Old 08-21-2013, 01:28 AM   #71
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Originally Posted by nataku View Post
Not really a complaint as much as an observation but, did any of you guys buy the blow off valve? I got it because I wanted that hissing when I shift (what can I say I care about stupid things like that). Anyway I don't even hear a peep out of it at any point, even if I redline and just let off completely. Is it just something that doesn't do much until I up the boost?
It's a recirculated blow off. With a cold air intake you will probably hear it open a bit, but def not with the factory air box. It will never be as loud as an atmospheric blow off
The Following User Says Thank You to spitfire481 For This Useful Post:
nataku (08-21-2013)
Old 08-21-2013, 01:30 AM   #72
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
Oh ok. Well just part of the stealth aspect of this kit then. Gotta love it.
nataku is offline   Reply With Quote
Old 08-21-2013, 01:34 AM   #73
DAMotorsports
Drives: 2013 Scion FRS "Raven"
I have the 50/50 bov with the plate removed and yes u can hear it
DAMotorsports is offline   Reply With Quote
The Following 2 Users Say Thank You to DAMotorsports For This Useful Post:
nix (08-21-2013), Sportsguy83 (08-21-2013)
Old 08-21-2013, 01:38 AM   #74
nix
nix's Avatar
Drives: AVO BRZ
Mine has that plate as well that takes it to 50:50 recirculating/venting it's pretty loud.
nix is offline   Reply With Quote
Old 08-21-2013, 01:39 AM   #75
nataku
Negative Mass
nataku's Avatar
Hmm could you explain a bit more? I didn't know there was more than one type. That could come with the kit. Mine does have a plate on the passenger's side of the valve with a couple of screws in it if that's what you're talking about.
Old 08-21-2013, 01:40 AM   #76
nataku
Negative Mass
nataku's Avatar
Yeah looks like what nix posted. I guess I'm not listening close enough!
Old 08-21-2013, 01:49 AM   #77
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
do you have the gate open or closed? It can be a full or a 50/50 depending on what you set
btw anyone have a clip. I hope its not too loud
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 08-21-2013, 01:54 AM   #78
nix
nix's Avatar
Drives: AVO BRZ
I had trouble recording the sound of it properly so far. It's dead silent with it closed and with it open just a nice audible, standard psssht sound, nothing loud or pitch altered like some big tuner brands.
The Following User Says Thank You to nix For This Useful Post:
Mr.Jay (08-21-2013)
Old 08-21-2013, 01:59 AM   #79
nataku
Negative Mass
nataku's Avatar
Yeah thanks for the inputs guys. I just went and pulled the plate off and it sounds great now. I was only able to hear it clearly by redlining with the hood up and the door open. In the cabin it's not too noisy, and outside it's certainly less noticeable than my exhaust noise.
The Following User Says Thank You to nataku For This Useful Post:
Mr.Jay (08-21-2013)
Old 08-21-2013, 02:59 AM   #80
FRSRAVEN
With the BOV on the AVO kit, its located after the MAF sensor. So if you vent that air to atmosphere, you are venting metered air. This could throw off the tune a bit.
If it were me, I'd leave it on full recirculate.
Probably a minor issue, but something to keep in mind.
FRSRAVEN is offline   Reply With Quote
Old 08-21-2013, 08:02 AM   #81
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
When we installed our kit, I tightened everything and did not have any problems. We did some track testing and blow the inlet gasket. Talked with Paul and a buddy of mine and found a set of locking nut plates that should fit to help stop the nut from backing out. Ill post the part numbers on Thursday once they arrive and I can confirm they work.
What inlet gasket?
Old 08-21-2013, 08:06 AM   #82
Sportsguy83
Drives: Limited BRZ
The gift that keeps on giving...
[ame="http://www.youtube.com/watch?v=W7uqfy6ZAJI"]Subaru BRZ with AVO Kit drive by video - YouTube[/ame]
I had this concern when I got the kit. After having it, its not a big issue. You will go rich on shifts, but for a fraction of time. Also, the tune will account for it and it really becomes a non-issue. If it were a 100% vent I would say its something to really look at, but since its 50/50 its impact is minimal .
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Mr.Jay (08-21-2013)
Old 08-21-2013, 09:51 AM   #83
spitfire481
Drives: 2JZ FRS
Good to know its 50/50 or 100% recirc. I thought it was just recirc only. Open atmosphere causes horrible rich issues between shifts on VW's, which I'm used to working on. I guess ill pull the plate and give it a go haha
Old 08-21-2013, 10:39 AM   #84
boarder1995
Drives: 2013 Subie BRZ Limited, black, 6MT
If locking bolts or nuts down are an issue, even with blue Loctite, another option would be washers from this company...
Nord-Lock.com
They're not regular locking washers. If it's a nut and bolt arrangement, you'll need a set on both flange mating surfaces. Their design requires greater breakout torque to untighten.
boarder1995 is offline   Reply With Quote
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
