Old 02-21-2015, 03:27 AM   #71
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I can't believe my friends and I never thought of this! Clearly a missed opportunity in youth, although that was a bit more than 4 years ago...
It ended up not being worth it we put them on the back tires of a manual tsx from 06ish and it ended up flat spotting the tires because we got a little to excited and it melted straight through the trays we ended up all booking it out of the school parking lot after a lookout we had ran down and told us the school called the cops. The kid ended up making up some elaborate lie that he left the ebrake on and it flat spotted him and the mechanic pulled him aside and said he knew what he had done
Old 02-21-2015, 10:15 AM   #72
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Drives: 15 BRZ
Back in my day the cafeteria trays were made of metal -- and you used to have to wrestle your peanut butter flavored sticky cube thingy from a live bear.
Old 02-21-2015, 10:55 AM   #73
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
The lunch lady?
The Following 4 Users Say Thank You to Andrew025 For This Useful Post:
FRSBRZGT86FAN (02-21-2015), HunterGreene (02-24-2015), ScoobsMcGee (02-21-2015), Ultramaroon (02-21-2015)
Old 02-21-2015, 04:02 PM   #74
FRSBRZGT86FAN
Lol ours have always been plastic all the way from elementary school up till I graduated. Plan B was to double up the lunch trays and steal 4 instead of two but we never got to it before we graduated....
Old 02-21-2015, 06:02 PM   #75
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Different steering system, but I had a similar issue several years back when I had a Mazda 3.
I was driving down the freeway and as I was about to exit an off-ramp my power steering went out. However, it wasn't as if I was driving the car without power steering - it was much more difficult. It took all my strength just to get the car to turn enough to not slam into the guard rails in the turn, ended up coming to a stop as I wouldn't have actually made it all the way through the turn. Had the issue arose seconds later while I was already on the off-ramp I probably would've wrecked. Turned the car off and back on and all was fine. A week later I got a TSB letter in the mail from Mazda regarding the issue
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 02-21-2015, 06:41 PM   #76
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Originally Posted by woode View Post
... power steering went out. However, it wasn't as if I was driving the car without power steering - it was much more difficult. It took all my strength just to get the car to turn enough to not slam into the guard rails in the turn...
Sounds terrifying.
I can think of one scenario that sort of fits the description.
IF the power steering is based on a stepper motor, and the motor is still under power but not receiving commands to rotate, the steering wheel would be extremely hard to move, since the driver would have to fight the stepper motor.
I'm not saying this is the case. I rather hope it's not, because it would seem to be a very stupid way to design power steering.
Anyone got any input on how electric power steering works in general, and on our cars in particular?
The Following User Says Thank You to Sarlacc For This Useful Post:
Ultramaroon (02-22-2015)
Old 02-22-2015, 12:42 AM   #77
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
You'll need a tray.
[ame="https://www.youtube.com/watch?v=9S_orLxj850"]You Will Need A Tray. - YouTube[/ame]
The Following User Says Thank You to themadscientist For This Useful Post:
Sarlacc (02-22-2015)
Old 02-22-2015, 12:44 AM   #78
themadscientist
Hotlink Terrorist
Almost all of my cars wind up being manual steering and it's not that hard. Then again, none of them were electric. Moving PS fluid back and forth through a hose from one side of the rack to the other is bound to be a heck of a lot easier than turning against a dead electric motor.
Old 02-22-2015, 09:42 PM   #79
Zozr
Drives: White
Your arms must be made of rubber if you can't steer a car without power steering
Zozr is offline   Reply With Quote
The Following User Says Thank You to Zozr For This Useful Post:
Teseo (02-22-2015)
Old 02-22-2015, 09:51 PM   #80
Andrew025
Andrew025's Avatar
Found photo of OP
The Following User Says Thank You to Andrew025 For This Useful Post:
Teseo (02-22-2015)
Old 02-22-2015, 10:28 PM   #81
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by Sarlacc View Post
Sounds terrifying.
Wow, you might be onto something. Seriously. I concur with your hypothesis. It is also in the realm of possibility there exists one or more failure modes that were not anticipated by the designers. Failsafe servo controls are actually quite a challenge to design. I wouldn't dare to call myself an expert but it was my bread & butter both as an intern and for several years after I graduated college.
Old 02-22-2015, 10:43 PM   #82
Ultramaroon
not playing cards
But this looks like just another issue of power steering loss, not lockup. Are you sure it wasn't just because you were surprised by it? I could see it being pretty frightening if you had never experienced P/S loss.
Old 02-23-2015, 01:16 AM   #83
woode
Boosted Member
woode's Avatar
Yes, I am positive in my case. I literally could not turn the steering wheel more than a few inches using all my strength. When the car is moving it is generally easier to turn without power steering at all.
The Following User Says Thank You to woode For This Useful Post:
Ultramaroon (02-23-2015)
Old 02-23-2015, 01:22 AM   #84
chubky
chubky's Avatar
Drives: 2014 Scion FR-S Monogram
I had power steering die on me once, I was driving a Toyota Highlander though. It sounds like your steering may have locked up instead of losing power steering. It really shouldn't be too hard if the car is in motion. The slower the car is moving, the tougher the steer would be w/o power steering.
Mine died on me while i was doing a U turn at a stop light, in a turn I planned on doing a 3 point turn already. It was a scary experience, glad nothing harmful happened
chubky is offline   Reply With Quote
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 04:41 PM
power steering ender2664 Engine, Exhaust, Transmission 32 03-21-2015 05:16 PM
Electronic Power Steering Failure tjdiz92 Issues | Warranty | Recalls / TSB 17 06-18-2014 02:34 AM
Electronic power steering Mathewgzlz Issues | Warranty | Recalls / TSB 9 01-22-2014 02:50 AM
Electric power steering madfast Scion FR-S / Toyota 86 GT86 General Forum 33 10-13-2011 11:11 AM
