Northern California NorCal
Old 03-03-2017, 11:35 PM   #8569
spike021
spike021's Avatar
I'm a big fan of clear bra. Done it on 4 of my cars in one form or another. On the BRZ I recommend doing entire front bumper, and headlights. I opted not to do any on the hood. the shape of the bumper is such that I feel the cost/benefit is not there to do part or all of the hood. Still, it's expensive. I took my car to one of the best shops in the bay area to get it done (they typically do very high end cars) and it was $700ish.
Here is how I would suggest you decide whether its worth it to you. Take a look at the front of your current car, which presumably does not have clear bra. If you drive it any number of miles, you will surely find a number of rock chips and other damage on the front end. Does that bother you? Do you wish the front end looked like it did when it was new, or fairly close to it? If so, then clear bra is worth it. If you're OK with rock chips and cosmetic damage, then skip it. Yes with time the film can age, turn yellow, maybe even crack and peel but that is years down the line and it is removable. I have clear bra on my 10 year old Lexus that still looks good, albeit a little yellowed but in my mind not having the front end peppered with chips was worth it. Not everyone agrees on that.
Those are very good points to consider.
I actually don't have a car right now and the BRZ will be my first, so I can't really speak from experience whether I'd appreciate the protection. Closest I can get is: up till this latest phone I've got, I've usually been the person who insists on getting a case for it. I don't know if that's really a good 1:1 argument but it kind of seems like it since it shows the kind of person I am, maybe?
Which place did you have it done at?
spike021 is offline   Reply With Quote
Old 03-03-2017, 11:37 PM   #8570
spike021
spike021's Avatar
Well, I did plan on getting back into rallyx since I'm much closer to a local event I used to frequent. Plus, a lot of my commuting is via farming roads with tons of rocks and debris, so I'm hoping it helps. I daily drove my BRZ and the front bumper was so chipped by the time I sold it 5 years later, I figured I'd give it a try. Only time will tell...
Starting to think it's worth it, at least for the front bumper.
Since it's going to be my first car and I plan to have it a long time, it seems additional protection would be a good investment.
Old 03-04-2017, 12:05 AM   #8571
PMok
Codename: Stitch
PMok's Avatar
Premier in Fremont.
www.premiermobilegroup.com
The Following User Says Thank You to PMok For This Useful Post:
spike021 (03-04-2017)
Old 03-04-2017, 03:31 AM   #8572
mkivsoopra
Premier in Fremont.
+1 for Premier. I had them do the clear bra on my Lexus in 2007 too... still looks great!
mkivsoopra is offline   Reply With Quote
Old 03-04-2017, 10:35 AM   #8573
Frisco
Frisco's Avatar
Drives: 2017 BRZ
Premier in Fremont.
I just got my car CQuartz treated by Jeff at Immaculate Reflections in Brentwood (highly recommended!). He said Premier is the best protective film shop in the Bay Area.
CJ
Frisco is offline   Reply With Quote
Old 03-04-2017, 04:26 PM   #8574
FirstWinter
Drives: Car
Originally Posted by akahenry View Post
Quick question, anyone know any Enkei Distributors that still have RPF1s in 17x9 + 35mm (5x100!!) in the F1 Silver Color remaining? I understand that the wheels are discontinued, but it'd be cool to pick up a set brand new!
You can try giving @AutoRnD a call. Rishie should be able to help you out.
FirstWinter is offline   Reply With Quote
Old 03-04-2017, 05:38 PM   #8575
spike021
spike021's Avatar
Just watched Logan. Best movie this year perhaps. Very good one.
The Following User Says Thank You to spike021 For This Useful Post:
My Key (03-05-2017)
Old 03-04-2017, 10:21 PM   #8576
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Any FR-S owners running LED DRLs instead of the halogens?
I was reminded of how bad and blinding the halogen DRLs look when a FR-S was behind me today.
Worth it getting LEDs for these? Should I just disable DRL via techstream? Maybe it's good that the halogens are blinding so people notice me? Thoughts?
Originally Posted by humfrz
I'm old and lazy
Old 03-05-2017, 01:44 AM   #8577
Kaotic Lazagna
Drives: GR Corolla
From what I've read, LED bulbs in the DRL positions will either lose high beam capabilities, or will just run at basically full power (so basically high beams).
Old 03-05-2017, 01:45 AM   #8578
Kaotic Lazagna
Drives: GR Corolla
Passed this on the way home from work tonight in the Yaris
Old 03-05-2017, 01:50 AM   #8579
Kaotic Lazagna
Drives: GR Corolla
Also got my Noco G3500 battery charger in the mail. Nice packaged and the build quality feels and looks good. I'll plug in the FR-S Monday night to charge the battery to full.
Anyone know how to use the battery repair mode? When I charged the battery the last time, it never went past 95%.
Old 03-05-2017, 03:22 PM   #8580
MyRx
MyRx's Avatar
There's always a parasitic draw - small amounts that keep your clock, radio memory, computer, alarm, etc "ON". Unplug the battery and you may see above 95%.
As for battery repair mode (aka re-balancing), it's a hit or miss TBH. Some batteries don't take a lot to actually damage the cell(s) and become unrepairable. Batteries are consumables. Nonetheless, read your manual how to use the repair mode. Typically tho, charge the battery THEN repair it.
Good luck
The Following User Says Thank You to MyRx For This Useful Post:
Kaotic Lazagna (03-05-2017)
Old 03-05-2017, 06:13 PM   #8581
Kaotic Lazagna
Drives: GR Corolla
Good luck
Ah, didn't think about that.
The part that confused me in the repair mode instructions was to unplug the battery. Figured out they probably meant remove the battery from the car after fully charging it to use the repair mode.
I'll probably forgo repair mode and just charge it up once a week.
Thanks for the info.
Old 03-05-2017, 06:34 PM   #8582
Clipdat
Proud of BOXER
Clipdat's Avatar
Yay wind storms and outdoor parking :/
I'm old and lazy
BigFatFlip (03-06-2017)
*Chat* Vancouver FR-S/BRZ Members Mumbo Jumbo Thread peazs CANADA 1397 06-28-2019 12:17 PM
NorCal (Bay Area) AutoX Thread! BlaineWasHere Northern California 1398 02-08-2019 01:27 PM
Mid-Atlantic Chat Thread clevrname Mid-Atlantic 5296 08-25-2016 01:30 PM
FS: Five Axis Five:AD Aero Kit w/ Rear spoiler Whiteout - NorCal Bay Area firebert Exterior Parts (Aero, Lighting, Etc.) 13 01-08-2013 11:07 PM
NorCal Bay Area ecutek tuning AsphaltLover Southern California 0 11-11-2012 12:38 AM
