View Poll Results: What is the state of your 6MT gearbox?
Butter smooth and only getting smoother 187 58.62%
Problems, grinds, synchro issues, etc... 132 41.38%
Voters: 319. You may not vote on this poll
Old 01-11-2015, 12:27 PM   #71
lp87
Drives: 2013 swp brz
Does anyone else have a scratching and whistling sound from the tranny only when cold?
lp87 is offline   Reply With Quote
Old 02-22-2015, 12:53 AM   #72
misooscar
misooscar's Avatar
Drives:
If anyone has replaced their tranny under warranty, please let me know which dealership in Bay Area, CA
misooscar is offline   Reply With Quote
The Following User Says Thank You to misooscar For This Useful Post:
akahenry (04-28-2015)
Old 02-22-2015, 12:57 AM   #73
Ultramaroon
not playing cards
Ultramaroon's Avatar
I wouldn't say scratching but I like the cold whine.
Old 02-22-2015, 12:59 AM   #74
Ultramaroon
not playing cards
4th gear syncro? Has it gotten worse?
Old 02-22-2015, 01:03 AM   #75
misooscar
misooscar's Avatar
Drives:
Same as always, just know how to avoid it on the street now, don't redline it in 3rd, but I have a trackday at Big Willow on April 12th, and it will be necessary to drive it like it like I stole it
Old 02-22-2015, 01:11 AM   #76
Ultramaroon
not playing cards
I just stumbled across the thread. Remember, it will be a brand new transmission and will take another 5000-8000 miles to break in, or one day at Big Willow.
Old 02-22-2015, 01:20 AM   #77
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
You know, ever since I bought a 96 cherokee 5 speed as a daily driver, my brz's transmission feels much better.
Whatabouteggs is offline   Reply With Quote
The Following User Says Thank You to Whatabouteggs For This Useful Post:
Ultramaroon (02-22-2015)
Old 02-22-2015, 04:41 AM   #78
Stevemachine17
Drives: SWP '14 BRZ
My BRZ grinds every now and then (once a week or so) when shifting from 3rd to 4th, it hasnt happened often enough to where I can predict it
Stevemachine17 is offline   Reply With Quote
Old 02-22-2015, 07:20 AM   #79
Entroper
Entroper's Avatar
Drives: 2019 MX-5 RF GT-S, 2002 Miata LS
The tolerances are tight with the AZ6. There is no mechanical fix for the 2nd gear crunch, the fix is your technique. Go slower when it's cold. Synthetic oils can make it a bit easier, but you have to slow yourself down. I've owned a 6-speed Miata, RX-8, and two 86 twins, all with some version of the AZ6, and all of them were tight going into 2nd when cold.
Entroper is offline   Reply With Quote
The Following User Says Thank You to Entroper For This Useful Post:
hmong337 (02-22-2015)
Old 02-22-2015, 08:59 AM   #80
ripper
ripper's Avatar
Originally Posted by cjd View Post
Super smooth except when cold where 2nd is reluctant. I like to let the car warm up before driving hard anyway so... No big deal. You've got to listen to what it's telling you, not just have your way wit it...
same same.
ripper is offline   Reply With Quote
Old 02-22-2015, 12:36 PM   #81
wootwoot
Drives: FRS
Motul gear oil made a world of difference for me.
wootwoot is offline   Reply With Quote
Old 02-23-2015, 06:13 PM   #82
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
I'm pretty hard on this gearbox so it's hard to commit to either poll but I'll share my experience. First off dump the factory gearbox fluid after break-in. I had a lot of metal (looked like mud) stuck to the magnetic drain plug. The "snick" into gear and any difficult cold shift wentry away with Red Line Lightweight shockproof (can't remember if I cut it in a 1/2 at the time). I had poor results with Motul Gear 300 on our STI race car (broke down in one one race) so I skipped right to what was proven for us. I eventually broke 4th gear at 400 whp and 325 slicks.
Now on the new box we added an oil cooler, pump, and filled with 1/2 lightweight shockproof and MT90 (I would have gone straight shockproof but there is some concern when running a pump). With the cooler the box was handling the power where it broke 4th gear before. I do get the sense that the gear teeth are stretched (sharp) as it can snick into 4th now. The interesting thing is that when I turn the pump and cooler on, it instantly stops the snick into 4th.
I'm starting to think the reason 4th breaks is due to a lack of lubrication and heat. I suspect the oil fill hole we use to pump the cooled oil back into the transmission might be pumping onto 4th gear. It's something to think about at least.
Phil Grabow
Element Tuning is offline   Reply With Quote
Old 02-23-2015, 06:56 PM   #83
orangeblue
Drives: Whiteout
My car is on it's second transmission (first replaced around 10k miles under warranty for grinding). New one still isn't 100% right. My dad's is completely different: light, easy to shift, glides right into gear. The difference is frustrating.
orangeblue is offline   Reply With Quote
Old 02-24-2015, 12:38 AM   #84
T-Steve
Drives: 2014 BRZ
I waited until warm weather arrived to see if my transmission 2nd gear crunch improved. It has.
Below about 50 F I get the second gear crunch consistently. Now that it's warm it almost never happens. I've only got 3000 miles on my '14 BRZ so I'll let it keep on breaking in.
T-Steve is offline   Reply With Quote
Transmission problems M&W_FRS Issues | Warranty | Recalls / TSB 9 11-23-2014 10:29 PM
Transmission problems ofuts Issues | Warranty | Recalls / TSB 24 10-23-2014 11:44 AM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 04:01 PM
Slow is smooth, smooth is fast B3ND3R Other Vehicles & General Automotive Discussions 43 03-21-2014 11:24 PM
Another PNW Car meet? Vote on a date and vote on what to do! NickFRS Northwest 45 01-07-2013 07:23 PM
