#71 | |
Supra Owner
Drives: 1995 Toyota Supra UK Spec
#72 |
RaggedEdge Autosports
Drives: 97 APU Supra
X2!
Red JZA80 APU Supra 800whp
White 07 Turbo Si 411whp *RIP* ![]() |
#73 | ||
Drives: RX8 S1
think before you post and stop assuming, makes you sound stupid
#74 |
Site Moderator
Drives: ichi 86 Project
iirc, subaru did say they're test driving both rwd & awd. that's why there's ppl think this car gonna have awd. i debated cuz, ppl said it's impossible to have awd in this car... almost to waste time til see the final production.
#75 |
Supra Owner
^ Once again Ichi... If you're referring to me (and others with the same opinion as me), I NEVER said it was impossible for it to be AWD. I just said it would be a stupid idea on Subaru's part... The changes that would need to be made to convert this current-RWD car to AWD would not be worth the money as it would involve changes that would modify subframes, even chassis, axles, hubs, etc.
And then after all of that, they would end up with a car that is FAR too much like the current Impreza WRX, something that would not be a wise marketing decision.
#76 |
Site Moderator
lol that debate can be talk bout it on different thread after i get back from jp. i just corrected 70NYD's statement bout they only testing rwd setup. i just remember reading bout how they're testing both setup.
#77 | |
Drives: 2012 BRZ, now track car and GRC dai
apart from the sti tune i dont see ANY EXTRA money being spent on the engine. and since sti have been doing subarus engines for years now the cost will be minimal! And anyway even if the engine in the subaru was the one worked by yamaha sti would probably get their hands on the engine sooner or later, so i dont see any extra costs |
#78 |
Drives: MR2
^ Why wouldn't Subaru then use the Toyota/Yamaha "tuned" engine in their car? From there they can give it an sti tune. It doesn't make sense for subaru and toyota to tune an engine two different ways.
#79 |
Supra Owner
Here we go again
![]() From the FT86 concept, we can see there is not enough room in front of the front axle for the engine, radiator, AC condensor, and the front bumper - to use Subaru's AWD system (Where the front axle shafts come out from the front of the transmission), the axle will need to be bought back, which will incur changes to the chassis, subframes, steering rack, etc. I thought it was to be a Subaru-inspired Boxer? Subaru may well be producing the block of the engine, but if anything it will be from Toyota directives IMO. Which will likely mean it will not be made to be AWD and will, in fact be made to go above or behind the front axle, this leaves only a Celica-GT4 style AWD system or RWD only system, however, the GT4 system will require the engine to be located higher in the chassis, which may change the hood, may change the interior, and will certainly raise the centre of gravity of the car -something Toyota seems adamant to keep low. This is, of course, only if the car is going to use something very similar to the FT86 chassis/body. Edit: nate, I completely agree... I'll say it again - this is a joint venture between Subie and Toyota, changing parts or tuning on either will cost more in R&D, and that cost will be passed onto the consumer. Which will likely again ruin the whole idea of an affordable sports coupe.
#80 |
Site Moderator
hey i didn't start is one. also one correction. there IS space in front, but cost & xmember setup, can't do it... but never know subaru CAN do it, just not cost friendly.
#81 | |
the way i see it there will be 2 versions the toyota or the subaru toyota will have the n/a yamaha worked motor and the only way a turbo will be seen is if the g-sports model is sold and subaru will have THEIR engine worked on by sti. there is no extra costs with two different engines, this is how it'd be the engines are made at subaru then the ones that are going to be put into toyotas will be shipped to yamaha missing the peices that yamaha will put into it when it gets to yamaha the engines get whatever changes put onto them and then on to toyota and into the cars, whilst the engines for the subarus will stay at subaru and be put directly into the subarus with select few in the sti versions. I personally dont see the extra cost, if anything it will be cheaper for subaru to do it this way rather than send all the engines to yamaha and wait for them to return to put them into the cars, and the toyota variants will go through this regardless if there is two different engines or not. the cars have to FEEL different when being driven thats the whole point. subaru MUST personalise the DRIVING experience to fit in with their other cars, and so too does toyota. i dont want to be driving down the road and see a subaru version of my car, regardless of the different body panels, if subarus car can do the same thing my toyota can i wont buy either car for the simple fact, the car is no longer one of a kind its got this other side that is exactly like it in the feel of the engine the way they both handle the exact same way except it has a different dress on it. its the reason why twins annoy me. why would i want something that someone else can have a duplicate of at the same time, and i know its going to be mass produced but its not the same thing, i want a toyota and not a subaru dressed as a toyota, in the end isnt that why we dont want it as a scion? because its not a scion its meant to be the successor of the AE-86 AND NOT the tc or the svx or the wrx. it has to feel like the 86 as a toyota which has that effortless feel of a free revving engine delivering performance throughout the rev range and nothing else, as a subaru it has to feel close to their cars which arent free revving which all sports versions are assisted by boost which inevitably makes it a subaru and gives it that UNIGUE FEEL. |
#82 | |
Supra Owner
Edit: I agree that they should have a different feel to them each, but I'm not sure whether it will - or won't - turn out that way, and I'm leaning towards no.... Ichi, I think we need to agree to disagree.... I don't think there is enough room to fit everything in front of that very small overhang, you think otherwise? Agreed? (I agree that Subaru could do it, but I think it would take quite major modifications, and that's not part of my argument :P )
#83 | |
Drives: RX8 S1
#84 | ||
hashiryu
Drives: Mk4 Supra
| North America to get Subaru version but not Toyota version? | Ground N Pound | BRZ First-Gen (2012+) — General Topics | 42 | 05-29-2014 01:23 AM |
| What FT-86 wheel size do you want to see on production version? | MR2fan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 121 | 08-15-2012 01:57 AM |
| Toyota FT-86 redesign rumors UNTRUE! Production version rumored to be shown at Geneva | BlackArtsViper | Scion FR-S / Toyota 86 GT86 General Forum | 113 | 06-20-2010 06:42 PM |
| FT-86 production version NOT at 2010 Geneva (yet). Photos of FT-86 concept from show. | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 132 | 03-08-2010 04:40 PM |
| No Subaru FT-86 for Australia! And currently no Subaru AWD version production plans. | Edi | BRZ First-Gen (2012+) — General Topics | 103 | 10-27-2009 03:27 PM |
