#71 |
Drives: Fr-s 2013 Hot Lava
#72 |
Drives: Rx7
#73 | ||
#74 |
Drives: Rx7
$1200 shipped for coil over to PR.
1. Standard spring length. Spring should be 8/8 standard, but I'll double check. Also can be change to whatever rate u want. 2. WORK Kiwami caps, I think it's black color. Flat version. 3. See #1. |
#75 |
Drives: 2013 Hot Lava FR-S 6 MT
I'm trying to understand the rationale for xxx/40 tires up front but xxx/35 tires in the back ... Is this simply to match the circumference of the stock wheels/tires for speedometer accuracy, while giving the front more height for comfort? Is it simply for stance?
#76 |
Drives: 2013 Raven FRS MT
Work Emotion XD9 question
Okay, I have gone back and forth with RavSpec about tire sizing for the XD9s. Does anyone on here have the XD9s with 245/35 front with 9.0" width and 255/35 rear with 10.0" width? And are you on BCR coilovers? Let me know your set up. Would like better wheel coverage than 235/35 front and 245/35 rear.
#77 |
Grip>Drift
Drives: FRS
What's the offset of the wheels? Pretty important information. Also how much camber are you running? Type of coils don't matter.
However it's likely the larger tire size you are wanting will fit fine.
#78 |
offset is 38
#79 |
There are plenty people with these wheels with the BCR CO setup. Just waiting on one their responses for confirmation before I order.
#80 |
Drives: '24 GR86
There are a few people here running 18x10s all around with similar size/taller tire sizes and they fit fine from what I've read. I would personally just 225/40s up front. 225s on a 9j will be the same as running 245s on a 10j
#81 |
Yep. I want 245 front and 255 rear. I am cool with 9.0" width in the front.
#82 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
I have xd9s 18x10 all around... Currently on 245s front and rear... Plenty of clearance to go 255 or even 265s squared.
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#83 |
#84 |
My FR-S has 5 gears
I'm on stance coilovers which should be about the same spring diameter if not exactly the same... You'll have plenty of inside of clearance esp with only a 9" up front.
Omar GC
| Tags |
| brz, work, wrb, xd9 |
| Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +38 | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 53 | 05-26-2015 11:39 AM |
| Wheel Directory: Work Emotion XD9 18x10.0 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 05-22-2015 11:54 PM |
| Wheel Directory: Work VS-XX 18x9.0 +33 / 18x10.0 +33 | brunofrs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 29 | 11-08-2013 12:26 AM |
| Wheel Directory: Work Emotion 11R 18x8.5 +45 / 18x9.5 +38 | DR1FT | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 01-04-2013 01:16 PM |
| Wheel Directory: Work Emotion 11R 18x9.5 +30 | autofashionfred | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 24 | 08-11-2012 01:39 AM |
