Old 06-25-2015, 02:53 PM   #71
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
Here's a local car we did an install on the end of last summer. UEL base kit with Delicious Tuning Flash N Go. He's been back a few times to add a catch can and just recently our Oil Cooler kit.
Here's my personal work in progress...I'm just about done with the wiring harness so hopefully it will be running soon
Jesse@JDLAutodesign is offline   Reply With Quote
The Following 5 Users Say Thank You to Jesse@JDLAutodesign For This Useful Post:
kch (06-25-2015), limitedblkwrx (09-21-2015), R2RO (07-02-2015), Rybot (06-25-2015), yomny (06-25-2015)
Old 06-25-2015, 03:19 PM   #72
kch
Senior Misanthrope
kch's Avatar
Hey Jesse, quick question. I saw you have an option for the FMIC that doesn't require cutting or replacing the crash beam. Are there any downsides to that solution? I really don't want to mess with anything safety related. Thanks!
Old 06-25-2015, 03:32 PM   #73
xxscaxx
Drives: 2013 SWP BRZ
You should totallllly make me one of those turbo heat shields...just saying
Also quick question for you. Your new 3 port catch can - I have noticed with other cans that run the PCV line and CCV line to a can and eliminate the other lines that they are all VTA cans with a breather filter on them. Technically your setup is a closed system because it routes to the intake but just wondering if lets say you wanted to run a catch can with the PCV line and CCV line to it and thats it, if it would be ok to do so (without running it to the intake pipe). Then again those other cans usually eliminate the PCV valve and i'm pretty sure yours does not. I am running dual Radium cans so I have a can designated for the PCV and the other will have a line from the CCV to the catch can and then the other side to the intake pipe...but just curious.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
JDLAutoDesign (06-25-2015)
Old 06-25-2015, 03:52 PM   #74
tyrantcf
Drives: '16 WRX, CBR1000RR
Possibly dumb question: Does JDL ship all of the kits with the same waste gate pressure setting?
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 06-25-2015, 04:12 PM   #75
Jesse@JDLAutodesign
Longer piping...the cold side transitions from 2"-2.75". The 2" allows clearance for all headlights (brz, gt86, etc). 2" is a bit small on the cold side for setups looking to make 400+.
The Following User Says Thank You to Jesse@JDLAutodesign For This Useful Post:
kch (06-25-2015)
Old 06-25-2015, 04:17 PM   #76
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
I'll let them answer that, but to give you something now, i requested 7psi and they put it in there.. Not sure what the default is.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
The Following User Says Thank You to yomny For This Useful Post:
tyrantcf (06-25-2015)
Old 06-25-2015, 04:23 PM   #77
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
The wastegate comes with an assortment of springs. Its enough to make 24psi on just gate pressure alone. Your best bet would be to get with your tuner to use the spring they recommend
JDLAutoDesign is offline   Reply With Quote
The Following User Says Thank You to JDLAutoDesign For This Useful Post:
Old 06-25-2015, 04:25 PM   #78
yomny
yomny's Avatar
On a side note for those who want to replace the original intake.. don't, I've gone through two filters and they can't take the heat.. they tear, so what JDL has is your best bet, either cold air or regular shorty.
Fail#1
Fail #2
Old 06-25-2015, 06:06 PM   #79
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
Fail#1
Fail #2
Dang man. Those filters are done.
What did you mean by what JDL has? Do they have an intake pipe or something?
Rybot is offline   Reply With Quote
Old 06-25-2015, 06:45 PM   #80
kch
Senior Misanthrope
kch's Avatar
But for someone on stock internals not looking to make a ton of power, that setup would work out ok? How easy would it be to change it out for the larger piping down the road if one wanted more power?
Old 06-25-2015, 06:57 PM   #81
JDLAutoDesign
Drives: 13 FRS
Another customers car
The Following 3 Users Say Thank You to JDLAutoDesign For This Useful Post:
ft86me (09-04-2016), Kris86 (06-27-2016), Rybot (06-25-2015)
Old 06-25-2015, 07:23 PM   #82
Rybot
Rybot's Avatar
How many kits do you guys install on a monthly basis?
Old 06-25-2015, 07:43 PM   #83
xxscaxx
@JDLAutoDesign - Jesse, did you use a chasebays harness for the tuck or do the wiring yourself? Just curious. I want to tuck my bay so bad but chasebays is the only one i know of that offers a harness and they don't plan on working on the harness any time in the near future for mass production...sigh.
Old 06-25-2015, 07:57 PM   #84
JDLAutoDesign
Drives: 13 FRS
It varies. We are mainly a fabrication shop and we offer parts for a lot of platforms. Every single part we fabricate has been installed here numerous times
Rybot (06-25-2015)
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
