Old 07-05-2013, 02:13 PM   #71
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Aww sweet I do have it. Didnt think that was a tool.
Sent from a hamburger
We were surprised too. "That's the tool?" But it works.
post_break is offline   Reply With Quote
Old 07-06-2013, 06:25 PM   #72
DriftEm
DriftEm's Avatar
So I installed the kit, haven't done the flash yet. When I turn on the car, the display shows the ethanol % for couple of seconds and then switches to temp. is that normal? how can I make it to just show the ethanol %?
DriftEm is offline   Reply With Quote
Old 07-06-2013, 06:28 PM   #73
Yruyur
Yruyur's Avatar
I would install the tune and see what happens. It may not be reading the value because the tune tells it where to get the value from.
Old 07-06-2013, 06:40 PM   #74
post_break
post_break's Avatar
Got my kit installed and will be editing the install video tonight.
The display should show ethanol percentage regardless of tune. We switched my car on but not started it and it showed e 8. We didn't even have the ecu cables connected. You may want to recheck your wiring.
Old 07-06-2013, 06:41 PM   #75
iketiak
iketiak's Avatar
Drives: 2013 Toyota 86/Scion FRS
Is it normal to get a CEL without tuning it and with the kit installed?
iketiak is offline   Reply With Quote
Old 07-06-2013, 06:51 PM   #76
post_break
post_break's Avatar
I believe so because the tune repurposed that sensor and stock it thinks the sensor isnt connected.
Old 07-06-2013, 06:53 PM   #77
Sensisnow
Drives: 05 TSX & 13 BRZ
Same here, I got e11 when I turned my car on without the tune. Just the on position, never started the engine, but I never saw any sort of temperature display.
Sent from my Galaxy Nexus using Tapatalk 4 Beta
2013 DGM BRZ
Visconti STG2 FlexFuel Tune - aFe intake - Perrin resonated catback - P&L header, front pipe, & overpipe - Kartboy short shifter - Eibach prokit springs - Smoked sidemarkers - Full LED interior/exterior - Kenwood cmos-210 backup camera - Hardwired Valentine V1
Sensisnow is offline   Reply With Quote
Old 07-06-2013, 07:10 PM   #78
DriftEm
DriftEm's Avatar
I got it, installer error. I had the blue and white/green wires touching. Everything is good
Old 07-07-2013, 12:46 AM   #79
Yruyur
Yruyur's Avatar
*******fantastic diy video you guys have on the first post of this thread*****
Very well shot and explained. Props to the guys involved!
Old 07-07-2013, 01:27 AM   #80
DriftEm
DriftEm's Avatar
One of the best install videos I've ever seen, great job.
Old 07-07-2013, 02:03 AM   #81
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
Great video @post_break & @cobrabyte, well explained and concise.
Just a note to Aussie/Euro members on the fuel line install - I noticed while installing mine that the fuel hose is connected to the metal pipe with only a hose clamp, as opposed to the US plastic + metal fitting.
I had to ditch the included plastic + metal fitting because it didn't fit on securely and is easily pulled off due to the different shape of the metal pipe. Instead I just cut the hose to desired length, fitted it over the metal pipe and re-used the hose clamp.
enouf is offline   Reply With Quote
Old 07-07-2013, 05:31 AM   #82
JiB
JiB's Avatar
Drives: GT86
We noticed the same thing, and if you didnt order the harness, your gonna have a bad time... our ecu doesnt use that position. and we had to steal a pin from the head unit that wasnt being used.
Currently on e57, CEL on, no Traction conrtol on, cruise control gets locked on and doesnt work, and there is no maps to switch. tune feels smooth, but no noticable gains at this point.
Need to do a log, and sort out these CEL codes - P2419 & P2401
JiB is offline   Reply With Quote
Old 07-07-2013, 08:44 AM   #83
enouf
Mr. Grumpy
enouf's Avatar
The pin stealing doesn't sound too bad. It's only one wire after all but it is an unwanted nuisance. Thanks for the heads up!
I've only installed the fuel line assembly at the moment and planning to move to the wiring next week. By the sound of things your flash didn't go too well and sounds half done - @Visconti & @Rich@ViscontiTuning any comments on this, as what JiB is saying doesn't sound good at all.
Old 07-07-2013, 08:46 AM   #84
Visconti
Drives: 05 STi
Sounds like you did something wrong
Visconti is offline   Reply With Quote
campaign: ban jv, diy, e85, fuel leak, kit, laughing to the bank, oh lord jesus its a fire, visconti, viscontifried, viscontinued
Flex fuel testing Dynotronics1 Southwest 5 06-22-2013 03:27 PM
FA20CLUB Flex Fuel Kit Ready FA20Club.com Engine, Exhaust, Transmission 16 05-22-2013 11:04 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
Cheap flex fuel? nix Engine, Exhaust, Transmission 1 05-11-2013 04:05 AM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 02:55 AM
