Old 07-24-2015, 11:48 AM   #71
raven1231
Originally Posted by TurboBRZ View Post
Update - so initially the car wouldn't start due to the new MAP sensor being installed, and then after swapping it with the stock one I could get it to idle after a while of feathering the throttle, but it took some trying. This was due to the MAF being in a larger tube than the stock one and needing to be re-calibrated/tuned.
So I disconnected the MAF to put the engine into limp mode and it started right up and idles perfect... only problem is I now have two leaks sprung from this stock-replacement radiator I got. So I contacted the company to get a refund and bought a Koyo that should be here in about a week. I am ordering up some slim 12" cooling fans for the Koyo as there is hardly any space with that turbo in there.
On a side note the wastegate on this turbo kit is dumping exhaust out the dump tube at idle... whether it is connected to a vacuum line or not. I contacted CX Racing and they are reimbursing my $50 for the wastegate. I went ahead and bought a 38mm TIAL replacement with a .5bar spring.
The guy who will be tuning the car also commented on these blow off valves that came with my kit and sell by the hundreds on ebay, saying that they are prone to leaking like the wastegate. So I went ahead and ordered up a Greddy FX BOV that should be here in about 3-4 days. What started out as a pretty crappy/cheap turbo kit is now turning out to be halfway decent.
Now I gotta rip everything back apart and get this thing back together again before my rebuild inspection on the 5th... I won't be able to drive it legally until the 3rd of August when I get my temp tag.
That's what my plans were when I was considering this kit a year ago. I was going to replace the BOV and Wastegate from the start as they are the most serious issues with Chinese kits. Tial will treat you much better man!
Old 07-24-2015, 12:21 PM   #72
TurboBRZ
TurboBRZ's Avatar
Drives: 2013 BRZ Limited
Yeah this kit will have a Blitz C3 Intake filter ($99) + Greddy FV BOV ($185) + Tial wastegate ($250). Then when the turbo craps out I'll likely replace it with a turbonetics or something similar ($800). Even by that time I'll still have over a thousand less into this kit than what people are paying for most the other kits available - and by that time I'll have the highest quality components making up my kit.
The BlueBaru Turbo Rebuild: http://www.ft86club.com/forums/showthread.php?t=90382
I Rebuild BRZ's for Breakfast.
TurboBRZ is offline   Reply With Quote
The Following User Says Thank You to TurboBRZ For This Useful Post:
raven1231 (07-24-2015)
Old 07-24-2015, 12:26 PM   #73
raven1231
Yeah, I was going to go the same route but buy the kit that comes with the manifold, piping, and intercooler, then source the turbo, BOV, and wastegate. Kit should be pretty solid after you change those out though.
Old 07-24-2015, 05:04 PM   #74
TurboBRZ
TurboBRZ's Avatar
So I waited a week for the dealer to get me a BRACKET for my brake lines on the passenger side (back order part) and instead they got me a CLIP... Not sure how you can confuse the two words or when I say "It bolts on to the frame rail with a 10mm bolt" and somehow they order a part with no bolt hole... Parts people.
So rather than waiting another week for them to order in another wrong part, I said screw it - reverse engineer the damn thing and get your car back together!
So I spent about an hour today reverse engineering the brake bracket from the left side of the car and am now printing a mirror copy of it for the right side. The part is not an exact copy, but is close enough that it will fit and work properly:
The Following 2 Users Say Thank You to TurboBRZ For This Useful Post:
P3tras (07-24-2015), Sportsguy83 (07-27-2015)
Old 07-24-2015, 11:24 PM   #75
TurboBRZ
TurboBRZ's Avatar
3D Printed Brake Line Bracket for 2013 BRZ
Here are some pictures of the 3D Printed bracket being installed:
If anyone wants the print file for this just let me know.
The Following 3 Users Say Thank You to TurboBRZ For This Useful Post:
DustinS (07-28-2015), raven1231 (07-25-2015), srizzors25 (08-11-2015)
Old 07-27-2015, 07:58 AM   #76
kilohercas
Drives: Subaru BRZ (soon?)
Good skils with 3D printer. I have same exact part damaged, and will need to replace.
Regarding 2 gear.
When i was doing measurements how far each gear is, i found that second and fourth gear are only 1mm away. Is it possible that you do select 2 gear, only thinking it is 4 ?
Without metal plate that bolts on top is very hard to put into 2 gear, i would want to believe it's only that.
And don't just simply buy new gearbox, try to open it first, sometimes it is very easy fault
P.s thanks for gearbox support link, one is going my way from ebay
kilohercas is offline   Reply With Quote
Old 07-27-2015, 09:44 AM   #77
TurboBRZ
TurboBRZ's Avatar
Regarding 2 gear.
If you want the print file for it I'll send it to you, but the actual part is only about $4 or so... I just didn't want to wait for it.
I won't buy a new gearbox for a while, but at the same time I don't have the experience required to rip open a transmission and determine what is wrong with it.
It DEFINITELY won't shift into second lol. I have another BRZ 6-speed that I drive every day (will be selling it once the blue car is done) and I'm very familiar with where 2nd is as that car works fine. Whether that lock-out plate is in or out, whether the new trans mount is installed or not, 2nd gear literally feels like you're pushing against a wall.
If the Perrin rear bushing doesn't fix the problem (which I doubt it will) then I will be driving this car around for a while shifting from 1st into 3rd... Then when I have the $$$ I'll buy a new clutch and flywheel and take the trans back off to bring in to a local transmission rebuilder. They'll look at it and give me an estimate for repair, and if the cost is higher than a used trans I'll buy a used one.
Old 07-27-2015, 10:09 AM   #78
kilohercas
With no mount i was shifting to every gear, no problem, gearbox was just hanging by engine and propshaft bearing...
I just was saying, when i was doing measurements for distance between gears for my gear monitor, it was very hard to shift into 2 and not into 4, spacing is very tight. And if limiter is too far in, you will not be able to shift into 2 gear, simple test would be run the engine and check how fast wheels are turning, when without any metal plate you slipping from left side to right side into first gear slot. ( i know, i am repeating myself)
Old 07-27-2015, 01:56 PM   #79
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Heard this weekend that a CX Racing turbo bit the dust during the first boost pull.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
Kuri (07-27-2015), raven1231 (07-28-2015), WhiteFRS69 (07-28-2015)
Old 07-27-2015, 02:57 PM   #80
TurboBRZ
TurboBRZ's Avatar
I talked to the tuner who blew it up - yep it did happen. Last time I blew up a turbo though it was a Garrett - so not sure that brand has a whole lot to do with it rather than a product getting through the quality check team that wasn't up to spec. Granted I am sure more of these make it through Chinese quality control than Japanese or US - as I've worked directly with businesses in both countries.
Old 07-28-2015, 10:12 AM   #81
TurboBRZ
TurboBRZ's Avatar
Blitz C3 Filter Adapter (3D Printed)
I needed a way to adapt my new Blitz C3 filter to the 2.75" intake piping on my car, so I designed and printed out a simple filter adapter:
If anyone wants the print file please let me know! Fitment is perfect!
DustinS (07-28-2015), raven1231 (07-28-2015), srizzors25 (08-11-2015)
Old 07-28-2015, 10:26 AM   #82
raven1231
Wait so are you replacing it with a different turbo?
Old 07-28-2015, 10:28 AM   #83
TurboBRZ
TurboBRZ's Avatar
No, for now I will run the same turbo my kit came with. Someone else with a CX kit went to the same tuner (James at HRI) this past weekend and his compressor wheel exploded. I won't be able to go to him until my car is complete - and hopefully my turbo holds up lol. CX has sold hundreds if not thousands of these turbos on their ebay listings.
Old 07-28-2015, 03:05 PM   #84
Top-Secret
Drives: FRS monogram
im looking forward to seeing if this kit holds up or not. make sure when doing pulls for the tune you are filming it just incase of some huge failure for us all to see
Top-Secret is offline   Reply With Quote
The Following User Says Thank You to Top-Secret For This Useful Post:
CrispyCheddar (07-28-2015)
brz cx racing turbo, brz rebuild, brz turbo
Ultimate Racing Turbo Kit sweetfrs Forced Induction 34 12-17-2015 12:25 PM
Ultimate Racing Turbo Kit ganz954 Forced Induction 19 11-13-2014 11:34 PM
91 MR2 Turbo with KO Racing GT35R Turbo Kit Unleashed Cars for Sale/Trade 2 02-21-2013 06:18 PM
91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit Unleashed Cars for Sale/Trade 8 02-20-2013 07:26 PM
