Old 07-19-2019, 12:55 AM   #8569
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by kev0 View Post
Got it. Emailed Sprintex to see what they say. Not sure if they even manufacture spare parts for that. This has been a huge PITA but i'm still looking forward to the car when everything's working.. sigh
Jon bond has all the parts for it if you know how to fix it. Or he may be able to repair it if you ship to him. I believe he also has completely built ones ready to go as well.
Old 07-19-2019, 02:01 AM   #8570
kev0
Drives: '14
As far as the vacuum actuator goes, does the one from JBP differ from any other one I find with the same part number?
https://jonbondperformance.com/index...roducts_id=146
and
https://www.magnusonsuperchargers.co...-01-31-764.htm
kev0 is offline   Reply With Quote
Old 07-19-2019, 03:18 AM   #8571
86TOYO2k17
and
Not sure. They look to have same part number. Can’t tell if that mounting bracket is the same or not I’d compare it to yours. If magnus looks the same then save 50$ on that one.
Old 07-19-2019, 07:25 PM   #8572
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I had to buy a replacement vacuum actuator years ago as the plastic came loose from the metal bracket. Poor design in my opinion. I got my from Sprintex directly. A little tedious to get it on and the arm thing in the correct position.
stockysnail is offline   Reply With Quote
Old 07-19-2019, 09:50 PM   #8573
kev0
Drives: '14
What were your symptoms with the failing vacuum actuator?
Old 07-21-2019, 08:37 PM   #8574
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Anyone got tips for taking those pesky hex screws out on IC install? Considering just removing the whole damn thing
Sent from my HTC6525LVW using Tapatalk
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 07-21-2019, 08:50 PM   #8575
JDM_Import
Drives: Boosted Toyobaru
I've had my sprintex supercharger installed and pro tuned for just over 2 months and got a Check Engine Light today after turning the car on. Im still putting the same 94 octane as per the map requires. I dont know what code it is at this moment.
Has anyone experienced this before, what do you recommend doing about this?
JDM_Import is offline   Reply With Quote
Old 07-21-2019, 09:46 PM   #8576
sroby
Drives: 2015 Firestorm 08/05/15
If you are on Ecutek tune, plug in your dongle spool up the Ecutek tune file you have the ability to read the codes and clear them. Go to Ecutek website . They have great tutorials for diy,s. Google is your best friend.
sroby is offline   Reply With Quote
Old 07-21-2019, 09:48 PM   #8577
jflogerzi
jflogerzi's Avatar
Pull the code.. till you do that you don't know. Is the car running normally. FTs, AFR, temp, idles normally?
2013 Series 10 FRS #553
Old 07-21-2019, 09:56 PM   #8578
JDM_Import
I do have ECUTEK tune. I paid for licensing and the tune but I never got a dongle or cable. Was this suppose to be given to me when i bought ecutek license?
Old 07-21-2019, 10:01 PM   #8579
jflogerzi
jflogerzi's Avatar
Grab any obo2 Bluetooth adapter and get a copy of torque or the iPhone version of you have an iPhone. For 20-25$ good investment. With FI you always want to be able pull cels anytime. So your also not monitoring AFR, fuel trims, etc....
Old 07-21-2019, 11:04 PM   #8580
86TOYO2k17
Smile
I’m guessing you got an actual dyno tune by a shop and not a e-tune? Cable/Dongle is for loading e-tunes and cost extra.
If iPhone dashcommand
Old 07-21-2019, 11:08 PM   #8581
sroby
He is correct. They are extra, you can find them for around 200.00 used on the forum.
Old 07-22-2019, 12:50 AM   #8582
stockysnail
Just the tip
Something just didn't feel quite the same. It was subtle and hard to explain. I frequently look under the hood and noticed it.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
