Old 06-18-2019, 01:46 AM   #8457
kev0
Drives: '14
Originally Posted by 86TOYO2k17 View Post
Not really, but what would be the point of supercharging if your driving like a corolla and not doing any pulls.
To help me get to highway speeds quicker!
The kit comes with everything needed. Should come with ecu relocation bracket (at least mine did) you also need to relocate the brake booster, but it comes with what you need for that as well. Essentially a straight bolt on kit, just need to grind down with a file part of the alternator.
Okay, thanks. So there's no additional harness that is only used for automatic transmissions then, right? My seller mentioned he might not have that harness but I think he meant the bracket and not a harness.
kev0 is offline   Reply With Quote
Old 06-18-2019, 01:57 AM   #8458
jflogerzi
jflogerzi's Avatar
The two biggest things is tune and proper install. Without those don't even bother..
2013 Series 10 FRS #553
Old 06-18-2019, 09:49 AM   #8459
86TOYO2k17
Drives: 2017 toyota 86
you should not need anything additional, it is the harness relocation bracket, it just shifts the harness back further away from supercharger to give it more space. I got a brand new unopened kit marketed for "manual" by retailer, but it had everything needed for auto as well. Only two differences are step 17 moving the brake booster away, i just basically flipped it around and zip tied it up. and step 24 is just adding that one flat metal ] shaped bracket.
The kit is incredibly easy and simple to install, instructions are very thorough and detailed. Just takes a bit of time, and attention to detail. Its an easy DIY, or a shop shouldn't charge you more then 8 hours.
Old 06-18-2019, 06:10 PM   #8460
sqd
sqd's Avatar
Drives: '13 SWP GT86
Agreed, the install isn't hard at all, not if you have worked on cars before anyway.
For a total newbie, I'd say get assistance from someone who is comfortable with cars and know how things work, mostly because the potential costly damage that could be done by an improper install.
A header for example, eh, just do it since the worst that could realistically happen is you have an exhaust leak. But an SC is a bigger beast, EVEN though the install is easy.
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
The Following User Says Thank You to sqd For This Useful Post:
86TOYO2k17 (06-18-2019)
Old 06-18-2019, 09:07 PM   #8461
86TOYO2k17
Agreed. I should say it’s like a 3.5/5 for a casual weekend DIYer. So idk his specific DIY history, capabilities, tools, space etc. if you’ve done full bolt ons and or a Crawford billet block its like the next level up. If you can barely change a tire, oil, or battery then maybe just pay someone 6-800$ for non IC kit to install it.
I just encourage people who have basic mechanical skill/knowledge to do it themselves not only to Save some money but also get more familiar with your car and the supercharger kit itself for future maintenance/repairs/trouble shooting etc. Plus idk how many shops I even trust to touch my car that are within driving distance.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
kev0 (06-18-2019)
Old 06-19-2019, 06:13 AM   #8462
kev0
Drives: '14
Alright, guys. I'm pulling the trigger on this kit.
Sprintex 210 non-IC with a 72.5mm pulley (will try and get a 75mm) , FF kit running E85, with a Moto-East Tune. Everything else is stock besides UEL Header.
Everything should be good assuming that the tune and installation is done right, correct? Keep in mind that I will not be tracking or racing this car. Just going to drive it like a Corolla.
The Following User Says Thank You to kev0 For This Useful Post:
ajcarson11 (06-19-2019)
Old 06-19-2019, 09:43 AM   #8463
sqd
sqd's Avatar
Yes, that shouldn't be any problem.
I personally have the non-IC 210, 72.5mm pulley 700cc injectors, full exhaust and a bigger fuel pump, a Moto East/@Xero-Limit tune. I will run purely on E85 though, but my 3rd tune is 50/50 blend of gas and E85, and the 4th is pure gasoline in case I run the tank to empty and can only find gas to fill up with.
But, those injectors and pump aren't a requirement for your use.
IG @squareddesign
Old 06-19-2019, 09:53 AM   #8464
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Kev0 is picking up my kit for a great deal ($1300) as I move onto a new platform. Happy to see him get it -- Only wish I could convince him to save the $500 in mechanic's fees -- I could help him install it!
Ironically, he is going to be running the exact same setup that I was... With most of my same parts... Maybe he is me?
ajcarson11 is offline   Reply With Quote
The Following User Says Thank You to ajcarson11 For This Useful Post:
kev0 (06-19-2019)
Old 06-20-2019, 02:59 AM   #8465
kev0
Drives: '14
Does anyone know where I could buy the 75mm and 80mm pulley? Sprintex doesn't seem to sell it on their website.
Also, does anyone know the whp numbers with the 80mm pulley?
Old 06-20-2019, 03:10 AM   #8466
jflogerzi
jflogerzi's Avatar
Most sites quote the 75mm. You will be fine with the 75mm and no IC. Only way to get them is to call sprintex and get them direct.
The Following User Says Thank You to jflogerzi For This Useful Post:
kev0 (06-20-2019)
Old 06-20-2019, 07:40 AM   #8467
kev0
Drives: '14
Would you guys prefer Delicious Tuning or Moto-East for this kit?
Also, is there anyone who is NOT running gauges? Is it super mandatory for a supercharger?
Old 06-20-2019, 05:12 PM   #8468
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Moto-East.
stockysnail is offline   Reply With Quote
The Following User Says Thank You to stockysnail For This Useful Post:
Xero-Limit (06-21-2019)
Old 06-20-2019, 05:14 PM   #8469
jflogerzi
jflogerzi's Avatar
Either is good but Moto East is what I have. No issues. Car runs great and even has a perfect idle. Also I no longer get the AC idle hunt/dip issue anymore
Old 06-20-2019, 07:45 PM   #8470
Kodename47
Kodename47's Avatar
Drives: UK GT86
I'd say gauges aren't needed for a simple SC build.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
kev0 (06-20-2019)
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
