Old 12-26-2011, 12:12 PM   #71
subatoy
subatoy's Avatar
Drives: subatoy
I don't understand what's all the whinning with the 5x100 bolt pattern.
Every freaking Rota wheel comes with that pattern and they
make knock-offs of every freaking wheel out there.
They have an amazing selection of wheels.
subatoy is offline   Reply With Quote
Old 12-26-2011, 01:48 PM   #72
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
He never said that they were the only wheel, only that they had a lot of options for the bolt pattern.
edit: Hachi is ninja modding, removed most of the post.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-26-2011, 01:58 PM   #73
JDLM
JDLM's Avatar
Drives: 2009 BMW 335i
I can't support a co. that can't have an individual thought and has to copy off of others hard work.
AWE90/ZSP/ZPP/2XA/NAV/HID/DPE////M/EAS/Disma
JDLM is offline   Reply With Quote
Old 12-26-2011, 07:02 PM   #74
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
What about calipers? Or were you saying still with stock brakes? I only plan on switching fluid and pads for track use, nothing else.
this x eleventybillion.
Originally Posted by old greg View Post
GT-Pentium or GTFO.
It's not. That's been my point for awhile
yep, i'm in the same boat as you. my MR2 has the weeniest brakes ever put on the SW20 chassis, yet with just some decent pads and fluid, it stops plenty hard enough. not sure why people are SO fascinated with putting the biggest brakes in the world on relatively light cars. and if i ever get it back on track and start experiencing fade (which i fully expect on the slicks with 2.5-3 times the horsepower), i'll step up to a more aggressive pad compound.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 12-26-2011, 08:26 PM   #75
Racecomp Engineering
Jamal on motoiq brought up a good point...on the STI the brembos are on the rear side of the rotor and for the BRZ the calipers are on the front. So it's not going to be as straightforward of a swap as you think (if you want it to work correctly). I have other ideas, but still premature at this point.
- drew
Old 12-26-2011, 08:48 PM   #76
old greg
Rocket Surgeon
Drives: PSM GGA OMG
When your rotors start turning blue, you might want to think about some ducting as well.
There doesn't seem to be anything preventing just swapping the front calipers left to right.
old greg is offline   Reply With Quote
Old 12-26-2011, 09:08 PM   #77
The issue is the piston sizes are staggered....so you'll end up with nasty pad wear if you swap left to right (which you have to do in order for the bleeder to be on top). Fine for "the look" but not worth it for me.
- drew
Last edited by Racecomp Engineering; 12-26-2011 at 09:16 PM. Reason: reworded everything
Old 12-26-2011, 09:15 PM   #78
subatoy
subatoy's Avatar
Drives: subatoy
unless you have lots of money to throw away thats the only way to go for most people.
I have WAY better uses for the extra $1k-$2k I'll save purchasing
the Rotas vs the original brands.
I have no need for forged wheels so Rotas are the way to go.
besides if you have that much money there are plenty of wheel companies that will make you a custom set with ANY bolt pattern you
may need so I still don't understand the whine about the pattern.
Old 12-26-2011, 09:20 PM   #79
NESW20
2.1L 3SGTE
haha, yes, blue would clash with my color scheme on the car...
2008 Civic Si Sedan
Old 12-26-2011, 09:46 PM   #80
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
- drew
I haven't messed with the STI calipers before, but some you can switch the transfer tubes and bleeder to fix that.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-26-2011, 09:51 PM   #81
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Well that does throw a wrench in the works. I suppose the blank bosses will need to be drilled and tapped then.
The sti calipers have internal transfers.
Old 12-26-2011, 09:55 PM   #82
JDLM
JDLM's Avatar
Tell me something I don't know
You make it sound like forged wheels are the only light weight wheels out there that are right : That is incorrect
You act like ROTAs are lightwieght (well that isn't always the case)
Old 12-27-2011, 09:20 AM   #83
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
They can be as lightweight as other cast wheels. LW cast wheel don't tend to be lighter than a LW forged wheel (ie a monoblock design like CE28s, TE37s, etc, not a forged 3 piece wheel which tend to be heavy). All performance wheel companies tend to have light and heavier wheels in their lineup.
Lots of weights of wheels are misleading with only one weight provided for a size, but they vary by offset at times too because the hub area can be thicker (my 5Zigen forged wheels are that way, they are forged but the +35s are ~.5 lbs heavier than +42s).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-27-2011, 09:25 AM   #84
JDLM
JDLM's Avatar
If you would re-read my post I wasn't saying forged wheels are the end all be all wheel or only process for a light wheel
fr-s brakes, fr-s differential, fr-s forums, frs brakes, frs differential, frs forum, frs forums, scion fr-s brakes, scion fr-s chassis, scion fr-s diff, scion fr-s forum, scion fr-s forums, scion fr-s suspension, scion frs brakes, scion frs chassis, scion frs differential, scion frs forum, scion frs forums, scion frs suspension
MOTOIQ A Tech Look Under The Scion FR-S poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 0 12-23-2011 03:45 AM
Confirmed Torsen Differential Andy Engine, Exhaust, Transmission 50 12-12-2011 11:01 PM
Stretched FT-86 chassis to spawn next generation Lexus IS Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 17 12-02-2010 02:27 PM
Brakes, track set up? CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-29-2010 08:16 PM
