Old 08-27-2013, 03:42 PM   #71
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Originally Posted by 7thgear View Post
subaru axle failing?
hmm
now where did i hear that one before... ohh yeah... a common complaint from every subaru owner since Achilies took Troy.
If the diff is Toyota I would assume the axels are as we'll.
Old 08-27-2013, 03:47 PM   #72
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
unpossible!
Old 08-27-2013, 03:51 PM   #73
TRev
The dealer just called me. They couldn't recreate the noise during normal driving. I requested they also try putting the car under load with the e-brake on. He did hear the noise then but said it is normal and due to the brake pads shifting. That noise matches the clicking sound when the brakes aren't being applied at all so not sure how it can be the pads shifting. Looks like I have to wait until the noise gets worse or the axle breaks. They did torque the axle nuts per my request though so maybe that will help.
TRev is offline   Reply With Quote
Old 08-27-2013, 04:25 PM   #74
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I'm still trying to figure out what exactly this "clicking" noise is as this car makes all sorts of noises
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 08-27-2013, 04:39 PM   #75
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Sure hope it can hold on for at least ~20 more runs!
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 08-27-2013, 04:58 PM   #76
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
If you put the car in reverse with your foot on the brake and give it gas you can hear it. I did that with the tech on the ground with his hand on the axle. Had me put in first and reverse a ton of times. I have a automatic and I could really hear the issue when brake torquing or accelerating in first or coming to a stop. You need to show them pictures and take the tech dude for a ride. The tech dude never drove my car other then into the shop to fix it. I did all the driving.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 08-27-2013, 05:08 PM   #77
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
15k and I have a rubbing sound that's very very slight and faint on rotation,sounds like a going bearing on passenger rear, but I suspect pending or minor cage damage from too many spins etc. is the DSS axle proven by users here on Fi as being more tolerant than stock to track use/lowered usage on road course?
kiichiro is offline   Reply With Quote
Old 08-27-2013, 07:23 PM   #78
BlaineWasHere
Grip>Drift
Drives: FRS
You'll know if you have the clicking noise. Before my failure it was very easy to replicate the noise under light street driving.
Old 08-27-2013, 07:31 PM   #79
Wheeljack
Wheeljack's Avatar
Drives: 2013 WRB BRZ Limited
I just put a deposit down on a BRZ limited with plans to autocross it next season. After reading this thread, I'm starting to reconsider. My S2000 had a similar issue. The axles would click due to improperly torqued axles nuts, and the cars were known for damaging cv boots. However, the damage appeared to effect the track guys. My CV boots eventually wore out, but after 80k miles. I was able to flip them to get another 25k or so. The car averaged 1 autocross every othe month since 2007 (some years I had more time to race than others). It looks like the BRZ may not be as durable. Correct me if I'm wrong but running in stock/street requires the use of OEM axles?
Wheeljack is offline   Reply With Quote
Old 08-27-2013, 07:38 PM   #80
BlaineWasHere
Grip>Drift
Drives: FRS
With all the shit I've put my car through I'll take one axle failure. Plus the downtime on the car from the time it was towed into the dealer from when I picked it up was only 3 days.
Old 08-27-2013, 09:26 PM   #81
Wheeljack
Wheeljack's Avatar
I suppose it's not a big deal as long as we're not replacing axles every 10k miles. All I had to do was go on over to Rennlist and read about rear main seal failures. It can always be worse.
Old 08-27-2013, 10:11 PM   #82
BlaineWasHere
Grip>Drift
Drives: FRS
I made it 36K miles and hundreds of autoX runs.
Old 08-27-2013, 10:25 PM   #83
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Straight from the rule book:
Alternate components which are normally expendable and considered replacement parts (e.g., engine and wheel bearings, seals, gaskets, filters, belts, bolts, bulbs, batteries, brake rotors, clutch discs, pressure plates, suspension bushings, drivetrain mounts, fenders, trim pieces, etc.) may be used provided they are essentially identical to the standard parts (e.g., have the same type, size, hardness, weight, material etc.), are used in the same location, and provide no performance benefit.
G_Ride is offline   Reply With Quote
Old 08-28-2013, 12:48 AM   #84
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
I've made a post about the clicking noise a while back, and now I'm starting to see what it can end up in..
They tightened the axle nut and the clicking stopped, but is that an early sign that my axle is going to break?
I've heard Moe issues with aftermarket axles too..
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
DDM HID Problem LinknLog Cosmetic Modification (Interior/Exterior/Lighting) 18 04-11-2013 12:43 PM
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
Problem! axss Scion FR-S / Toyota 86 GT86 General Forum 32 11-24-2012 02:31 PM
ABS Problem chrislee2423 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 07-09-2012 04:06 PM
anyone with this problem? debs0712 Scion FR-S / Toyota 86 GT86 General Forum 2 06-30-2012 10:17 AM
