Old 09-06-2012, 11:34 PM   #71
TheProspect
TheProspect's Avatar
Drives: Hot-Lava fr-S Smoked Tail Lights
I'm confused does it delete high beams at the same time or do i get lucky and can use highbeams on back roads?!?!?
My VTec Goes BWwWwWaAAaAaAAAAAaAaHHHHH!!!!!!
TheProspect is offline   Reply With Quote
Old 09-07-2012, 12:17 AM   #72
gmookher
you all want a DRL switch, like this:
use a burned out fuse and drop a micro toggle switch and wala, DRL on off switch!
http://www.autozone.com/autozone/acc...fier=6427_0_0_
gmookher is offline   Reply With Quote
The Following User Says Thank You to gmookher For This Useful Post:
sroby (03-24-2019)
Old 09-07-2012, 12:40 AM   #73
travace
travace's Avatar
Drives: Scion FR-S
Originally Posted by Jeff Lange View Post
When every car on the road has it, you get used to it, so around here, it looks weird when you see a car without DRL, lol.
Jeff
thats the thing DRL's only stood out when it was new tech and not on every vehicle. when i got my first chevy people would flash me all the time to remind me hey you left your lights on. now that never happens.
travace is offline   Reply With Quote
Old 09-30-2012, 04:13 PM   #74
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
so this mod will let me keep high beams?
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
The Following User Says Thank You to WolfsFang For This Useful Post:
sroby (03-24-2019)
Old 10-01-2012, 09:59 PM   #75
Ishii Motors
Ishii Motors's Avatar
Drives: Scion FRS
It's not a mod, it's an actual DRL Delete. It permanently gets rid of the DRL on a FR-S. It will keep the high beams working of course.
Taking it to the dealer to turn them off, is just that: Turning them off.
This is for people that want to completely get rid of the DRL.
Ishii
Ishii Motors is offline   Reply With Quote
Old 10-02-2012, 06:59 PM   #76
WolfsFang
Scrape Master
WolfsFang's Avatar
Ishii
thanks! i was thinking how pointless the DRL's will be once i black out my headlights.
Old 10-31-2012, 02:19 AM   #77
Batman
Easy, Tiger.
Batman's Avatar
Drives: Tiguan, S4, SBC 350 Wrangler
I know this is a slightly older post, but one of my friends is a tech at toyota and turned off the DRL option through the ecu. I just noticed last night however that when I flip on my brights, all I get is the DRL yellow light, not the bright light I need. I will be asking him when he's back in town, but has anyone else had this issue?
Batman is offline   Reply With Quote
The Following User Says Thank You to Batman For This Useful Post:
Godzilla35 (08-28-2013)
Old 11-06-2012, 03:26 PM   #78
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
@Ishii Motors, I know this is a DRL delete DIY, but is there any particular reason why you went the extra step and actually removed the resistor, rather than disconnecting, taping up both ends and zip-tying them out of the way? If you ever needed to re-enable them, wouldn't it be easier?
raul is offline   Reply With Quote
Old 12-08-2012, 10:59 PM   #79
Rokkinpo
Drives: 2013 Hot lava Scion FR-S
I didn't read the whole post but I did the fuse thing first and you lose high beams or I did. so the other day I was at work and wanted to see what I could change in the computer so I through the TIS on and there is an option to turn off the DRL option. So just go to your dealership and ask them to do it most will do it for free
Rokkinpo is offline   Reply With Quote
Old 12-21-2012, 10:04 AM   #80
silvenshadow
Drives: 2013 6MT Ultramarine FRS
Note to anyone looking to perform the DRL delete.
You can see in the pics on the first post a small rectangular vented panel just next to the area of plastic this thread says to remove. If you pull gently this panel will just pop off. Depending on the size of your arm you can just put your hand in there, the drl resistor plug is immediately above the panel.
You can carefully unplug the resistor, wrap the wire around the harness and tuck the end against the frame. This took me about 1 minute, required no tools or supplies, and was totally effective.
If you look on the back of that access panel there is a nice Subaru logo (on my NA FRS).
Thanks Subaru!
silvenshadow is offline   Reply With Quote
The Following User Says Thank You to silvenshadow For This Useful Post:
greighn (04-09-2013)
Old 12-21-2012, 12:59 PM   #81
drftrdie
drftrdie's Avatar
Drives: Ae86,X2 , Scion FRS
Yes you have to get the ecu replaced from the dealer for free to correct this
drftrdie is offline   Reply With Quote
The Following User Says Thank You to drftrdie For This Useful Post:
Zagmeister (07-13-2013)
Old 12-22-2012, 09:53 PM   #82
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
thanks for the DIY. took about 20min (those plastic screws mainly) to do and was pretty straight forward. i had originally went to the dealership to have them turned off and ended up with the no hi beam issue. i know that the new ECU would fix this but i really don't want to make any more trips to the dealership so i just had them put the DRLs back on, came home and did the delete from this thread. it's reversible for the most part and doesn't require a trip to the dealership if i ever want them back.
mezdup is offline   Reply With Quote
Old 12-26-2012, 01:57 PM   #83
pituala
Mr. Know It All
Drives: 2013 FR-S Asphalt
subscribing
2013 FR-S Asphalt MT (55w HID's)
1985 Celica Supra 1JZ (Stupid Fast)
pituala is offline   Reply With Quote
Old 12-29-2012, 02:50 PM   #84
BoostedWrbBrz
Drives: 2014 Wrb Brz limited 6m
or you can plug in a techstream and click the drl off button
BoostedWrbBrz is offline   Reply With Quote
