Old 10-09-2013, 10:46 AM   #71
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by vgi View Post
I wasn't saying you would flash those either.
I don't have an ecutek so sorry if I'm asking a stupid question. I was under impression that if the tune is locked then you can't even see the tables and thus compare the values in the tables between different tunes, or copy those values into map editor OFT uses?
Edit: I mean, if it's not getting values from somewhere then it's you doing the tuning and then it doesn't matter how many other tunes you have had as long as you are comfortable doing the tuning.
You are correct, but just because I can't see the values in the tables doesn't mean I can't datalog the ignition timing or the camshaft angles, or see how much the direct injectors versus port injectors are being used. The real keys are the injector scaling, maf scaling, and ignition retard for boost. I am hoping to get a Tactrix and use ECU Flash to start tuning my own car as well as soon as it is ready for primetime.
King Tut is offline
The Following User Says Thank You to King Tut For This Useful Post:
vgi (10-09-2013)
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
NLM - Full Blown turbo kit with a twist No Limit Motorsport Forced Induction 84 06-19-2013 01:59 PM
SilverSkyline210's Full Blown Turbo Kit Install SilverSkyline210 Forced Induction 22 06-15-2013 05:23 PM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 10:15 PM
