Old 10-03-2013, 04:35 PM   #71
sparks
sparks's Avatar
Originally Posted by Iddoit2er View Post
While I opened up the door to put the new speakers in, I took out the door control assemblies and wrapped the housing in foam before putting them back in. No more rattle from the door controls! I suggest anyone who needs to take the door card off do this while youre in there. Now to fix the rattle from the TBL...
I didn't do anything to mine and the rattles are GONE. Funny how removing low bass from the doors quiets everything down
2013 BRZ Preimum #452 - Sterling Silver
sparks is offline   Reply With Quote
Old 10-03-2013, 05:30 PM   #72
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
You can remove the resonance that causes some rattling by adding damping material to the door. I added second skin speaker tweakers in the door panel behind the woofers and can dial the bass up a little before it starts booming.
http://store.secondskinaudio.com/speaker-tweaker-kit/
Haven't found a need to add any more damping material.
JDKane527 is offline   Reply With Quote
Old 10-03-2013, 06:54 PM   #73
Iddoit2er
Drives: S
You know, I noticed that there's a frequency range thats not quite as present anymore - Im guessing thats why it sounds a lot cleaner, or at least in large part.
Can someone out there give a real quick explanation of the upgrade in layman's terms? What they did to the DSP? What the new cable is for? All i know is that it sounds different, theres a range that I dont quite hear anymore, and two speakers arent being used anymore.
Iddoit2er is offline   Reply With Quote
Old 10-03-2013, 11:12 PM   #74
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
It works!
New DSP Amp cured everything!
So thankful the car is well insulated.
http://www.ft86club.com/forums/showp...4&postcount=53
The sound is excellent, I sat with my daughter and listened to Imogen Heap,"Hide & Seek", shocked at the detail and the sound stage.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 10-04-2013, 09:03 AM   #75
sparks
sparks's Avatar
The 400+ system feeds Front Left channel to the dash speakers (mid+tweet) and the same channel feeds the door. So 2 speakers (seperated by distance) are producing twice the mids.
The 400CF first replaces the door speakers, not a bad speaker but the replacements are better.
The cable uses the old mids speaker connections to feed the doors. The power for Front Left passes through the tweeter into the new cable and plugs into the disconnected factory amp (lines to the doors).
DSP - I started with a 400CF, so I have no comparison, but have experience with a few SQ builds. The sound stage is centered on the driver, I can fine tune the EQ to my liking, and I can tell the rear speakers are working. Now that the DSP is routing all the bass to the sub, my doors don't rattle, my license plate does
The Following 2 Users Say Thank You to sparks For This Useful Post:
Iddoit2er (10-04-2013), tonystewart (10-04-2013)
Old 10-04-2013, 11:00 AM   #76
tonystewart
Thank you for the explanation, very helpful.
Old 10-04-2013, 10:28 PM   #77
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Might be a silly question but do you mean the sound stage is centered on the front? Or is it literally on the driver where the passenger seat hears the sound slightly worse?
l0aded is offline   Reply With Quote
Old 10-05-2013, 08:38 AM   #78
sparks
sparks's Avatar
On the driver, from the passenger it's a littlie right side heavy but still clean
Old 10-15-2013, 06:41 AM   #79
Raven23
So how are people liking their reference upgrade? Is it a big upgrade compared to the regular version?
Raven23 is offline   Reply With Quote
Old 10-15-2013, 08:30 AM   #80
buddy32
Drives: WRB Subaru BRZ Limited
Installed a couple of weeks ago. I like it alot.
http://www.ft86club.com/forums/showp...40&postcount=6
buddy32 is offline   Reply With Quote
Old 10-18-2013, 05:29 PM   #81
epsilonkore
Drives: FireStorm 6 Spd Manual
My review of OEM Audio Plus Reference
I find the reference to be an improvement over the base 400 series in spacial positioning and midrange. The OEM door speakers along with the dash mids were a shallow/narrow mess compared to the Reference door speakers and deactivation of the dash ones. That being said, it provides no more "boom" for those of you looking for that,(it SHOULDNT, its a "REFERENCE" system) its just cleaner, better positioned and supplies a complete aural range as the door, dash tweets and sub all complement each others range specs better than the OEM ones ever did. The backseat speakers are along for the ride it seems, and barely audible... there just for positioning. I am happy with my setup, and for early adopters the upgrade price minus the $100 rebate made it worth it for me. I work in the music entertainment industry and I was a bit embarrassed to let my co workers ride and listen to the stock setup. OEM Audio will keep me in the lunchtime carpool rotation as even our head of A&R was impressed
That being said, a few things I dont like:
I dont like that I had to lose my dash mids (they cut the mids connector off to attach to the new umbilical cord). Part of the reason I liked the idea of OEM Audio was that it preserved my stock setup so I could restore it later if I trade up or just want to sell the system used. I can no longer do that without selling the car with a neutered dash setup.
I also dont like all the umbilical cables running through the dash. Along with my AVIC x950, SiriusXM and the various adapters to make it all work, the area behind my head unit is a tangled mess once I added the umbilical (despite my attempt to zip tie it into submission). I hoped "OEM" could have kept it cleaner, but together with Pioneers help that area is crammed full. The second complaint: the system sounds great at lower volumes (sign of a good system) and at higher ear piercing levels. Its clean, powerful, smooth and only needs minor EQ tweaking to fit the kind of music I listen to most (country, pop, rap) though I find that dance/house music needs a bit more work to keep all the sounds from melting/muddling together. I have tried tweaking the EQ quite I bit and I cant seem to find a happy spot for songs with extensive layers of sound. This kind of music can be hard to reproduce accurately, but by seeing "reference" in the name, I hoped it would be a little closer to our studio setups that can play ANYTHING accurately, then again this is a CAR with pre positioned (and not optimally) speaker locations. It will never match the studio, but it does sound damn clean at its best (listen to Drake Hold On, We're Going home) and good at its worst (anything heavily layered and already distorted, The Killers "Shot at the Night" disappoints me after hearing it in the Studio).
epsilonkore is offline   Reply With Quote
The Following User Says Thank You to epsilonkore For This Useful Post:
Gary in NJ (10-18-2013)
Old 10-30-2013, 02:41 AM   #82
Yruyur
Yruyur's Avatar
Got the stock 3.5 speakers out and the amp off to ship back for the reference series.
Sent from my SCH-I545 using Tapatalk
Old 10-30-2013, 02:42 AM   #83
Yruyur
Yruyur's Avatar
And a close up of the 3.5
Old 11-07-2013, 10:54 AM   #84
Yruyur
Yruyur's Avatar
Here are the speakers back. You can see how they removed the plugs to add to the umbilical
Sent from my SCH-I545 using Tapatalk 2
OEM Audio Plus [Reference] 400 shiro Electronics | Audio | NAV | Infotainment 3 08-16-2013 04:18 PM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 10:45 PM
Wheel reference links JDLM Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 02-27-2012 04:22 AM
Toyota reference has the FR-S with a 2.5L motor Toyota fr-s Scion FR-S / Toyota 86 GT86 General Forum 3 09-24-2011 06:42 PM
Toyota Reference Site Axel Other Vehicles & General Automotive Discussions 7 03-06-2010 08:07 AM
