Software Tuning Discuss all software tuning topics. |
03-11-2014, 12:07 PM | #71 | |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
The logic behind getting into rough correction mode is quite convoluted - not just Rough_Correction_Minimum_KC_Advance_Map_Value involved. This is a good reference - http://www.romraider.com/forum/topic1840.html |
03-11-2014, 12:13 PM | #72 | |
To exit from fine correction mode to rough correction mode, ALL of the following requirements must be met:
Of course this all applies to a car that isn't ours... it could totally be wrong. I have found through experimentation that using less than 3.9 in the advance table keeps it from dropping, that's all i know for sure. then again, i often set it to zero in those areas just coincidentally, so maybe that's why it doesn't seem as though the table matters. i could swear i remember running 0<value<3.9 in the advance and not seeing it drop, though i cant be sure about that without correlating old roms to logs or testing it again. |
03-11-2014, 01:39 PM | #73 |
Yeah, it is odd that that's the case. Maybe setting that value to 0 changes the way the logic handles the advance tables - I've never really looked at it closely. The logic is pretty much the same as other Subarus, incidentally.
03-11-2014, 11:07 PM | #74 |
Code:
If (in fine correction) { If (pulled more than 4 degrees or the ECU is unhappy) { Goto (IAM correction) } If (Large/rapid change in engine load) { Goto (FBKC) } } else { Check to see if any adjustments need to be made Stay in FLKC correction mode } If (in FBKC mode) { While (engine load is rapidly changing) { Check for knock and pull timing if needed When (Done) { Go back to previous mode } } } Looks like I'll need access to flkc @shiv@vishnu to confirm for myself or @Td-d /anyone with previous subaru platforms to clarify if the number in the map that dictates where coarse correction starts is at 4, and since ours is set at 0 so behaves differently. |
03-12-2014, 12:24 AM | #75 | |
As for where course correction starts well got no idea |
03-12-2014, 12:29 AM | #76 |
Most of the tip in knock I see shows up in fbkc. It'll write into fine learning sometimes though, particularly when tipping in to a long pull.
The Following User Says Thank You to jamesm For This Useful Post: | steve99 (03-12-2014) |
Similar Threads | ||||
BC Racing Coilovers - Knock? | 636 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 42 | 12-09-2015 10:41 PM |
FR-S Rod knock | pozer | Issues | Warranty | Recalls / TSB | 95 | 11-03-2015 09:39 AM |
ca-fi knock off questions | fionnsfrs | Electronics | Audio | NAV | Infotainment | 2 | 10-27-2013 01:47 PM |
Knock on e85 not a problem? | gdrider77 | Forced Induction | 76 | 10-20-2013 11:36 PM |
Would you rather buy knock off parts for your car? | EJ20 | Engine, Exhaust, Transmission | 63 | 11-02-2011 06:17 PM |
