Old 04-23-2019, 09:25 AM   #841
tomm.brz
Drives: brz 2017 hksv2
on what page is the video, i can t find it anymore?
Old 04-23-2019, 09:28 AM   #842
Originally Posted by shiumai View Post
Anyone see Scotty Car Repair's video on this subject?
5 posts up.
It will make your eyes, ears and brain bleed.
Dadhawk (04-23-2019), DandoX (04-23-2019), Icecreamtruk (04-23-2019), PWBRZ (04-23-2019), RRnold (04-23-2019), weederr33 (04-24-2019)
Old 04-23-2019, 09:32 AM   #843
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
5 posts up.
For fun read the comments in YouTube
Sent from my PH-1 using Tapatalk
ybotspawn is offline   Reply With Quote
Old 04-23-2019, 09:59 AM   #844
tomm.brz
5 posts up.
oh i made confusion then
weeks ago i saw a video of a guy working at subaru performing the recall, can't find it anymore
Old 04-23-2019, 10:40 AM   #845
bfrank1972
Drives: 2013 FR-S Argento
Hah this guy, I always feel like I need to wipe my screen down after I watch one of his videos.
bfrank1972 is offline   Reply With Quote
The Following 5 Users Say Thank You to bfrank1972 For This Useful Post:
Dadhawk (04-23-2019), DarkPira7e (04-23-2019), James Russels (04-23-2019), Tcoat (04-23-2019), weederr33 (04-24-2019)
Old 04-23-2019, 01:22 PM   #846
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
If someone had their hands in my face like that in real life, it wouldn't take long before they'd get a good hard slap.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
The Following 2 Users Say Thank You to venturaII For This Useful Post:
Dadhawk (04-23-2019), Ultramaroon (04-23-2019)
Old 04-23-2019, 02:35 PM   #847
Ultramaroon
not playing cards
Ultramaroon's Avatar
Did not click but I already know exactly how I would feel.
Old 04-23-2019, 02:49 PM   #848
You have seen it before. It is the dude with the garage that makes yours look immaculate! Also the guy that stores all his fluids on a table outside in the sun. In Texas.
Dadhawk (04-23-2019), Teseo (04-23-2019), Ultramaroon (04-23-2019)
Old 04-24-2019, 01:00 PM   #849
maslin
Benz Tech
Drives: 2017 BRZ Premium
49 documents. Nothing dated that I can find, this is the only I can't recall seeing before.
https://static.nhtsa.gov/odi/rcl/201...8V772-7068.pdf
Subaru dealers are checking and adjusting valve clearance, or should be. No idea about Toyota.
maslin is offline   Reply With Quote
Old 04-24-2019, 02:06 PM   #850
ka-t_240
I like this addition!
ka-t_240 is offline   Reply With Quote
Old 04-24-2019, 04:17 PM   #851
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
That exactly describes how I felt about my experience with my Subaru dealer/corporate about performing the recall on my car with aftermarket parts installed.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
Tcoat (04-24-2019)
Old 04-24-2019, 04:43 PM   #852
msaikhan
Drives: frs
On the manual it does say check valve clearance and adjust if need to. BUT doubt any adjusting is done. The techs at my dealer just blames every tapping sound on the direct injection.
msaikhan is offline   Reply With Quote
Old 04-24-2019, 05:42 PM   #853
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Picked up my car finally yesterday with the new engine installed. So far, other than a lot of vibration at idle which is smoothing out the more I drive it (tech said give it a week or two for the ECU to "learn"), it's running great. They overfilled the oil again, as usual... at least an inch above the "high" mark, higher than it was back when I was worried about myself doing it in another thread (or maybe this one) and drained a quart.. but I'm going to not worry about it this time.
They also filled it with "blue" coolant.. I couldnt' see it in the reservoir and thought they had neglected to top it off after the initial fill, so I went to top it off and started adding the Toyota/Scion/Lexus red stuff I keep on hand. Well, I added about a cup and blue started showing in the filler neck. Sigh. They had filled it with the blue stuff, and I couldn't see the line through the plastic even w/ a flashlight. I siphoned off about the same amount I had added, but it had mixed instantly. The red stuff I use is Zerex Asian formula. Somebody reassure me that mixing a cup of that with the blue stuff the dealership used isn't an issue. Also, somebody reassure me that the dealership didn't screw up, and that the blue coolant is the correct coolant. Searched, but there doesn't seem to be any definitive answer because most of the OAT and HOAT coolants can be pink OR blue, or yellow... I know to stay away from the orange "Dex-cool" stuff.
Probably should have started another coolant thread... nah... lol. Thanks in advance.
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
The Following User Says Thank You to MuseChaser For This Useful Post:
humfrz (04-24-2019)
Old 04-24-2019, 06:14 PM   #854
maslin
Benz Tech
Document calls for "Super Coolant SOA635041", the internet says it's blue.
Mercedes coolant was yellow/clear, then blue, now blue or pink. We've been told not to mix them if possible but it doesn't really matter.
The Following User Says Thank You to maslin For This Useful Post:
MuseChaser (04-24-2019)
brz, failure, frs, i cant even, j02, recall, so much glue
Registry Thread: Failure After J02 Recall DarkPira7e Issues | Warranty | Recalls / TSB 489 05-26-2023 03:46 PM
Is the fad threads ruining our fad threads? Andrew025 Off-Topic Lounge [WARNING: NO POLITICS] 12 10-04-2017 10:12 PM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 06:18 PM
BRZ or FRS (yes, another one of those threads) lisaaaxo FR-S / BRZ vs.... 19 04-11-2015 03:44 PM
Vs. threads.... TwinscrollGT35R FR-S / BRZ vs.... 34 05-22-2012 09:21 PM
