Old 05-28-2016, 08:31 AM   #827
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by Jmonty View Post
So finally installed my Type A 350 & Front pipe picked up 30 tq in the low range an 20 tq in the mid range over my pervious header. @VitViper for the before/after dyno. Top end was about the same 336whp on my JRSC C38
What header and tune did you have previously?
Old 05-28-2016, 10:26 PM   #828
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
I had a Vitviper pro tune with a catless prototype header and front pipe from PRE in Portland
Jmonty is offline   Reply With Quote
Old 05-29-2016, 02:58 PM   #829
Calum
That Guy
Ok, how much do you think you gained with the ace over a stock header, any idea?
Old 05-29-2016, 05:34 PM   #830
Jmonty
I would say 40-60 whp, depending on the dyno, tune and fuel. Getting rid of the torque dip and picking up mid-range and low-end power was well worth it
Old 05-30-2016, 03:48 PM   #831
You just made me giggle.
Old 05-30-2016, 03:49 PM   #832
@Calum @Jmonty is on a A/350. James, I hope I made the right call with the recommendation for the header. Any thoughts on the actual feel and power delivery?
I'm curious to see what @VitViper thought of the header; he does some crazy work.
Old 05-30-2016, 05:46 PM   #833
Calum
That Guy
What kind of gain would one see with one of these headers over the c30 JRSC kit with 91 octane. I'm guessing @Jmonty is running E85...? Those gains seem a little too good to be true otherwise.
Old 05-30-2016, 05:51 PM   #834
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I'm curious how this header would perform with the Cosworth supercharger.
MS, CSCS, TSAC-F, CPT
Old 05-30-2016, 07:58 PM   #835
From an otherwise 100% stock car (header, tune, flex only)
Test notes:
- The torque dip is GONE. GONE GONE GONE. With an EL header.
- There is a gain of 10.8 lb/ft wtq, peak vs peak, on ACN 91
- There is a gain of 28.5 whp, peak vs peak, on ACN91
- There is a gain of 22 lb/ft wtq, peak vs peak, on E70 vs stock
- There is a gain of 39 whp, peak vs peak, on E70 vs stock
http://www.ft86club.com/forums/showthread.php?t=88696
Old 05-30-2016, 09:18 PM   #836
Calum
That Guy
I'm asking about the a car running the JRSC c30 carb tune setup, vs the same setup with an ACE header and appropriate tune.
Old 05-30-2016, 09:22 PM   #837
Totally realistic... the JRSC amplifies the output by 40-80% depending on the supporting mods...
The general concensus with the JRSC owners is that the Ace header really, REALLY fattens up the power band.
Remember, while the JRSC eliminates the torque dip, the dip is eliminated because the torque curve is being "tilted" counterclockwise. It's still there, but just covered up by all the gains from boost. Add the Ace header gains to this, and it becomes really, really meaty.
Come visit socal, and experience it in person on the CSG car.
Old 05-30-2016, 09:22 PM   #838
That combo hasn't happened yet, but the Edelbrock loves it.
Old 05-31-2016, 06:39 AM   #839
Calum
That Guy
I would love to, but...
Old 05-31-2016, 10:53 AM   #840
Gruppe-S vs Ace 4-2-1 A/350
Both cars are on Ethanol (E70?), JRSC, HBP. Same dyno, same tuner. CSG's BRZ overlaid onto the official JRSC HBP dyno.
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
