#866 |
You are correct, sir. I removed wheel diameters from my post.
#867 |
Drives: '13 FR-S
wanting to buy 527's 18x8.75 +35 (front) 18x8.75 +20 (rear) color doesnt matter. going to PC. if the deals right tires too.
only place i can find them is on flebay... now i know one can get awesome deals on items there.. but id rather support a vendor or a forum reference. can anyone guide me to "that one guy?" fr-s on Tein S tech springs. Front dropped 1.22 inches (-31mm) rear dropped 1.02 inches (-26mm) looking for a mild/wild stretch could go 215 or 225 |
#868 |
Drives: Too heavy
Pm joeboxer for the wheels hookup , and then pm a member Umpadupa for the 18x8.75 +35f and +20R , I believe he run that setup... He has a whiteout and a flatblack xxr527 setup.
I'm running 17x8.25 with the stock Michelins tires with a mild stretch ... Hope that helps
| Tags |
| 17 wheels |
| Wheel Directory: ProDrive GC-012L 18x8.5 +48 | MarkMash | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 05-12-2013 03:55 PM |
| Is there a thread for 'people doing stupid things in their brand new car' thread? | Symbiont | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 36 | 02-18-2013 12:24 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
| Are there any RWYB Wheel to Wheel road races? | LexusFman | Other Vehicles & General Automotive Discussions | 1 | 11-05-2011 12:28 PM |
