Old 06-17-2012, 04:17 PM   #71
ahausheer
Re-member
Drives: Toyota camry
Noob question: Could you get a crankshaft that reduces stroke length to lower compression? Is this ever effective or used or do people just get lower compression pistons?
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 06-17-2012, 04:26 PM   #72
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
The best way is pistons, the cheap (crap) way is thicker head gaskets.
uspspro is offline   Reply With Quote
Old 06-17-2012, 05:54 PM   #73
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
I wonder if Subaru will offer a turbo aftermarket (if that's what they go for in the STi, of course), like TRD usually does with their S/C.
Considering that the compression ratio would almost definitely need to be dropped, I kind of doubt it, but it's nice to dream.
The main thing that would hold me back from FI is the drastic amount of changes that would need to be done to the engine to handle it (pistons, ECU, 3" exhaust system, etc.), even if I'm already considering a tune to smooth out the torque dip of death.
Symbiont is offline   Reply With Quote
Old 06-17-2012, 06:16 PM   #74
MANDALAY
Drives: MR2
I wouldnt think Subaru will Turbo the car as from a marketing approach would say it would eat into WRX sales.
I dont think there will be anything from Toyota also because again i believe they will reintroduce the Supra as a more expensive forced Induced car.
Both companies will retain both models as price conservative high volume sporty cars.
Look what Mazda did, they were in ruins and then released the MX5, With the sales they were able to introduce the RX8 and the revamped 3.
MANDALAY is offline   Reply With Quote
Old 06-17-2012, 09:17 PM   #75
xwd
I think the cars are for different enough crowds and an STI version would be even lower volume than the WRX STI version. It would likely be between 32-35K so that prices it out of reach for a lot of folks. Subaru makes three levels of Impreza, I don't think you'll see that with the BRZ probably only two.
Subaru isn't going to make a bolt on turbo upgrade. They have never done that and there is just too much to change out.
The compression ratio is the big issue IMHO. The car already requires premium gas NA, I think a piston swap will be mandatory to be safe unless you are willing to run E85 all the time, which you could do, or some kind if race gas.
Old 06-17-2012, 10:01 PM   #76
GirlyScions
Drives: Mazda3
If I was to chance boost on this high compression engine it would be a positive displacement S/C. Such as a eaton mp62 or a jackson. Simply because there are no kits available and S/C will be cheeper and simpler to install.
These superchargers also only come on during wot which is great for when you need power and youll keep your daily mpg.
Id prefer a factory sti turbo brz though.
GirlyScions is offline   Reply With Quote
The Following User Says Thank You to GirlyScions For This Useful Post:
Old 06-18-2012, 12:59 AM   #77
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I think the centrifugal charger is the best option for the space constraints. Easy, compact, self-contained, no extra oil/water lines. Less heat to deal with.
But I also think a larger turbo BRZ would be nice. I have a 6262 bb on my SR20VE in my sentra. It's amazing, 10psi made 365whp. 19psi made 517whp. I have no custom tune either. Rom tune from jim wolf technology.
The response is terrible under 4k rpm. But when the big cam lobes kick in (ala vtec) it hits boost instantly. Once the turbo is spooled, the response is near instant.
Coheed is offline   Reply With Quote
Old 06-18-2012, 04:41 PM   #78
robo_robb
robo_robb's Avatar
Drives: Whiteout FR-S
Personally, I would prefer a Supercharger on a car with reflexes this sharp. Throttle response is paramount.
robo_robb is offline   Reply With Quote
The Following 2 Users Say Thank You to robo_robb For This Useful Post:
Dadhawk (06-18-2012), Swift Racing Technologies (07-11-2012)
Old 06-18-2012, 11:25 PM   #79
Unleashed
Unleashed's Avatar
Drives: 13' WRX
Noob Question
Really noob question, but I heard people talking about running E85 to compensate for the high compression ration. Is that true?
Unleashed is offline   Reply With Quote
Old 06-19-2012, 12:04 AM   #80
Don@Accelerated
Don@Accelerated's Avatar
I'm currently working on a turbo kit. Its very simple to get that low end torque with a turbo when setup correctly.
Don@Accelerated is offline   Reply With Quote
Old 06-19-2012, 03:50 AM   #81
MANDALAY
Drives: MR2
Rotrex would be easy.
The way i see it , remove the bid resonator and that tube.
Make a bracket to the left of the alternator and put a restrictor on the inlet and feed the TB.
Low psi , no intercooler , stock internals and hell maybe even the stock ECU could handle it. 5 psi and you will definitely gain 50 -70 Hp
Old 06-19-2012, 12:47 PM   #82
Swift Racing Technologies's Avatar
Patience Grasshopper there are definitely FI under development for this platform. Details will be released soon
Swift Racing Technologies is offline   Reply With Quote
Old 07-10-2012, 09:48 AM   #83
MANDALAY
Drives: MR2
There are a few happening at the same time around the world.
Old 07-10-2012, 10:21 AM   #84
catharsis
Drives: honda civic si 08
theres always some turbo lag. I think a small turbo would be ok for this car. But supercharging is ideal.
catharsis is offline   Reply With Quote
The Following User Says Thank You to catharsis For This Useful Post:
super GT in 3D shadow explorer Off-Topic Lounge [WARNING: NO POLITICS] 13 05-31-2012 04:08 AM
Im super drunk Exhaust Off-Topic Lounge [WARNING: NO POLITICS] 5 04-02-2012 10:15 AM
Super GT McAndrewsR BRZ First-Gen (2012+) — General Topics 6 03-15-2012 04:30 PM
Super excited but..... curtiscr87 Scion FR-S / Toyota 86 GT86 General Forum 26 02-02-2012 01:07 AM
Super Bowl! Midship Runabout Off-Topic Lounge [WARNING: NO POLITICS] 13 01-29-2010 05:02 PM
