#71 | |
Drives: 2024 GR86/ 2015 FRS
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts |
#72 |
Drives: DS FRS
#73 |
Drives: DS FRS
#74 | |
Simmons
#75 |
Drives: '13 BRZ in WRB--let's mod!!!
#76 |
So it seems like the majority of the sound seems to be coming from the diff inserts, then. gah.
#77 | |
+35s should fix all of those things but 255s are going to be a tight squeeze unless you run a lot of camber. They should clear big brakes, too. But they aren't as readily available as the +45s. Personally, I think the answer is somewhere in the middle: +45s with some sort of spacer.
#78 |
Drives: 2013 FR-S Asphalt
I had the trans bushing and it wasn't an issue. I put my diff bushings in last week, before we did Andrew's car and it helped a lot with wheelhop, but it is much louder.
In fact I might play around with removing some of the diff bushings, maybe the top inserts on the rear to see how things change. |
#79 |
Andrew Pallotta and I got together yesterday at a Steel Cities SCCA Event to do a little tire testing and such. For now here are two runs from my car on Dunlop Z2's:
Me, 41.1: [ame="http://www.youtube.com/watch?feature=player_embedded&v=6p5ZHKeqdz8"]2013 SCR #2 Strano - YouTube[/ame] Andrew, 41.5 (though it was his first run in my car did run a non-recorded 41.0 later: [ame="http://www.youtube.com/watch?feature=player_embedded&v=d--w48LlmvQ"]Andrew 20130519 - YouTube[/ame] Andrew has other video from his car on the Hankooks, he ran a bunch of 40.9's and I ran a 40.89 something in his car. |
#80 |
You jokers are fast!
Nicely done... Andrew is obviously more loose--did he get that squared away for his quickest? My car seems to now have that under control w/o increasing push. VERY nice balance. |
#81 |
Conedancer
Drives: 2013 Subaru BRZ SWP
No noises here..and I have everything but control arm done..congrats on you and Sams developement..
Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#82 | |
The Z2's get a lot better after the first event, I know Andrew didn't like them over the RS3's. I am curios how they work in Lincoln, I know the RS3's work good out there. Good luck to both of you in Lincoln. Simmons
#83 | |
Drives: ND2, formerly BRZ (MT/CBS)
![]() For additional video posts (two more 86's and others), results link, etc from this event, see this thread: http://www.racepa.com/content/index.php?topic=9891.40 |
#84 | |
My video from driving my own car: [ame="http://www.youtube.com/watch?v=XG7s-MAut04"]SCR 5/19/13 - STX FR-S - Andrew - YouTube[/ame] I have Sam's video and will post it up later once I edit it down.
| Ricepuddin's Build thread | Ricepuddin | Member's Car Journals | 71 | 11-23-2019 11:22 PM |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 10:59 PM |
| EOJ (Not much of a Build) Thread | jonbatz01 | Member's Car Journals | 41 | 07-31-2013 08:34 PM |
| JoeBoxer FR-S build thread | JoeBoxer | Member's Car Journals | 112 | 04-08-2013 02:19 AM |
| My Whiteout 6MT build thread... | jadewbj | Member's Car Journals | 10 | 01-04-2013 05:10 PM |
