Old 11-03-2021, 08:06 AM   #827
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
If you can, get the stage 2. The thicker pads are a huge benefit to track guys.
I run hawk DTC 60 with the stage II front and sport Rear. No cooling needed. Highly recommend this over the willwood BP series.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline
Old 11-03-2021, 11:25 AM   #828
Rafi@RR-racing
Rafi@RR-racing's Avatar
Drives: Toyota GT86
DTC 60 is an aggressive pad. It is equivalent to Wilwood BP30.
Rafi@RR-racing is offline
Old 07-21-2022, 04:00 PM   #829
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
I finally got around to installing the Carbotech 1521s.
I decided to just use my angle grinder with a 60 grit sanding flap disc to quickly sweep across the rotors as I spun them on my stool with the backrest removed. Then I used 80 grit sandpaper wrapped around a flat block of wood to add a cross hatch pattern tangential to the center drum, going in each direction. Saved me a $100 instead of getting them spun, and it really didn't look like there was much grooving that would require them to be spun. In fact, the BP10's had probably 75%+ of the material left on them, which I will keep for any future track days. Obviously, I haven't been using the brake pads that much when canyon carving, or rather, I haven't been abusing them or heating them up much.
I then took the car out to bed the brakes. I did 4 sets of medium braking from 45-15 then 8-10 sets of hard braking from 60-15. Through it all, the brakes never squealed, and after, I drove around for another half an hour with light to medium braking, and I never once heard a squeal. The wife was with me, and she was very happy.
I haven't had them long enough to know if they will ever squeal. I'll have to see after the car gets washed or after a rain or in different weather conditions, but my guess is they will be near quiet to completely quiet. Again, I haven't had them long enough to make a full review, but my initial impressions are that they don't seem to have as strong of a bite as the BP10s, nor do they feel as hard, but that could change as they wear in more fully. They seem perfect for the street and are easy to modulate, but feel sporty. I'm curious how they will hold up to street and canyon use. Overall, I am very happy thus far.
May pull the trigger on front kit soon. How did the 1521 hold up after they've worn in some? How were they for canyons? They work well now that you are turbo-K24'd?
How's dust? lol. I have white wheels and my current pads are extra dusty. My car is 99.9% street use, so I was thinking of either the stage 1 or stage 2 front kit with 1521 pads, plus some low dust ceramic pads in the rear like EBC red stuff or Hawk performance ceramic.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline
Old 07-21-2022, 04:38 PM   #830
Rafi@RR-racing
Drives: Toyota GT86
Never BED 1521
Carbotech DOES NOT recommend bedding 1521 pads. After installing these pads, the car needs to be driven like your grandma would drive for about 400 miles (and this is a direct quote!). If these pads are bedded, there is a good chance they would glaze, which would cause squealing.
Old 07-21-2022, 06:25 PM   #831
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I like them. They don’t have the bite of the BP pads, but they also only squeal for me once they get hot in the canyons, and then they quiet down once I cruise around. Less dust for sure. Pedal feel is okay minus the initial bite and immediacy they BPs had. I like them.
Irace86.2.0 is offline
Old 07-22-2022, 10:44 PM   #832
jflogerzi
jflogerzi's Avatar
1521's are street only pads. Maybe Light Auto-X but I would not to use them for harder driving. But they are always super quiet. Honestly Sport is more then enough for street only. The pads used on Sport are really thick. These pads will last a lonnngggg time
2013 Series 10 FRS #553
jflogerzi is offline
Old 01-11-2023, 11:04 AM   #833
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Vending without paying… but has good info, so instead of deleting, I’ve locked
ichitaka05 is offline
The Following 7 Users Say Thank You to ichitaka05 For This Useful Post:
bmacfrs (01-12-2023), finch1750 (01-11-2023), Jdmjunkie (01-11-2023), Pat (01-11-2023), shayangh (01-11-2023), soundman98 (01-11-2023), Takumi788 (01-12-2023)
big brake kit, competition, track
AP Racing brake systems in development track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 872 09-17-2017 08:43 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 06:53 PM
AP Racing Factory Big Brake Kit, NOT Competition Lonergt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 05:51 PM
Official street racing thread. All street racing goes here! bkblitzed Off-Topic Lounge [WARNING: NO POLITICS] 8 07-19-2013 12:31 PM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 02:32 PM
