Old 09-25-2016, 03:06 PM   #71
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Originally Posted by denso View Post
Not bad! I decided to design my own low mount kit too but my IC piping is a bit different.
Nice work, I love custom builds! What turbo did you decide on? Any more pics?
kask2_6.0 is offline   Reply With Quote
Old 09-27-2016, 01:33 PM   #72
denso
Drives: 86
Im on a GT30. Yes I got a lot of pics - will sort them and upload them but I need to sort out a few things at my mounting - Im running an internal WG and my compressor housing is a bit "to big" so Im not happy with the position.
denso is offline   Reply With Quote
The Following User Says Thank You to denso For This Useful Post:
radroach (10-16-2016)
Old 09-27-2016, 01:53 PM   #73
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
I think this might be the sickest build around. Self built systems aren't usually so well thought out.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
The Following User Says Thank You to Luftwaffel For This Useful Post:
kask2_6.0 (09-27-2016)
Old 09-27-2016, 04:35 PM   #74
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Should have the cast part next week. For now, here is the printed version in place:
The Following User Says Thank You to kask2_6.0 For This Useful Post:
denso (09-27-2016)
Old 09-27-2016, 04:40 PM   #75
sato
sato's Avatar
Drives: Dodge Patitas
I absolutely love your work... That piece right there makes me very carhorny
The Following User Says Thank You to sato For This Useful Post:
kask2_6.0 (09-28-2016)
Old 10-10-2016, 03:17 AM   #76
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
I'm really happy with how the casting turned out. I will have to machine the gate pads from casting off (big square on the right side) when it comes back out for swaintech ceramic coating. Would like to get some miles on it first though.
Pretty tight and complicated down there.
Started it today!! Got it leak checked and logged some files at idle. So far so good.
The Following 5 Users Say Thank You to kask2_6.0 For This Useful Post:
ATL BRZ (10-10-2016), BigFatFlip (10-10-2016), DustinS (10-10-2016), Lonewolf (10-12-2016), VerusEric (10-10-2016)
Old 10-10-2016, 10:21 PM   #77
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Very nice piece. Just curious, who did your casting? Anybody local?
Old 10-11-2016, 02:00 AM   #78
Irace86
Drives: BRZ + Ducati M796
Why turbo over supercharger?
Cosworth, Edelbrock, and Jackson Racing have really good offerings and I don't think I would be disappointed with any of them. BUT.. I just really like turbos. And living in CA and having this crappy 91 it is a huge benefit to me to be able to vary boost levels depending on fuel using a flex fuel setup. This isn't possible with a SC setup.
Awesome build. I love the custom 3D parts and castings.
Just wanted to point out that there has been wastegated/bypassed supercharger systems running boost controllers; they are possible. Obviously a turbocharger system integrates a wastegate out of necessity, so adding a boost controller is easier.
Irace86 is offline   Reply With Quote
Old 10-11-2016, 11:11 PM   #79
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
It was Wisconsin Precision Casting. They were really easy to work with.
I've heard of it being done but I've never seen it. Would be interested in seeing it done on this platform though.
Old 10-11-2016, 11:12 PM   #80
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Some Ace header love..
The Following 3 Users Say Thank You to kask2_6.0 For This Useful Post:
ATL BRZ (10-12-2016), lamawithonel (10-17-2016), VerusEric (10-11-2016)
Old 10-16-2016, 12:36 PM   #81
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
I thought for sure that my turbo sat lower than the ptuning setup but after installing the aero shield it appears that is not the case at all. Mine actually sits higher!
Ptuning pic for reference:
I hit the dyno at Mann Engineering on Friday and was having issues building boost. My fault though. I had a 5 psi spring in the wastegate for the initial shakedown and the exhaust pressure would immediately blow it wide open. After all of this custom work and if the only issue I have is too weak of a wastegate spring (read: lack of confidence), I'll take it! Everything else worked perfectly
Oil cooler and radiator worked great as well. From what I hear many turbo cars have trouble with overheating on the dyno. The Velox radiator was doing its job so well I was barely staying at operating temp.
I swapped out the spring for 12 psi yesterday and things are much better. I will still need to head back to the dyno for final tuning and power numbers.
The Following 2 Users Say Thank You to kask2_6.0 For This Useful Post:
BigFatFlip (10-16-2016), VerusEric (10-16-2016)
Old 10-16-2016, 07:49 PM   #82
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Cutting up the hood latch support for the intercooler plumbing and oil cooler left the hood a little flimsy. Problem solved.
Old 10-16-2016, 10:21 PM   #83
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I really hope you either jig the entire kit and sell, sell, sell...
This is by far a peace of art. I can't wait to see the final outcome.
Huge!
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 10-22-2016, 10:47 PM   #84
johl
johl's Avatar
Drives: toyota 86
Just read through this build and it looks amazing. Really good work.
Could you please talk me through your reasons for wanting twin scroll and also equal length headers for the manifold? I mean asking as I am looking at adding a turbo to my car but would prefer not to high mount the turbo. But being a right hand drive car I can't put it low and near the gearbox like yours. Which leaves 2 options. Low mount to the front with an unequal manifold or get creative and create a spaghetti like manifold to make it equal length.
Any of your input would be greatly appreciated
johl is offline   Reply With Quote
Considering a CSP Build from my STX twin.. Scooby South Tracking / Autocross / HPDE / Drifting 9 10-17-2015 12:10 AM
Best twin build performance wise? gt8613 BRZ First-Gen (2012+) — General Topics 9 01-19-2015 08:29 PM
- 86FLY - Australian Custom Turbo Jetkit 4.0 Build + Custom Flex Fuel Dyno Tune aaronsadventures Member's Car Journals 6 12-04-2014 03:01 AM
JET86. The Australian self built, twin charged build. jet86 Member's Car Journals 85 11-15-2014 05:35 PM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
