Old 12-22-2018, 04:17 PM   #841
NV89
NV89's Avatar
Drives: 14 BRZ, Genesis coupe track, 05 sti
Originally Posted by weederr33 View Post
You're in Texas? I haven't seen anyone around here with the HKS supercharger
Yeah I'm in San Antonio. I need friends lol, so hit me up peeps if near by.
Sent from my Pixel 3 using Tapatalk
NV89 is offline   Reply With Quote
The Following User Says Thank You to NV89 For This Useful Post:
weederr33 (12-22-2018)
Old 12-22-2018, 04:18 PM   #842
NV89
NV89's Avatar
Originally Posted by PuslarBrrrz View Post
That lack of down low torque will save your piston rods my friend. Your numbers makes me want a HKS SC even more.
I will consider selling mine to you.
Old 01-02-2019, 03:44 PM   #843
killsafkat
killsafkat's Avatar
Drives: 2013 GT86
Anyone here tried putting on an aftermarket bypass valve on their kits?? just curious what the kit would sound like if the bypass valve was vented to atmosphere. :P
killsafkat is offline   Reply With Quote
Old 01-06-2019, 12:19 PM   #844
xcuz31
Drives: white frs
I recently installed hks sc and used the flash tuner tune ron 91 . Everything went smoothly. Just curious on cold start my afr is running lean for 1 minute around 15-18 bouncing around those range and i can hear the exhaust back firing . And after 1 minute it will idle and stay on 14.6. Its only on cold start it runs lean . Is this normal? Or anything i need to check
xcuz31 is offline   Reply With Quote
Old 01-06-2019, 02:33 PM   #845
tomm.brz
Drives: brz 2017 hksv2
on cold start the car is always targeting a bit leaner (around 15.44), fuel system status would be 1 (front sensor not ready/in temp yet) and is basically a lean open loop
so it s normal, when the target then goes to around 14.7, it becomes a closed loop (fuel system status 2) and the measured afr follows the target
i also guess the backfiring you think you re hearing is just a loud cold start with negative timings? maybe hks just didn t remove the loud cold start, i wouldn t worry
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
Trap63 (01-06-2019), xcuz31 (01-06-2019)
Old 01-06-2019, 02:34 PM   #846
tomm.brz
i think it s not doable the venting to atmosphere since the blow off valve on the hks sc kit is after the maf sensor, so you would cause problems to the afr
Old 01-13-2019, 03:46 PM   #847
xcuz31
Drives: white frs
This values okay idle?
Old 02-05-2019, 04:16 PM   #848
killsafkat
killsafkat's Avatar
Drives: 2013 GT86
Any one using bigger/aftermarket intercooler with their v2/v3 kits?? i live in a tropical country with summer temps crossing 40c, so thinking of getting a bigger intercooler for lowering the intake temperatures (HKS upgrade kit too expensive).
Old 02-05-2019, 10:10 PM   #849
NV89
NV89's Avatar
I'm looking to do the same.
Old 02-06-2019, 08:04 PM   #850
wbradley
Sarcastic SOB
wbradley's Avatar
I have a V1 kit with an over sized intercooler. Made it difficult to find a place for the traction fluid and oil coolers.
Old 03-07-2019, 05:38 PM   #851
ok_brz
Enthusiast/Drifter
ok_brz's Avatar
Drives: 2015 Subaru BRZ
Looking at getting my kit installed (V3) here within the next month. I will be running a fairly conservative tune due to me already beating the sh** out of my car at drift events. My setup that will change from stock are: 700cc DW injectors / Innovative o2 / NonStopTuning 19 row Oil cooler. Tuning will be done via OFT.
I will hopefully in the future be upgrading I/C size as well as running a mini electric fan set up on the traction fluid cooler.
Nice to see this thread still alive... I don't see many groups alive and talking about the kit so much when I personally feel like its one of the better kits on the market.
Does anyone have an "off the shelf" part number for a belt replacement?
(apologies for all the jumping around but one of my first posts on the forums and would rather get it all out than make a bunch of 'mini reply's')
ok_brz is offline   Reply With Quote
The Following User Says Thank You to ok_brz For This Useful Post:
zeal86 (03-07-2019)
Old 03-10-2019, 10:19 AM   #852
tomm.brz
61 pages and no one ever talked about this
Is it suggested/does this kit need to mount a PCV valve from WRX or a second 1way check valve from PCV to Intake manifold, to avoid pressurize the crank case?
Old 03-10-2019, 05:44 PM   #853
wbradley
Sarcastic SOB
wbradley's Avatar
I installed a WRX PCV valve, but tbh I really don't think it makes any difference.
Old 03-10-2019, 07:30 PM   #854
tomm.brz
Any con's to it? i mean it is always better to have it (wrx pcv or check valve) than not to have it right?
The Following User Says Thank You to tomm.brz For This Useful Post:
maicolp (04-11-2019)
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 02:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 10:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 10:37 AM
