Old 04-07-2014, 03:26 PM   #71
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
phenoyz, it depends which model year you are looking at. Regardless of MY the difference is 50 hp. However there are several other differences as well. Several people have said they like the base model because it forces you to work harder to go fast, and given the engine's smaller size it's a bit more rev happy and needs to be kept high in the rpm band. On the other hand the vast majority of Porsche-philes will recommend always purchasing the newest model year S you can afford (that advice is as old as time).
The 987.1 (MY 2006-2008) Cayman has a 2.7 liter engine with 245hp. The Cayman S of that vintage has a 3.4 liter engine with 295hp. The Cayman has a 5 speed manual transmission - the S model a 6 speed manual. The base Cayman has 17" wheels standard, the S 18"s. The S also has considerably larger brakes with red painted calipers and a "dual" exhaust outlet.
The 987.2 (MY 2009-2012) Cayman has a 2.9 liter engine with 265hp. The Cayman S of that vintage has a 3.4 liter engine with 315hp. The base Cayman still had a 5 speed transmission standard, but I believe the 6 speed box was an option. And everything else I stated above applies to these model years, AFAIK.
While doing research for a potential Cayman purchase I would recommend the online community over at www.planet-9.com
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
The Following 2 Users Say Thank You to WolfpackS2k For This Useful Post:
Ash_89 (03-25-2021), juliog (04-07-2014)
Old 04-07-2014, 03:46 PM   #72
OrbitalEllipses
Drives: Attitude
Originally Posted by regal View Post
If the OP had owned a Lotus Elise he would have covered all the bases. We need to get him behind the wheel of one.
OP probably wanted a car that worked most of the time and was actually comfortable.
Old 04-07-2014, 04:30 PM   #73
phenoyz
Drives: 2011 Honda Fit Sport
Thanks.
phenoyz is offline   Reply With Quote
Old 04-08-2014, 09:27 AM   #74
WolfpackS2k
BTW I was slightly off on the hp figures...The 2009+ Cayman S has 320hp, not 315. Sorry about that.
Old 04-08-2014, 09:44 AM   #75
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
I think the 315 was the rating of the 987.2 Boxster S, if I remember right.
chrisl is offline   Reply With Quote
Old 04-08-2014, 01:38 PM   #76
WolfpackS2k
Yeah I think you're right. Though I thought the difference between Boxster and Cayman was bigger than 5hp, more like 15? Eh whatever :P
Old 04-10-2014, 02:49 PM   #77
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Those numbers are all BS anyways. I had the Cayman R which was supposed to have 330 hp, but the dyno results didn't show that.
Old 04-10-2014, 03:44 PM   #78
chrisl
The 330 is specified at the crank, so unless you know the drivetrain loss, you can't really say whether it was BS or not based on a dyno graph.
Old 04-10-2014, 03:53 PM   #79
King Tut
NASA SpecE30 Racer
King Tut's Avatar
You can when you compare it to Cayman S dynos.
Old 04-10-2014, 04:23 PM   #80
chrisl
Fair enough (though it is always possible that the S is underrated and the R is accurately rated).
Old 04-10-2014, 05:11 PM   #81
juliog
juliog's Avatar
Drives: 86
Do rear engine Porsches experience less drivetrain loss compared to FR cars? (cause no driveshaft..?)
juliog is offline   Reply With Quote
Old 04-10-2014, 05:55 PM   #82
chrisl
I believe so, in the same way that a FF car has lower drivetrain loss.
Old 04-11-2014, 06:30 AM   #83
regal
The Elise has a reliable Toyota drivetrain, haven't heard of issues with the 2zz.
A lot less powetrain loss, basically they have more in common with FWD. Look at the MR-S (2), Toyota raided their fwd parts bin to build that car and it had much less powertrain loss than our twins.
But its much easier and cheaper IMHO to work on FR.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 04-12-2014, 04:26 PM   #84
ZDan
ZDan's Avatar
Drives: '23 BRZ
Rear and mid-engined Porsches do not have much if any less drivetrain loss vs. front-engine/rear-drive cars.
There is pretty much *zero* power lost in the driveshaft of an FR car. Losses throughout the driveline are primarily the transmission (two gear interfaces at ~2% each) and the diff (ring and pinion at ~6%) and the tires accounting for another ~5%.
These same losses are all present in Porsches.
A big advantage of transverse-engine fwd (or transverse mid-engine like the MR-2) is the lack of a ring/pinion. 6% r/p loss replaced with a chain or gearset at 2%, so roughly 4% more efficient vs. longitudinal engine with a ring/pinion, all else equal.
The Following 3 Users Say Thank You to ZDan For This Useful Post:
Ash_89 (03-25-2021), juliog (04-14-2014), WolfpackS2k (04-14-2014)
brz, cayman, s2000
2013 981 Cayman ironchef Other Vehicles & General Automotive Discussions 49 12-09-2012 07:03 PM
FR-S vs Cayman colganc FR-S / BRZ vs.... 102 09-13-2012 04:17 PM
GT86 vs. 370 vs. Cayman S wrxgoose FR-S / BRZ vs.... 0 08-27-2012 11:26 PM
FRS/brz VS Porsche Cayman jurjurson FR-S / BRZ vs.... 22 08-15-2012 04:14 PM
FR-S, Cayman S, & Lexus GS Mcdj18 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-23-2012 04:49 PM
