Old 06-29-2015, 02:38 PM   #71
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
So, I have been talking with CounterSpace Garage about this and we have something figured out. Let me just say, if you are serious about purchasing a set of the SPOON Rigid Collars, you will not be disappointed with the deal. I cannot say anything on the public forum but if you want more details please PM me. I am helping CounterSpace Garage with this as they have lots of other stuff going on at the moment.
As for the rust/corrosion, the Rigid Collars come with copper grease. there`s plenty of it ( I think I used maybe half of the tube) so if you do live in the area where it snows, just be generous with the lube (that`s what she said) .
mokinbird87 is offline   Reply With Quote
Old 06-29-2015, 03:01 PM   #72
mokinbird87
BOXER FR
PMs answered.
The Following User Says Thank You to mokinbird87 For This Useful Post:
noodlebaka (06-29-2015)
Old 06-29-2015, 10:18 PM   #73
BRZ FTW
Drives: 2017 Subaru BRZ
Originally Posted by mokinbird87 View Post
PMs answered.
PM sent.
BRZ FTW is offline   Reply With Quote
Old 06-30-2015, 02:17 PM   #74
mokinbird87
BOXER FR
hi guys, PMs answered. things going well. stay tuned!
Old 07-01-2015, 12:52 AM   #75
lamawithonel
Drives: 2014 Subaru BRZ Ltd.
How do these compare to the Revolution sub-frame centering bolts?
http://www.aj-racing.com/shop/produc...cat=372&page=2
*question everything*learn something*answer nothing*
lamawithonel is offline   Reply With Quote
Old 07-01-2015, 03:33 AM   #76
KoolBRZ
KoolBRZ's Avatar
Those bolts would help take up the slop in the holes, but they don't address the uneven mating surfaces between the body and the top plate of the subframe bushings as well as the support arm to body connections. These surfaces aren't planed flat nor are they perfectly parallel. The rigid collar's cone actually helps support the bolts, and prevent shearing, while the washers actually lock the mating surfaces together.
The Following User Says Thank You to KoolBRZ For This Useful Post:
civicdrivr (07-01-2015)
Old 07-01-2015, 01:25 PM   #77
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
$242?!?!?!
For what probably costs them $2.42...
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
hmong337 (08-13-2015)
Old 07-01-2015, 01:39 PM   #78
mokinbird87
BOXER FR
I`m sure the rigid collars cost like $5 to make lol... but it`s the R&D and quality we pay for right?
The Following 2 Users Say Thank You to mokinbird87 For This Useful Post:
8R6 (07-01-2015), Hyper4mance2k (07-01-2015)
Old 07-01-2015, 01:44 PM   #79
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
overpriced frs/brz parts? This is unheard of.
The Following 5 Users Say Thank You to continuecrushing For This Useful Post:
8R6 (07-01-2015), civicdrivr (07-01-2015), hmong337 (08-13-2015), Hyper4mance2k (07-01-2015), wparsons (07-06-2015)
Old 07-01-2015, 06:48 PM   #80
CSG David
CSG David's Avatar
So Spoon gave us some wrong information. The pricing was too good to be true and after sending in an order, they apologized for the mistake. Everyone participating in the GB will be contacted by @mokinbird87. Based on the new information, we believe the pricing is a little too high for what they are. If you guys are still interested in the product, then we are still capable of getting them direct from Spoon Japan, but PM us if you would like to order. Thanks again for your interest.
The Following User Says Thank You to CSG David For This Useful Post:
continuecrushing (07-01-2015)
Old 07-01-2015, 07:39 PM   #81
continuecrushing
oh I definitely didn't mean these, just frs/brz parts in general are more expensive sometimes just because we're the new platform!
Like $100 side markers and such
Old 07-01-2015, 09:28 PM   #82
KoolBRZ
KoolBRZ's Avatar
You can still use the link and coupon I posted to get both front and back sets for $360 after the 30% discount. This is before tax. I bought express shipping also for $50 more. These are one piece washers with a cone on one side. The taper has to be just right to fit inside the subframe holes, crush against the bolt, and still tighten down far enough to conform the washer to irregular mating surfaces. That cone has to be just right in order to work correctly. This is not something you can make at home, or buy in the local hardware store.
The Following 2 Users Say Thank You to KoolBRZ For This Useful Post:
juliog (07-02-2015), tonystewart (07-02-2015)
Old 07-02-2015, 12:47 AM   #83
Createddeleted
Drives: 2014 BRZ - 2004 GLI
I would be more apt to buy these if they were more than 1 time use.
Createddeleted is offline   Reply With Quote
Old 07-02-2015, 02:39 AM   #84
KoolBRZ
KoolBRZ's Avatar
I've replaced my coilovers 10 times over. Replaced the sway bars twice. Replaced the steering rack mounts with Delryn inserts. Had my wheels off so many times I've about worn through my second set of lugnuts and studs. I have yet to touch a single one of my subframe bolts with anything other than a jackstand. Unless you have an accident, why would you need to use more than once? If it's to replace bushings, just do the bushings first.
Spoon GT86? c147258 Scion FR-S / Toyota 86 GT86 General Forum 67 04-27-2016 01:31 AM
No Spoon parts for the 86... twincamRob FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 81 06-02-2015 11:37 AM
Fs: brand new pbm subframe collars Guildjs Brakes, Suspension, Chassis 3 10-16-2014 09:54 AM
T1R Differential Collars Mikepage Engine, Exhaust, Transmission 0 05-01-2014 10:18 PM
