#71 |
Drives: Forester 2007, BRZ Limited '13
Again, don't want to be PITA, but all of you are referring to clutch pedal assembly feel, not clutch itself.
'Get another clutch' - should read, 'get tighter spring for your pedal assembly'. Or 'get different valve', either way.
I am busy. Do not disturb. http://youtu.be/I58ZSqwFlWw?hd=1
#72 |
Drives: Raven Scion FR-S MT
Okay.... I think I've managed to confuse myself. I learn new things about the car every time I drive...
I've been driving under the assumption that the clutch engages at the middle or end of the release, and my start and gear changes have been less than ideal. Tonight, while aimlessly driving around town (seems to happen a lot since I got the car...) it hit me that the clutch engages early in the release (so it seems to me), but since it requires such low revs to start it didn't register. Once I realized that, things drastically improved (well, except the pedal is still way too high for me). This car is making me feel like a shifting novice :P I've driven manuals for over 13 years. What I'm confused about is that most people have been saying it has a mid to high clutch point...? At the moment I'm thinking it's low-mid. |
#73 | |
Drives: 2013 Subaru BRZ Limited AT
#74 |
Drives: 350z Nismo, CBR1000RR
Got to drive a BRZ Limited yesterday, and even after driving around surface streets for about 15 minutes and getting used to it, I'm definitely not a fan of the clutch. The pressure is light, but not too light; it's more of the awkward engagement point that bugs me, especially when rolling out from a stop. However, it's not as bad as a lot of other newer cars I've driven, and I feel like with a little adjustment it would be quite good.
#75 |
Drives: 1982 Toyota Corolla Coupe SR5
When people say it has a mid to high clutch point that is when the master cylinder starts pushing fluid into the slave. If you take the spring off the clutch pedal that is the high point.
When you say low - mid that is when the clutch re-engages at the low point when you start releasing the pedal from the metal/floor. When the clutch pedal is all the way back up the clutch is fully engaged. With the spring reattached to the pedal that is the free play where nothing really happens. The service manual will have all the factory adjustment measurements which you can change to suit your clutch style. But too low and the clutch may not fully disengage. |
#76 | |
Seems to me that it would depend on which side the clutch fork is on. It would be harder to have a mechanical linkage setup for a LHDriver with the clutch fork on the RHS like my Corolla.
Do not know what the setup on the FRS/BRZ is? Quote:
#77 |
Back From The Dead
I was in my 4 week old 2012 Jeep Wrangler. It had just started to rain and I saw a deer down the road. No big deal, I'll just change lanes and slow down a little in case he does jump out in front of me. Well as soon as I tapped the brakes the rear end just slid out. I counter steered but it just went off road. Once your off the road at 60+ mph your brakes don't do much. About 10 feet off the road was a big tree, and I hit it head on.
You can see pics here http://www.hvfd6.org/apps/public/new...m?News_ID=1020 Bottom line is I'm lucky to be alive, I've known peole to hit softer things slower and die... |
#78 | |
Drives: Firestorm FR-S (MT)
#79 |
Boostin'
Drives: FRS-T
I thought it was heavy! My rabbit feels much better and its true that it grips high in the pedal but there might be an adjustment at the pedal like other cars
#80 |
Back From The Dead
#81 |
Have no idea. Do you suggest to run a link in BRZ\FR-s?
#82 |
Drives: Premium Red Manual
I like the clutch feeling a bit light and not so stiff. My issue as stated by some above is that a clutch shouldn't start releasing three inches from the floor board and finish releasing with your left knee (left side driver) in your throat. Its too high and too long a rake. You can adjust the clutch pedal height, but you have to do it right, see other posts, and Subaru gets flaky about you doing it because of the waranty which includes the clutch and brakes. I understand they want to be sure the clutch is fully disengaged, but several inches is too much and it takes so long to get fully engaged, that can cause slippage too. And if this car was designed "purposefully for the track" then the current clutch specs are crazy. The clutch actually has a stop to keep it from going to the floor contributing to the too high feeling. Your right and left foot should be in proper relation to each other.
#83 | |
Drives: 2011 Outlander XLS, 2013 FR-S Blue
#84 |
Drives: i walk the streets.
Anyone know how the hydraulic setup is done on this car? If it's a hydraulic thrust ("throw out") bearing it may be contributing to the "light feel" that many people seem to complain about. (Nothing to do with the engagement point.)
I swapped a 6-speed into my Golf TDI which has a hydraulic thrust bearing instead of the master/slave cylinder combo that pushes onto a fork in a lever fashion to disengage the clutch disk/pressure plate. The hydraulic bearing setup is so light compared to the "standard" hydraulic setup it feels like something is broken. It was so light compared to my stock clutch and the 6-speed clutch setup I've got is even upgraded to hold well more torque than the stock unit could handle. Same "feeling" goes for a couple other vehicles I've driven with this setup vs. the older style setup. Might contribute a bit to the "pedal" feel.
--- Deebeaux
--- Former '13 FR-S Turbo Owner |
| Clutch Delay Valve? | ashtray | Engine, Exhaust, Transmission | 72 | 11-18-2015 12:10 PM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 12:22 PM |
| Clutch/brake smell | mr2lor | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 05-24-2012 01:45 PM |
| Clutch wear? | Pakjk89 | Engine, Exhaust, Transmission | 102 | 04-12-2012 07:21 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 03:48 PM |
