Old 08-06-2014, 11:11 PM   #71
Hagbard
Hagbard's Avatar
Originally Posted by Walla Walla View Post
it's really better, you've worked at the right spot!
how much timing did you remove?
for the gas, if it's 94 petro can, it really have a bad reputation. it contain ethanol, and it seems to produce more knock. but, there are some debate on this...
Ya Petro 94 in it now, Will give the esso 93 another try again after this tank, I pulled 2, but i think i will put 1 back in to see.
Hagbard is offline   Reply With Quote
Old 08-07-2014, 03:43 AM   #72
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Whenever I reopen the bin file after modifying tables Timing Compensation Per Cylinder A and B, they are returned to the original values. Knock Correction Max Advance A saves fine. What's going on?
Old 08-07-2014, 03:56 AM   #73
steve99
Increase your user level and it will let you save those tables
Wayno (08-07-2014)
Old 08-07-2014, 06:00 AM   #74
Wayno
Wayno's Avatar
Here are the changes to OTS 1.59 G (EU MT) and I (EU AT) series aussie roms.
Stage 1 has Steve's updates for our shitty 98RON fuel.
I STRONGLY recommend not using these and waiting for 2.0 for G and I series roms and hopefully 91 AKI and BPB built in.
<Removed attachments as 2.0 is released>
Old 08-07-2014, 06:11 AM   #75
steve99
be interesting to see how the BPB mods go as they add 2 or 3 degrees of timing over 6000 where our 98 ron does not perform to well knock wise
will add those to the knock fix post thanks
Old 08-07-2014, 06:18 AM   #76
Wayno
Wayno's Avatar
I saw in the BPB beta download shiv has 91 and 93 tunes for everything. When 2.0 is released will it be better to base all our stuff on 91 instead of 93? Or would it be better to copy tables from 91?
Old 08-07-2014, 06:26 AM   #77
steve99
I only had a quick look at the 91 vs 93 tunes but it appeared the only difference was ignition timing advance over about 6000 rpm and about 1 degree pulled out of the 93 tunes to make them 91 tunes its only worth a few hp top end . Probably try the 93 version if your running United Petroleum 100 octane , else i think we will have to run the 91 version on our 98 fuel , its just going to be suck it and see but its easy changes
Old 08-07-2014, 06:40 AM   #78
Wayno
Wayno's Avatar
Do you mean this on the right with only 4 values changed in 1 table between 91 and 93...
Old 08-07-2014, 07:08 AM   #79
steve99
Yes,
I dont have BPB so i only looked at the stg1 91/93 even less changes just the base timing B as you found
@Wayno I believe the tune changes for BPB were for V2xx ROM and not meant for V1.5X tunes as their has been substantial changes to the V2xx tunes from V1.5x.
Old 08-07-2014, 09:33 AM   #80
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
did another 1st, 2nd, 3rd redline pull
http://datazap.me/u/silver-ignition/...og=0&data=1-12
now, if I look at the chart with FLKC and Ignition Advance selected, it seems like when the FLKC drops, the IA drops to about 26*, should 26 be my target number when messing with the tables in Rom Raider under that engine load? Or is it more complicated than that?
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 08-07-2014, 04:19 PM   #81
steve99
Looks like your original fuel was better
Tried to explain it here
http://www.ft86club.com/forums/showthread.php?t=61820
Short version
KCA=Knock Control Advance
IAM=Ignition Advance Multiplier
FLKC= Fine Learning Knock Control
FBKC (Feedback Knock Control)= does not directly impact ignition advance but it will cause the IAM to drop which will effect you ignition advance.
KCA = (values in "Knock Advance Max A table" * IAM ) - FLKC
Total_Timing = Base_timing_B + KCA + other offsets due IAT/coolant temp ect
EG Total_Timing = 25 + 3 - 2
Old 08-07-2014, 04:31 PM   #82
Silver Ignition
APEXHNTR
Short version
my head hurts.
I've read that thread over and over trying to make sense of it but there's just so much that goes into this lol driving me bonkers
#1867 of 2500
Old 08-07-2014, 04:42 PM   #83
steve99
my head hurts.
OK lets make it easier
Lets assume your IAM=1 which it is and stays at 1 and lets assume you car is warmed up to operating temp and the Intake Air temperature is in a range where no offset is applied.
Total_Timing = Base_Timing_B + Knock_Correction_Max_A + FLCK(read from log as a negative value)
Eg
Total_timing = 26 + 2 - 2(flkc)
Old 08-07-2014, 04:54 PM   #84
Silver Ignition
APEXHNTR
Eg
So these two numbers are taken from the maps and applied to the FLKC for the final number that we're seeing in the Ignition Advance column? Am I in the area here?
This is so frustrating because I have a really good grasp on how engine performance works but this whole thing is driving me up a wall
#1867 of 2500
Vishnu Tuning's Tales From The Dyno: Crawford Billet Power Blocks Shiv@Openflash Engine, Exhaust, Transmission 129 11-24-2017 07:58 PM
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 05:01 PM
Crawford Billet power blocks Triumphrider Engine, Exhaust, Transmission 0 08-01-2014 01:39 AM
FS: One set of barely used Crawford Billet Power Blocks Robert@Openflash Engine, Exhaust, Bolt-Ons 1 06-07-2014 04:13 PM
**Crawford Power Block Install Special -- R/T Tuning -- Call Today** R/T Tuning Engine, Exhaust, Bolt-Ons 3 05-21-2014 11:18 AM
