Old 12-19-2015, 11:32 PM   #71
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Anyone here running a 3.73 with boost? I'm very intrested because I run a 18/40 on my turbo Busa which made all my gears way longer and the turbo loved it.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 12-19-2015, 11:57 PM   #72
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Yep, m85 lsd rear swap. Its worth it.
My 3rd gear tops out at 100mph @ 7500, 4th at 128. Really stretches out the time you're in the powerband, which for any turbo car is always an improvement at least in a straight line.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
The Following User Says Thank You to BRZoomTX For This Useful Post:
MrSlay (12-20-2015)
Old 12-20-2015, 07:51 AM   #73
MrSlay
Drives: Gx 460, FRS, Prius
Originally Posted by FRS Justin View Post
I guess its in the car setup on what works best. As you could see in my videos I walk away at the start. (launching at 7800 rpm) from the v8s and if I do get beat its from the top end charge at the end they pass me. I will try to post a video of a ZL1 Camaro I raced. I was at the light when he came around I thought that one was mine all the way down until 300 feet from the end.[/url]
Tire has a lot to do with that
15 FRS
12 Prius
12 ISF
15 Gx 460
My YouTube Channel
MrSlay is offline   Reply With Quote
The Following User Says Thank You to MrSlay For This Useful Post:
FRS Justin (12-20-2015)
Old 12-20-2015, 10:27 AM   #74
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
That's some good numbers for na.
The Following User Says Thank You to NyC Zn6 For This Useful Post:
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
BRZedit and boost. (also wondering BRZedit vs ECUtek with boost) NickFRS Software Tuning 43 03-10-2014 04:10 AM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
