Old 06-30-2016, 02:17 AM   #71
japes
Fish out of water
japes's Avatar
Drives: 2016 86 GT White
Originally Posted by shiumai View Post
The tires and wheels, in those specific sizes, fit without issue when i was lowered 1" on swift springs and stock suspension. Camber was addressed with the LCAs in the rear and camber bolts up front.
When i went another 1/4" lower on Tein Flex Z coilovers, the rear driver tire rubbed the rear bumper plastic clip when going over some dips. that was the only rubbing i experienced. front camber was taken care of with the coilover top hats in front.
Really? wow, I thought there'd be problems in the front at full lock.
I'm making a parts list, so in addition to coilovers, rubber and wheels, looks like I need LCA and camber bolts. Which ones do you run? Would you recommend them?
I need to keep the wheel/tire flush or sucked to the fender, else I wont pass vehicle inspection here, so the devil will be in the details
Let's be honest, I have no idea what I'm doing.
japes is offline   Reply With Quote
Old 06-30-2016, 08:49 AM   #72
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
i have 8.5 in the front, so no issues with rubbing at full lock. maybe with 9.5 you'd have to be a bit more careful. you don't need camber bolts if you have coilovers with adjustable top hats. i run the cusco LCAs but my alignment shop recommends SPL.
if you need to keep the wheels flush with the fender, i'd go with 8.5" wide all around, +42 offset, face 2 in the 57xtreme. probably with 235/40/18 tire size.
shiumai is offline   Reply With Quote
Old 06-30-2016, 10:51 AM   #73
japes
Fish out of water
japes's Avatar
I was thinking that, but staggered looks so good. I guess it cant be helped though.
I'm looking at these https://www.rayswheels.co.jp/product...el=57Xtreme_XM , so I think the sizing is the same though. It says face 1 and 2 but I don't see anything in the images. I'll have to find a dealer and work it out i guess.
Thanks so much for the help, I'm pretty lost in all this right now. It's my first time, and I'm dealing with the language barrier
Old 06-30-2016, 11:18 AM   #74
shiumai
shiumai's Avatar
Face 2 is more concave than Face 1 and looks better. my front is face 1 +33 and is flat; i'd have bought face 2 +42 if it were available when i bought my wheels but that size had not been offered yet.
Old 07-03-2016, 11:56 PM   #75
Odd
Odd's Avatar
Drives: DGM BRZ
Originally Posted by haimichaeltran View Post
Were you still under their one year warranty?
I think I was - or within that time. They honored the warranty but it took a little email persistence. Now i'm just waiting for the other one to go out.
Odd is offline   Reply With Quote
Old 10-25-2016, 02:42 PM   #76
Daver
Do Coilovers eliminate the need for the LCAs in the back, or will I need to purchase both?
I have finally gotten my Wheels and Am also making a part list on what I need. (gettin expensive :/)
Daver is offline   Reply With Quote
Old 10-25-2016, 07:10 PM   #77
shiumai
shiumai's Avatar
You'll still need LCAs to adjust camber in the rear.
Old 05-20-2017, 12:35 PM   #78
shiumai
shiumai's Avatar
5/20/17 - Installed a Marsh Power House (MPH) Fabrication GT-spec carbon fiber hood (http://www.marshpowerhousefab.com/pr...86-gtspec-hood), after seeing this thread:
http://www.ft86club.com/forums/showthread.php?t=116268
I bought it to reduce under hood temps during stop and go traffic in summer, and to increase efficiency of the radiator by increasing airflow on spirited drives. It should work the same as cutting vents in the OEM hood, which I didn't want to do. I'm not expecting it to reduce peak oil temps but to aid in coolant recovery time between pulls during occasional canyon runs.
I'm leaving it unpainted (it comes with a clear coat) because it's an additional cost, it blends in pretty well with my DGM car, and if I ever need to return to stock, it's easier to sell an unpainted CF hood.
Observations - it's very light and rigid. The backing structure around the perimeter makes it stiff, and it doesn't feel flimsy at all. The rear corners are slightly high (maybe 1/8"), so I've let Joel know about that for future builds. No biggie to me. All the holes for the OEM rubber/plastic seals are drilled and the seals transfer over perfectly. I got mine with the tubes to direct airflow from the NACA ducts down to the coil packs, but I haven't installed them yet. There's probably no need to install them for daily driving, but might be nice to have them for canyon runs or track.
After observing both oil and coolant temps (via my P3 vent gauge) during daily driving, I notice that my coolant temps don't exceed 194°F as much as they used to. In stop and go traffic, the coolant temp doesn't rise as much as it did in hot summer weather. If it does, peak temps are a few degrees lower than I observed before, as the hot air is allowed to exit the engine compartment. Once I start moving, coolant temps drop faster than before. I've noticed oil temps seem to drop faster as well after a few strong pulls.
The Following 16 Users Say Thank You to shiumai For This Useful Post:
ajaxthebetter (07-16-2017), avishenoy1 (07-14-2017), BigFatFlip (07-14-2017), botbs (06-04-2020), carsebuco (07-20-2017), Clipdat (07-14-2017), DGMlJDlBRZ (05-21-2017), gramicci101 (05-20-2017), Lonewolf (01-01-2020), mrg666 (02-05-2019), new2subaru (05-20-2017), paiceyfan (05-20-2017), Raven86Project (07-29-2017), Satanasso (03-13-2019), turbocat (03-23-2018), zigzagz94 (06-06-2017)
Old 07-14-2017, 12:49 PM   #79
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
God damn, that looks amazing! And the fitment looks spot on as well!
Originally Posted by humfrz
I'm old and lazy
shiumai (07-14-2017)
Old 03-12-2019, 01:54 AM   #80
Lav
Drives: Frs
Commenting because i dont know how to save on the tapatalk app. I can subscribe but i cant find it later unless there is activity
bibbity boppity give me the zoppity
Lav is offline   Reply With Quote
Old 01-01-2020, 12:29 PM   #81
shiumai
shiumai's Avatar
Happy New Year, all. 2019 was a pisser because of the WTY-84 (valve spring) recall which is required for registration in California. After waiting for more than a year to see what people were doing, I finally had the Edelbrock supercharger un-installed by CSG (who had installed it originally) in December. The car is currently at the dealership for the recall as of today. The Edelbrock is up for sale as I do not plan on reinstalling it. http://www.ft86club.com/forums/showthread.php?t=138163
Also sold my MPH hood as it's no longer needed. I'll miss the supercharger for sure, but don't want to re-install it and have something happen due to the recall work. If anything happens, the dealer will point to the supercharger for sure.
The Following User Says Thank You to shiumai For This Useful Post:
BRZ Guy (02-05-2024)
Old 01-03-2026, 01:22 AM   #82
shiumai
shiumai's Avatar
Happy New Year all! I still have my BRZ - it still looks pretty damn good and people are surprised it looks so clean inside and out. It's 12 years old and I've got almost 28k miles on it now, lol. Not much, but my daily commute is only 4 miles to work.
As you can read from my last post, I returned the engine back to stock in 2020 and sold the E-force supercharger. The whole valve spring recall ordeal for the whole of 2019 really pissed me off. My wife told me 'just stop modifying your car (referencing the 280Z and BRZ) as you always have problems. Just buy a car with enough power from the start'. I was like 'You're giving me the green light to get a new car?' and she said 'Yup'.
So, back in 2019, I was shopping for another car while I was going through the valve spring thing. I was looking at a Cayman or BMW M4, but I'm not a Porsche or BMW guy. So I just waited and looked. Then in July 2019, Chevrolet announced the C8 Corvette. I saw the reveal, the specs and the price, and I said 'That's it!'. I put my name on a list in Nov 2019 and a deposit/order in Dec 2019. After waiting more than a year, I took delivery of my 2020 C8 in Jan 2021.
My wife asked me 'What are you going to do with the BRZ? Are you seriously going to drive the C8 to work?' I said 'That's what I was planning to do'. She asked me how much I'd get for the BRZ so we looked it up and it was about half the value (at that time) and she said 'Just keep the BRZ as your daily driver'. This also meant that she'd have to park her Subaru Outback in the street so both my cars could be in the garage. Thank goodness I married the right woman!
So that's where I am now. BRZ as the daily, C8 as the canyon weekend car. My son got his license and drives the BRZ occasionally. Now I'm thankful it's back to stock without the power of the supercharger.
villainous_frx (01-03-2026)
FT-86 Wallpaper Gallery Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 80 05-22-2014 09:12 PM
New Gallery of TRD Parts harajukukei FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 50 06-18-2013 10:33 PM
Projects and Gallery Dezoris Member's Car Journals 0 10-26-2012 05:30 PM
Progressive snapshot Yruyur Scion FR-S / Toyota 86 GT86 General Forum 11 09-25-2012 12:31 AM
Gallery of parts to look forward to from Tom's harajukukei Scion FR-S / Toyota 86 GT86 General Forum 20 09-09-2012 08:16 PM
