Old 10-29-2015, 09:16 PM   #71
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by CxG View Post
If someone went with the V3 and later down the road decided to use the HKS stroker kit could they upgrade pulleys and push more boost?
We have a Flash & Go Tune that suits any forced induction kit. So if you decide to upgrade to a different pulley or add a FlexFuel Kit our tune will accomodate.
Cheers,
William Knose
Old 10-30-2015, 06:07 AM   #72
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Originally Posted by kbye View Post
It could never be a fair comparison in the first place - roots type superchargers behave differently from centrifugal superchargers. Edelbrock will give you more low end torque whereas the HKS will yield more power in the top-end.
A more fair comparison against HKS would be JRSC/Kraftwerks, and for Edelbrock it would be against Cosworth/Harrop or even Sprintex in a way.
Sure - no problem with your comments re: the different types, but the Edelbrock unit makes similar top end numbers without all the add ons - so what I'm saying is that bang for buck the HKS unit doesn't seem worth it (My opinion of course)... and you still get the torque benefits of the roots SC.
I'd like to see what the other kits do with matched header-back exhausts and all the bits HKS had on their car when providing the HP numbers etc for their tune.
Ultimately I don't really care how the SC works, just that it works reliably, safely and can put a grin on my face for less money than it's competitors
86 South Africa is offline   Reply With Quote
Old 10-30-2015, 11:24 AM   #73
CxG
Drives: Pearl White '13 ZN6
Originally Posted by kch View Post
That's a question better suited for your professional tuner and not a bunch of forum jockeys.
my bad, I'm asking if they sell other pulleys that allows for more boost than just 7psi. maybe 10 or 14. Haven't seen anything on that part so if you now i'd appreciate some info
CxG is offline   Reply With Quote
Old 10-30-2015, 12:24 PM   #74
kch
Senior Misanthrope
kch's Avatar
Didn't mean to come across as attacking you. I was just saying that bringing a stroker kit into the mix makes things more complicated.
Old 10-30-2015, 12:27 PM   #75
vividracing
vividracing's Avatar
They do indeed sell different sized pulleys to adjust boost levels.
-Seth
vividracing is offline   Reply With Quote
Old 10-30-2015, 01:20 PM   #76
CxG
all good homie, thanks for looking out
Old 10-30-2015, 01:22 PM   #77
CxG
-Seth
do you know where or do the v1 pulleys fit because those are the only ones i can find
Old 10-30-2015, 01:51 PM   #78
vividracing
I don't believe that HKS differentiates their pulleys between the V1, V2, and V3 systems. I assume they are the same fitment. And we can get them.
-Seth
Old 10-30-2015, 02:29 PM   #79
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
V1(100mm) & V3(110mm) use usual 5 bolt pulley and upgradable
there is 5 bolt adapter between supercharger & 5 bolt pulley.
V2 has 1 bolt pulley(90mm) and it's smallest pulley already. so no upgrade is needed. they put 1 bolt pulley without adapter.
1 bolt pulley is preinstalled , but 5 bolt is not
V2 supercharger unit
V3 supercharger unit
if someone want use larger pulley for v2, we need adapter
that used in V1 or V3 for 5 bolt pulley.because every pulley that HKS sells in aftermarket are 5 bolt pulley.
I don't know larger pulley will fit in v2 supercharger bracket , it has small space beside pulley.
only thing that needed for boost upgrade in V2 is just boring out air restrictor.
it's caculated impeller speed table for HKS s/c kit.
V2 V1 V3
90mm 100mm 110mm
3000 45236 40712 37011
4000 60314 54283 49348
5000 75393 67854 61685
6000 90471 81424 74022
6500 98011 88210 80191
7000 105550 94995 86359
7100 107058 96352 87593
7200 108566 97709 88826
7300 110073 99066 90060
7400 111581 100423 91294
Yobiwan is offline   Reply With Quote
Old 10-30-2015, 02:31 PM   #80
vividracing
V2 has 1 bolt pulley and it's smallest pulley already. so no upgrade is needed. they put 1 bolt pulley without adapter.
but if someone want use larger pulley for v2, we need adapter
You, sir, are on it!
-Seth
Old 11-01-2015, 09:07 AM   #81
superleggera
superleggera's Avatar
Drives: BRZ / MX5 / S4
I was really interested in this kit up until the point I read that you have to buy a full catless exhaust system when you get it with the flash editor (nowhere was this explained on the couple of vendors I saw this kit for sale at either). At any rate, my concern is that here in Mass, they seem to crack down when obd2 readiness is messed with (the car gets flagged and then you have to go to some state inspection center which they go through the entire car - http://www.massvehiclecheck.state.ma...emissions.html.
Just curious, how does the flash editor overcome the o2 readiness? I would get the full exhaust at some point, but I would prefer catted parts so I dont have to deal with state inspection hassles.
superleggera is offline   Reply With Quote
Old 11-01-2015, 10:53 AM   #82
drew_kar
drew_kar's Avatar
Drives: WRB Brz / SR S14
I had the same issue on my old Mustang that had an aftermarket FI system on it. I could not get my car inspected since it failed the readiness test. I had to contact my tuner to turn on the rear o2 sensors through a revised tune. Here in NC I think you're allowed to 1 not ready.. Maybe HKS USA could make these changes if you ship out the flash editor to them like one would if they wanted a 93 octane tune?
Sent from my Nexus 5X using Tapatalk
drew_kar is offline   Reply With Quote
Old 11-12-2015, 09:47 AM   #83
Scott@HKSUSA
Scott@HKSUSA's Avatar
Drives: 2013 FR-S, HKS V2 S/C
V3 (english) instructions attached!
File Type: pdf 12001-KT003_KT003A(E04215-A40010-00)EN.pdf (1.96 MB, 1168 views)
Scott@HKSUSA is offline   Reply With Quote
Old 11-13-2015, 12:37 PM   #84
FutureFT86
FutureFT86's Avatar
Drives: 13 Scion FR-S
Instructions are down. Can you re-upload plz?
Check out my build: Instagram @kawallito
FutureFT86 is offline   Reply With Quote
supercharger help... sosick Forced Induction 25 08-15-2013 11:02 PM
HKS GT Supercharger Evasive Motorsports Forced Induction 48 02-08-2013 06:21 PM
ETA on TRD Supercharger? frsinpa Forced Induction 18 01-11-2013 10:09 AM
supercharger? but by who? carbonBLUE Forced Induction 14 11-02-2012 10:10 PM
HKS GT Supercharger Kit BPAuto Forced Induction 18 10-27-2012 03:11 PM
